Old 07-08-2013, 09:57 PM   #1
mbrick OP
Oddometer: 135
KTM 690 SM LC4 engine rebuild thread
Hey Advrider,
I am chronicling the rebuild of my 2007 690 SM LC4 engine here. Bike has 12k miles.
It had a bad noise in the bottom that I suspected was the balancer bearing or maybe a crank bearing. Here is a video of the sound. It would go away after about 2-3 minutes idling, which is the strange part... you'll hear it stop near the end of the video then it sounds normal.
The cam chain was tight with a manual CCT (maybe even a little tight for my judgement), so I don't think that was the source.
Now on to the fun work!
Started by draining the oil and coolant. Oil screen on the tranny side shown, other was clean.
Cheated and used the rear brake to loosen the clutch nut since I don't have the tool to hold the basket.
Next removed the motor, fairly straightforward, didn't get many pics. Toughest part was the frame pinching onto the back of the engine through the swing arm pivot.
Finally split the case and removed the balancer.
I am concerned about the balancer shaft grooves from the 2x seals and possibility it already allowed a little water to seep past to the bearing. Should I replace it?
Closeup of the suspect bearing. It feels gritty/rough, especially compared to the other side so I am fairly certain this was the problem.
Note broken oil ring. It could have broke when it opened up after coming past the edge of the cylinder but I don't think that is likely.
Right case cleaned up.
Left case cleaned up.
A little concerned about wear on the small oil pump:
Big pump looks good:
Transmission gears look good, no pitting or missing teeth. Shift dogs have very minor wear
Bore has 1 section with a few lines but otherwise no signs of wear. I suppose nikasil is pretty hard after all
Cleaned piston, very little wear.
Photos of broken oil ring. Was going to replace rings anyway.
Exhaust roller needs to be replaced (as I suspected from reading many posts). Not much movement in the bearing but the galling is a no-go.
Also took apart the starter to clean/grease. Stopped here because I am concerned about holding the 4x (four!) brushes back when re-inserting the stator. Really would like to re-grease the bushing in the back though.
Valves and head look good, no oil on any stems. I will remove the valves to change the valve stem seals. Intake clearances in spec, will check exhaust with new rocker. Should I look for anything else?
Cam looks good.
Had the non-iridum equivalent, electrode is still sharp, I will use a new factory iridium plug though.
Very little play in the big end of the rod, at least as I would grade it quantitatively. I had considered having a new rod kit installed but probably won't.
I have blown through the oil passages with compressed air and nothing seemed restricted.
I'll compile a list of specific tools used once I finish.
I'd like to hear your thoughts!
mbrick screwed with this post 07-08-2013 at 10:28 PM
mbrick is offline   Reply With Quote
Old 07-08-2013, 09:57 PM   #2
mbrick OP
Oddometer: 135
Continued...
Next steps:
-Will have a friend help me measure the bore and piston this week to compare against specs and check clearance to make sure I don't need a piston
-Decide on balancer replacement or not
-Decide to further take apart starter or not
-Finish cleaning the few remaining parts
-Order 2 balancer bearings, rings, exh rocker, gasket kit
Old 07-09-2013, 02:20 AM   #3
Motomochila
Mad Scientist
Motomochila's Avatar
Oddometer: 1,000
You are moving in the right direction but I'd go ahead and replace the big end with a rod kit. The labor to do everything far outweighs the money to replace now. Tearing apart again next year after only a 1,000 miles is a PITA. Also 12,000? I suspect you are hard on the throttle and wring it out to the top before shifting. Ring shouldn't break so early. She's got more than enough power if you short shift and your motor will live much longer. Add a few teeth to the rear sprocket and you'll get all the excitement you need since you rarely ever need the top end based on stock gearing.
Just my opinion after doing the same with mine, only at 9,000.
2014 KTM 690 Enduro R, 2014 EXC500,2012 BMW GTL1600, 2015 BMW F800 GS Adventure, , 2015 Ducati Hypermotard SP and 16 other motorcycle projects in various stages of completion. It's an addiction thing.
Motomochila is offline   Reply With Quote
Old 07-09-2013, 08:34 AM   #4
mbrick OP
Oddometer: 135
What rod kit did you go with and who'd you have do the work? ProX is cheaper but I prefer stock parts.
I was planning on going from 16/40 to either 15/40 or 16/42 since the sprockets do need replacing.
Old 07-12-2013, 12:06 AM   #5
mbrick OP
Oddometer: 135
Just wanted to provide an update after having a machinist help measure the parts:
Piston I: 4.0146"
Bore I x / y: 4.0157" / 4.0156"
Piston to bore clearance: 0.0011" or 0.0279mm.
Crank runout: 0.002" main gear side and 0.003" flywheel side. We did give it a squeeze to see if it would improve but it was pretty happy there. Would have liked to see less runout.
So piston and bore are on the tight edge of the spec, and clearance is just under the tight side. Impressive for the mileage. He said the big end rod bearing and wrist pin both felt like new so I won't replace them.
Will go with a new ring set and a new balancer due to the heavy grooves. Surprised the shaft was not heat treated.
Old 07-12-2013, 01:39 AM   #6
Gleado
Oddometer: 22
You might want to heat treat or surface harden the balancer where the seals ride or it will just happen again. See if you can upgrade the bearing also with a higher grade bearing. Bearing supply houses can be your friend. I ride a DR650, ok flame me, but I'm 51 and don't ride as fast as I used to so it works for me. I've thought about getting a KTM but still in the research mode.
Gleado is offline   Reply With Quote
Old 07-12-2013, 09:29 AM   #7
mbrick OP
Oddometer: 135
Good point about heat treat or carburizing, I will ask around.
I suspect the bearing failed from water ingress past the seals?? Just a theory though. It's a NTN from Japan, what would you consider higher quality?
Depending on what style riding you do, you should look at one of the 690 models. I know the DR will last longer than 12k miles before any major work, but I think KTM's are still really high quality. Otherwise I wouldn't continue buying them!
Old 07-12-2013, 05:33 PM   #8
Gleado
Oddometer: 22
There's lots of different brands like NSK, FAG, etc. I'm no expert but I do have a good bearing house in Albuquerque. I rely on those guys to help with the upgraded bearings. If the original spec'd bearing has held up I will usually replace with same grade. I'd go by failure rates based on what you hear on the forums. Bearing upgrades are not big hitters cost-wise. You can even go ceramic or plastic cage if you don't like the metal cage bearings cause it fragged your trans upon failure. Just be sure to let them know what application your dealing with as sometimes temperature and other factors must be known to properly select the new animal. 11k miles is bogus though that's why I suggested upgrading. Sometimes you can get bad bearings like anything else, but I sure wouldn't go with what you had. As far as my question on KTM's, I'm just trying to get a feel for what I'm in for reliability wise. I ride with guys on occasion running KTM's I'll start asking around. What I like about them is the lightweight and apparently they handle really well too. Good luck with your rebuild!
Old 09-15-2013, 06:30 AM   #9
Orangeshirtdude
Fight the Power Commander
Orangeshirtdude's Avatar
Oddometer: 65
How are things looking on this? I have my LC4 from my 08 690 SMC that I have to tear into. It has just a hair under 30K miles and started making a horrible noise that was different from yours. Mine has shed metal into the oil too--it's definitely a bearing somewhere.
The first thing I checked were the rocker arm bearings as those are known to fail. Mine were fine, but I discovered an odd thing. My valve clearances opened up a ton, as in I measured as much as 0.6 mm on one intake valve. I traded messages with a guy in Europe who said his shat a cam bearing. The hypothesis is that the 690 LC4 engine does not pump adequate oil to the top end during long wheelies. Anyway, without coming right out and saying it, I'm hoping mine is the same issue.
On the other hand, it could be something worse, considering the mileage and that I absolutely flogged this bike. Even though I was very meticulous with maintenance and running good quality oil, 30K miles is a lot for a big bore single.
Ok, now for the most important question: For someone who has never split a case before, how miserable a project is this 690 LC4 rebuild? I do have a machinist/mc mechanic who can advise and help out, but he hasn't opened up one of these particular engines either. Can you offer a "difficulty rating" on this?
2009 Beta 450RR
2008 KTM 690 SMC
2004 Kawasaki ZX-10R (FOR SALE--Please refer to my thread under Bikes in the Fleamarket)
Orangeshirtdude is offline   Reply With Quote
Old 09-17-2013, 01:11 AM   #10
gen
gen's Avatar
Oddometer: 802
You must have flogged it
Mickwheeler put 100,000 miles on an '09 690 Enduro R
with only a replacement of the intake/exhaust rocker arms/camshaft at 31K miles. That's the highest mileage 690 that I think anyone has seen on ADV.
DoD#1458 | GaijinRiders | 2010 KTM 690 Enduro
gen screwed with this post 09-17-2013 at 04:04 AM
gen is offline   Reply With Quote
Old 09-17-2013, 03:55 AM   #11
wvridgerider
wvridgerider's Avatar
Oddometer: 568
After this would you buy another 690?
wvridgerider is offline   Reply With Quote
Old 09-17-2013, 05:39 AM   #12
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,570
Heh, I flogged the shit out of mine. The top end was worn the hell out at 27K miles.
Old 09-17-2013, 07:30 AM   #13
Orangeshirtdude
Oddometer: 65
That's amazing, 100K? Wow. Getting 100K on any bike is an accomplishment.
I rode mine hard and will know fairly soon how bad off the engine is.
2009 Beta 450RR
2008 KTM 690 SMC
Old 09-17-2013, 09:00 AM   #14
davesupreme
grand poobah
Oddometer: 1,553
i know on the RFS motors, the crankcase vent is just above that bearing, and if you get water in the line, it's supposed to kill that bearing....
davesupreme is offline   Reply With Quote
Old 09-17-2013, 10:52 AM   #15
MrHix
MrHix's Avatar
Oddometer: 384
Thanks for this thread mbrick, I hope it doesn't become useful to me for another 16K miles or so.
Cheers,
MrHix
MrHix is offline   Reply With Quote
Times are GMT -7.   It's 04:45 PM.
