Old 07-11-2013, 12:20 AM   #1
pizellu OP
Oddometer: 44
Question R1100gs clutch adjustment
Hi to all, I got a problem when shifting up from 1st to 2nd and more when shifting 2nd to 3rd! 4th and 5th are ok and shifting down is a breeze on all gears. Do you think it is an adjustment? The shifting forks are new and the gears do not skip. I was thinking about the adjustment on the rear of the gearbox. Does it move the clutch? Or it will just make more tension on the cable? I have looked on the manual and the setting on the cable are not that far off.
Thanks for any help!
pizellu is offline   Reply With Quote
Old 07-11-2013, 04:36 AM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,545
Doesn't sound like a clutch adjustment to me. Make sure you have the correct amount of slack in the cable by adjusting the top. If you can't get the correct slack at the upper adjuster, then adjust at the clutch fork down on the trans.
I can't, off the top of my head, remember the proper slack, but IIRC it is around 2mm.
Jim
Old 07-11-2013, 06:30 AM   #3
Poway
SHED (Shit Head)
Poway's Avatar
Oddometer: 500
You Tube
Here's a great, simple procedure clutch adjustment procedure via you tube.
Although these specs are off, a tad for a GS.
http://www.youtube.com/watch?v=Yg1Hz1hGfPg
Poway is offline   Reply With Quote
Old 07-11-2013, 06:33 AM   #4
mike54
You don't get me
mike54's Avatar
Oddometer: 13,370
4-6mm free play at the lever. Also check the linkage at the shifter. If that's loose or sloppy it can cause trouble.
A genius is the one most like himself. - T. Monk via S. Lacy
Do stand up guys lie?
mike54 is offline   Reply With Quote
Old 07-11-2013, 07:07 AM   #5
JimVonBaden
"Cool" Aid!
Oddometer: 54,545
Thanks Mike!
Jim
Old 07-11-2013, 07:19 AM   #6
Dkingston
Dkingston's Avatar
Oddometer: 10
I had a similar issue and this was my problem
Dkingston is offline   Reply With Quote
Old 07-12-2013, 07:10 AM   #7
Jim Moore
Jim Moore's Avatar
Oddometer: 14,592
That's got a few more miles on it. Surely you didn't throw it out!
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is online now   Reply With Quote
Old 07-12-2013, 07:14 AM   #8
Mugwest
Mugwest's Avatar
Oddometer: 7,106
When mine look like that i give 'em to my KLR buddy
Mugwest is offline   Reply With Quote
Old 07-12-2013, 07:26 AM   #9
Dkingston
Dkingston's Avatar
Oddometer: 10
Nope, I kept it as a reminder to put an additional cable along side the new one. I would have been screwed, blued and tattooed if I would have used up the last miles in this one.
What a way to end a day!
Times are GMT -7.   It's 05:04 AM.
