Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 02-16-2014, 08:06 AM   #196
ChrisK7
ChrisK7's Avatar
Oddometer: 254
Originally Posted by RoteEddie View Post
How can he adjust anything without adding a pc or similar?
On my 12 SMT 990 as well as the older 990 Adv. you can make or buy a simple cable that plugs into the bike that allows you to tune the bike with free software program called TuneECU. You can change all sorts of settings as well as maps.
I believe the new 1190 has the same plug but I don't know if anyone knows if it will work on the new bikes yet cause of the canbus system.
'14 KTM Adventure 1190R 12 KTM 990 SMT ,09 KTM 530 EXC (plated), 09 Kawasaki Brute Force 750
ChrisK7 is offline   Reply With Quote
Old 02-16-2014, 08:13 AM   #197
Wonway
KTM Fanboi #2
Oddometer: 428
Oh noes! Not the magical canbus system
1994 Ducati 888 LTD #61
2008 Husqvarna TE610
2014 KTM 1190 Adventure R
Wonway is offline   Reply With Quote
Old 02-16-2014, 08:15 AM   #198
RoteEddie
Oddometer: 531
AS far as I know TuneEcu wont work.
14' KTM 500EXC
13' KTM 1190 Adventure
12' Aprilia Tuono V4R APRC
12' KTM 690 Enduro R Evo2
RoteEddie is offline   Reply With Quote
Old 02-16-2014, 08:35 AM   #199
Harold Waikiki
oldfatdumbbrokeoutof
Harold Waikiki's Avatar
Oddometer: 402
he has a full on mobile dyno and computers that he takes to races, etc.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
'09 KTM 950 SE Erzberg
'15 KTM 1290 SA ordered.
Harold Waikiki is offline   Reply With Quote
Old 02-16-2014, 08:37 AM   #200
Harold Waikiki
Oddometer: 402
i will find out on march first hopefully.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
Old 02-18-2014, 05:50 AM   #201
RichyRich68
Oddometer: 36
Direct from Wings. WINGS mufflers with dB-killers mounted (either small or large) - no need to remap (including the new 1190 Adventure)
WINGS mufflers (690, 950/990) without dB-killers mounted - you should remap using the Akrapovic-KTM map
except on 1190 Adventure where catalitic converter remains in the system when only muffler is changed and you don't need to remap.
For all parameters needed for the EFI to calculate the adequate gasoline/air mixture the sensors remain.
One of the advantages of EFI is the constant mixture ratio even when conditions changes (driving on a top of a mountain where the air is thinner....).
Best regards,
Wings
Sent from my RM-860_nam_usa_100 using Tapatalk
2014 KTM 1190 Adventure Graphite - 2008 KTM 505xc ..................Go orange or go home!.........................
RichyRich68 is offline   Reply With Quote
Old 02-20-2014, 05:41 PM   #202
wilmar13
Oddometer: 762
I did notice there are no maps listed for 1190adv... Is it a matter of not listed yet, or it truly isn't compatible due to canbus?
Is there no ktm map for full system available, even from the dealer?
Slip-on and keeping the cat makes no sense to me except for poseur factor. ;)
I mean seriously it will be louder and need repacking even more frequently with the heat from the cat with no real functional improvement.
'14 KTM 1190-R
wilmar13 is offline   Reply With Quote
Old 02-20-2014, 06:07 PM   #203
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,468
http://advrider.com/forums/showpost....&postcount=187
Don't you dare read the thread...don't do it!
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 02-20-2014, 06:27 PM   #204
ChrisK7
ChrisK7's Avatar
Oddometer: 254
I personally didn't do it for the performance. I did it to get rid of 10 lbs of big ugly stainless steel hanging off the side of the bike and to eliminate some of the heat from the stock can.
Oh and HELL YES I did it for the looks. Look at this bike for Christ sake, it deserves it.
Old 02-20-2014, 06:28 PM   #205
wilmar13
Oddometer: 762
Im asking for clarification regarding tuneecu being a non starter vs just not ready yet. Hard to tell if info was speculation, or informed factual information. Installing headers (removing cat) and running it with stock map is a poor idea, unless you have installed wideband sensors and verified AFR is safe throughout rev range. I just don't see how this is possible. Yes it will run. Yes you will burn exhaust valves. The engine mapping and throttle response will not be ideal.
The RC8R has full canbus and tuneecu works just fine.
'14 KTM 1190-R
wilmar13 screwed with this post 02-20-2014 at 06:33 PM
Old 02-20-2014, 06:42 PM   #206
Wonway
KTM Fanboi #2
Oddometer: 428
Then you better put that stock muffler back on or else you will burn the exhaust valves.
Old 02-20-2014, 07:21 PM   #207
wilmar13
Oddometer: 762
I apologize if I have stepped on toes with the tone of my posts, but the engine will be too lean with headers and stock tune.
I am not looking to explain how all the variables play together if it isn't understood, just interested if TuneECU is a future option for the 1190ADV.
'14 KTM 1190-R
Old 02-20-2014, 07:24 PM   #208
Wonway
KTM Fanboi #2
Oddometer: 428
I think it would be helpful to all of us if you do.
Old 02-21-2014, 03:23 PM   #209
Bikefalcon
Oddometer: 11
I have a RC8R on which I installed aftermarket exhaust which removed the cat. I did the 15 minute reset and it seems to run fine. I have not had it dyno check but it doesn't seem to be far off in terms of mixture. I assume the 15 minute reset would also work on the 1190. The steps for the reset-- engine cold, throttle closed, start, do not touch throttle, let idle for 15 minutes, shut off engine.
Bikefalcon is offline   Reply With Quote
Old 02-26-2014, 05:11 PM   #210
ColdC
Oddometer: 146
Under seat option?
Is there a reason that an under seat option wouldn't work? It would be nice to be able to tuck the can in so that pannier racks wouldn't have to be off-set on the exhaust side.
ColdC is offline   Reply With Quote
Times are GMT -7.   It's 09:34 AM.
