Old 07-08-2013, 01:54 PM   #1
EvilEagle OP
Oddometer: 101
'07 GSA died while riding - wont start.
I've UTFSF and have read all the threads close to this - but I can't find one that has the same exact problem. I was riding to work the other day, bike was running fine, normal ops/temp/everything. A little more than a mile from my house, the bike died while in gear with gas applied, just as if I'd used the cut off switch. Electrics are all normal, bike turns over after coming to a stop. When throttle is applied during cranking the sound and vibration changes (so it's getting gas) but it won't fire.
'07 GSA with around 38k miles on it.
What am I missing?
(thanks for reading)
EvilEagle is offline   Reply With Quote
Old 07-08-2013, 02:24 PM   #2
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 986
I don't have an exact answer, but I wanted to point out that your original diagnosis is wrong. Changing the throttle opening during cranking does not imply proper fuel flow. It only implies proper compression/vacuum.
Do the basics. Check compression (likely OK given your observations), spark and then fuel.
As a betting man I'd say that your fuel pump controller went belly-up. I could be wrong. Therefore, check the basics.
I'd wish you luck, but I don't think you'll need it...
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is offline   Reply With Quote
Old 07-08-2013, 02:41 PM   #3
EvilEagle OP
Oddometer: 101
Ok, thanks. I was thinking fuel also.
Old 07-09-2013, 09:32 AM   #4
Swinefahrt
RooteR
Swinefahrt's Avatar
Oddometer: 591
That's happened to me. The first thing I checked was the battery connection. Lo and behold I found one of the battery cables loose.
'07 GS
If its got tits or wheels, it'll give you problems!
Swinefahrt is offline   Reply With Quote
Old 07-11-2013, 11:21 AM   #5
Skelt
Skelt's Avatar
Oddometer: 175
The fuel line I used to replace my filter inside the tank ruptured, giving me the exact same results. This is on an R110GS but had the same results.
"Artificial Intelligence is no match for natural stupidity"
2007 R1200GS
1995 R1100GS
2001 F650 GS/Dakar
Skelt is offline   Reply With Quote
Old 07-11-2013, 11:58 AM   #6
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,828
Usually one of two things, battery/cables or fuel controller. Since it is free, I would load check the battery first, and check the cables.
Jim
Old 07-11-2013, 12:03 PM   #7
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,867
It IS a BMW.............buy some decent hiking shoes and keep them in the tankbag.
Make an adventure out of it.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 09-29-2013, 04:17 PM   #8
EvilEagle OP
Oddometer: 101
I was finally around enough to get to the bottom of the problem - fuel controller! Thanks for the tips guys!
Old 09-29-2013, 07:29 PM   #9
wegimex
wegimex's Avatar
Oddometer: 50
I always carry a spare. Standard GS problem. Ring antenna, fuel controller.
R100R Mystic 94, 1190 ADV T 2014
wegimex is offline   Reply With Quote
Old 10-01-2013, 11:02 AM   #10
Shred Head Fred
Captain Amstel
Shred Head Fred's Avatar
Oddometer: 56
'07 Brother
Sounds like a good spare part to have on board. I also have an '07 GSA Adventurer, could you post the P/N? Couldn't find it on MAX fische.
Much thanks in advance.
C heers
"I feel sorry for the people that don't drink because that's the best they're gonna feel all day"
Dean Martin
Shred Head Fred is offline   Reply With Quote
Old 10-01-2013, 12:57 PM   #11
simoneau
Biker/Adventurer/Retiree
simoneau's Avatar
Oddometer: 203
16 14 7 720 776 fuel pump, electronic http://www.maxbmwmotorcycles.com/fic...png?v=04302013
Number 5 on list.
Randy
2014 BMW R1200GSA (OLIVE)
Ride it like you stole it, care for it like you'll keep it, never let it cool down and it'll last forever!
simoneau is offline   Reply With Quote
Old 10-01-2013, 01:36 PM   #12
JimVonBaden
"Cool" Aid!
Oddometer: 53,828
C heers
Just get the bypass cable from Vendors. It is much cheaper and smaller to pack.
Jim
Old 10-01-2013, 02:08 PM   #13
Shred Head Fred
Captain Amstel
Oddometer: 56
Bypass cable on order
Thanks,
Jim
Dean Martin
Old 10-01-2013, 05:23 PM   #14
EvilEagle OP
Oddometer: 101
Rode it tonight. All is well except the brake failure light is on solid from the time the starter is engaged.
Now where did I put that search function???
Times are GMT -7.   It's 01:34 PM.
