Old 07-09-2013, 05:03 PM   #1
Joeboxer82is OP
Oddometer: 26
Battery Voltage
I was riding to work earlier when i noticed my voltage went down to 11.7 from 13.4 and e battery light lit up. I had e battery and starter replaced in May. Could it be either e coil or rectifier??
Joeboxer82is is offline   Reply With Quote
Old 07-09-2013, 05:15 PM   #2
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,535
I think all of the coil and rectifier are internal to your Bosch type alternator.
likely an easy repair for you, or a local automobile electronics ( starter/alternator type ) shop.
or try here.
http://www.euromotoelectrics.com/category-s/26.htm
I find the site a bit tough to navigate, but the parts are good and priced fair.
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 07-09-2013, 07:31 PM   #3
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,527
Assuming you have no loose cables, it would likely be your alternator. Easy, if not cheap, fix. (OK, not that easy.)
Jim
Old 07-09-2013, 07:46 PM   #4
Jazz62
Jazz62's Avatar
Oddometer: 1,034
Can a loose alternator belt cause this?
Jazz62 is offline   Reply With Quote
Old 07-09-2013, 07:51 PM   #5
JimVonBaden
"Cool" Aid!
Oddometer: 53,527
It could, though usually you will hear it.
Jim
Old 07-09-2013, 08:53 PM   #6
Joeboxer82is OP
Oddometer: 26
There's no weird or strange sound coming from e alternator. Hopefully it's just some loose wires... I'll be getting it checked later.Mine is a 2001 R1150GS with 222,000km in it. Thanks fellas...
Old 07-09-2013, 10:08 PM   #7
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,127
If it's not the belt, at that mileage I would suspect the brushes.
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 07-10-2013, 12:52 AM   #8
Joeboxer82is OP
Oddometer: 26
The mechanic told me that the alternator has to be replaced.Lucky he has a used one... Not cheap though! Btw how much does a brand new alternator cost? I do understand that it's a bitch to take it off from e bike.
Old 07-10-2013, 05:38 AM   #9
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,749
Do you have any accessory loads running off the voltage lead in the diagnostic plug?
A couple months ago, I had an intermittent voltage drop and battery light flicker problem. I *thought* it was the alternator, but it turns out I had a bad relay coil connected to that voltage lead. When I replaced the relay, the problem resolved itself.
Along the way, I replaced the voltage regulator - if you've got the alternator out now, remove the VR and have a look at the brushes/shaft. My brushes were significantly worn, so I put a new one in on the 'it can't hurt' principle.
Twilight Error is offline   Reply With Quote
Old 07-10-2013, 07:22 AM   #10
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,420
I would remove the front cover and inspect the alternator belt.
def is offline   Reply With Quote
Old 07-10-2013, 09:04 AM   #11
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,127
Used oilhead alternators are reasonably inexpensive and I have never gotten much for any that I have sold in the past.
Yes they are tedious to remove if the bike has ABS. I have done them.
The unit IS repairable - parts are available from Euromotoelectrics.
Link to a reman one. http://www.euromotoelectrics.com/Rem...w-alt1020r.htm
Old 07-10-2013, 11:33 AM   #12
def
def's Avatar
Oddometer: 10,420
Alternators have few wear parts. They are
1- Brush(es).
2- Bearings.
The other part that might require replacement would be the regulator/rectifier. It is very unlikely that the stator windings have failed.
First things first...there is a chance that the drive belt has broken. It is easy to check so, I would go there first.
We're curious so, keep us informed of what you find.
Thank you.
Old 07-10-2013, 11:47 AM   #13
def
def's Avatar
Oddometer: 10,420
"Caution Will Smith...beware of suspicious used alternator salesmen"
"Hey Andy" "Hey Barney. How ya doin"?
"Well Andy, I've got a problem with that car I just bought from that nice little old lady over in Mount Pilot. The battery isn't chargin' like it should" "Well Barn, I would take it over to Guber and have him check the alternator".
"Andy, that car is a 6 volt electrical system and its a generator, not an alternator. Alternators haven't been used on cars yet. Andy, you should know that".
"Well Barney, I was just tryin' to help. Do what you want".
Old 07-10-2013, 11:50 AM   #14
GS/BS
Oddometer: 28
Battery Voltage
Wow- That's interesting as I was on a business trip yesterday out in the middle of nowhere and my Battery light came on. I had to meet with a client so was concerned. The bike did start after my 30 min appointment but only 1 ABS light is flashing and my Tachometer quit working. During my return trip, the light went out and the Tach started again for about a minute and then the light was back on Tach off again. I got it home but have not had time to look into it much. Did check battery connections all are good. The battery came up on the trickle charger but still have the same issues. I'm thinking Loose Wire. Going to dive into it tonight. Will take any info from anybody. Thanks.
GS/BS is offline   Reply With Quote
Old 07-10-2013, 12:18 PM   #15
def
def's Avatar
Oddometer: 10,420
"Hey Andy" "Hey Barney" "Andy, Guber had a look at the wires under the hood. He says, Can't be fixed. Whadda I do now Andy"?
"Well Barn, I'd put an alternator on it".
Times are GMT -7.   It's 02:14 PM.
