Old 07-09-2013, 06:18 PM   #1
AutoXfreak OP
AutoXfreak's Avatar
Oddometer: 121
Clutch slave bleeding problem
Hey there OC'ers
I had to replace my clutch slave due to the stock one failing. I have installed the new Recluse unit and pre-bled the slave before installing. I am trying to back-bleed the system using the provided syringe. But no matter how hard I push, there is no fluid coming through the master. I have pushed hard enough to pop the tight fitting hose off the syringe. I have the bleeder open, at times it's just spewing out of the bleeder threads. I'm just lost... Please help!?!?
950 Adventure
AutoXfreak is offline   Reply With Quote
Old 07-09-2013, 06:48 PM   #2
Johnf3
Oddometer: 1,048
Originally Posted by AutoXfreak View Post
Hey there OC'ers
The clutch lever is putting enough pressure on the master cylinder so that you can't back bleed it. Make sure the lever plunger is not contacting the master cylinder at all and you will be able to back bleed without issue.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 07-09-2013, 06:57 PM   #3
crazybrit
crazybrit's Avatar
Oddometer: 8,553
Turn the red adjusting knob on the clutch lever until fluid flows.
crazybrit is offline   Reply With Quote
Old 07-09-2013, 08:29 PM   #4
AutoXfreak OP
AutoXfreak's Avatar
Oddometer: 121
Well. After reading a lot of threads about bleeding the slave, I had never heard of this. And sure enough, turned the adjuster on the lever and YATZEE! A huge spatter of fluid emerged and all the air has been bled! Awesome guys! Orange Crush is awesome!
Thank you!
950 Adventure
Times are GMT -7.   It's 02:37 AM.
