Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 02-26-2014, 07:36 PM   #211
Harold Waikiki
oldfatdumbbrokeoutof
Harold Waikiki's Avatar
Oddometer: 387
Originally Posted by Harold Waikiki View Post
i will find out on march first hopefully.
Originally Posted by RoteEddie View Post
AS far as I know TuneEcu wont work.
Rode the 1190r yesterday 250 miles with db killers removed from akra. Sounded great! Also my tuner plugged in the 1190 to his laptop and confirmed that nothing can be modified till auto tune does their thing. Also no use for a power commander.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
'09 KTM 950 SE Erzberg
'15 KTM 1290 SA ordered.
Harold Waikiki is offline   Reply With Quote
Old 02-26-2014, 07:38 PM   #212
Harold Waikiki
Oddometer: 387
I meant tune ecu not auto tune.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
Old 02-26-2014, 10:09 PM   #213
OrangeV
OrangeV's Avatar
Oddometer: 580
This is very different...
75 V perky peak power from around 5000rpm and loves to be worked through the gears.
When you hit that sweet spot, it is simply electrifying. Stoner
A smile is a curve that sets allot of things straight..
OrangeV is offline   Reply With Quote
Old 02-27-2014, 02:11 PM   #214
ternus
El Gran Camino
ternus's Avatar
Oddometer: 90
Was your tuner able to read anything from the bike at all?
ternus is offline   Reply With Quote
Old 02-27-2014, 02:17 PM   #215
Wonway
KTM Fanboi #2
Oddometer: 423
He can read RPM, Speed, Coolant Temp, current gear, mileage and time of day.
1994 Ducati 888 LTD #61
2008 Husqvarna TE610
2014 KTM 1190 Adventure R
Wonway is offline   Reply With Quote
Old 02-27-2014, 07:12 PM   #216
Harold Waikiki
Oddometer: 387
Just that he was locked out.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
Old 03-03-2014, 02:47 PM   #217
TakSD
Oddometer: 55
Did you check that the air/fuel ratio is ok, so you know the bike isn't running lean or rich? Thanks
1190R for everything, EXC 450 Six days for the rough stuff
TakSD is offline   Reply With Quote
Old 03-03-2014, 06:44 PM   #218
dewaynehasty
Oddometer: 90
Muffs
I also don't understand why these slip on exhausts cost so much. I also don't understand why the stock exhaust is soooo freaking big! What is in that thing anyway? Why did they make is so big?
I just want an exhaust that will allow me to have symmetrical panniers. It doesn't have to be titanium or gold plated. Just something reasonably priced that won't hurt the performance.
Any suggestions would be appreciated.
dewaynehasty is offline   Reply With Quote
Old 03-03-2014, 06:50 PM   #219
Wonway
KTM Fanboi #2
Oddometer: 423
Why would you sacrifice space in the left pannier just to make them symmetrical?
Old 03-04-2014, 12:35 AM   #220
Davy F
Pro Goolie Fiddler
Davy F's Avatar
Oddometer: 259
Buy the Remus Hexcone slip-on and then go for the Nomada pannier set-up designed for that exhaust. That will give you the symmetrical panniers you crave.
Good luck exploring the infinate abbyss !
Davy F is offline   Reply With Quote
Old 03-04-2014, 01:45 AM   #221
dragos
Belzebut
dragos's Avatar
Oddometer: 863
The stock one and the Akrapovik are manifold type (they have an internal labyrinth of pipes) while the Remus and Wings just use some "packing material" (fiber glass). Incidentally, this means the Remus and Wings need more maintenance (the packing material degrades and needs change).
dragos is offline   Reply With Quote
Old 03-04-2014, 08:36 PM   #222
dewaynehasty
Oddometer: 90
exhaust
If there isn't anything special about these slip on exhaust "cans" then can we us any can out there even if it is made for other bikes? I realize the OD has to be the same and the mounting hardware won't work, but other than that will it work?
Old 03-04-2014, 08:57 PM   #223
Wonway
KTM Fanboi #2
Oddometer: 423
Sometimes yes sometimes no.
Old 03-17-2014, 07:34 PM   #224
dewaynehasty
Oddometer: 90
exhaust
I found this small exhaust on ebay for $60. The key is that the exhaust must be 60mm inside diameter. It fit perfectly but...way to loud. It doesn't have any baffles at all.
I really don't want to spend 800 on a can. But I'm afraid that I'll end up spending several hundred experimenting on different models before I find one that works best.
http://www.ebay.com/itm/281086129623...%3AMEBIDX%3AIT
Old 03-17-2014, 07:49 PM   #225
steveWFL
steveWFL's Avatar
Oddometer: 1,344
all the stuff the liberals, tree huggers, and green crowd demand be put in there
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Times are GMT -7.   It's 03:39 AM.
