View Results: How do you clean your chain?
Leave it on the bike 76 87.36%
Remove it from the bike 2 2.30%
I ride an expensive import and let the mechanic clean it while I ask for Grey Poupon 9 10.34%
Voters: 87. You may not vote on this poll
Old 07-11-2013, 06:17 PM   #1
HappyForNow OP
Oddometer: 20
Cool2 How do you clean your chain?
4
HappyForNow screwed with this post 08-08-2013 at 08:18 AM
HappyForNow is offline   Reply With Quote
Old 07-11-2013, 07:19 PM   #2
KX50002
NooB, my ass
KX50002's Avatar
Oddometer: 1,837
When I go really fast... the dirt just flies off
SOTGMOTT Some Of The Gear Most Of The Time
KX50002 is offline   Reply With Quote
Old 07-11-2013, 07:21 PM   #3
mitchapalooza
Rider is Air-cooled
mitchapalooza's Avatar
Oddometer: 112
...like an idiot...
Or at least I used to.
mitchapalooza is online now   Reply With Quote
Old 07-11-2013, 07:39 PM   #4
sieg
sieg's Avatar
Oddometer: 2,869
Hit it with the pressure washer, with the engine running, trans in gear, bike on a stand, while washing bike. I clean it when I clean the bike. Really why clean a chain other than just vanity? The pivot points are lubed and sealed, so dirt ain't getting in there. Dirt never stays on the rollers where they meet the sprocket, note how they are always clean and shiny even on a dirty chain. So what are we cleaning? The side plates, so what will that hurt, if they're dirty?
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 07-11-2013, 07:51 PM   #5
joexr
Oddometer: 3,773
I just lube mine when the rollers look shiny and wipe it with a rag. A pressure washer can force water thru the O-rings.
Old 07-11-2013, 08:27 PM   #6
sieg
sieg's Avatar
Oddometer: 2,869
If you point it at the O-rings and not the side plates.
Old 07-11-2013, 08:32 PM   #7
joexr
Oddometer: 3,773
And what do you think happens when the water hits the inner sideplates between the outer? It still < hits > the O-rings at pressure.
Old 07-11-2013, 10:23 PM   #8
sieg
sieg's Avatar
Oddometer: 2,869
I think it is at such a reduced pressure and at such an angle that it does not go past the o rings. All I know is I've been doing it for years and have not had a premature failure with a chain. I'm not saying it can't happen but that's the way I wash mine, and that's what the OP ask. Do you personally know of anyone that ruined a chain with a pressure washer? Me either.
Old 07-11-2013, 11:10 PM   #9
PalePhase
Humour Noir
PalePhase's Avatar
Oddometer: 824
I picked up a tip in another forum and now use a pesticide sprayer (the kind with a pump handle to pressurize the entire container) with kerosene in it and then use the spray from the wand to wash the dirt from the chain as I rotate the rear wheel, taking care to wash out the interface between chain and sprocket. The kerosene will not attack the o-rings and the pressure is low enough that it will not force kerosene past them and risk washing out the lube on the links.
The down side is that it can be very messy and you want to keep the kerosene off your tire and brake rotor and pads. Also, disposing of dirty kerosene is a bit of problem so... reuse it! Most of the particulate contaminant will settle out if you pour it into a container (I use blue plastic container made for the stuff) and wait until the next chaining cleaning to pour it out. You don't need it to be as clean for washing chains as you would for burning it in a kerosene lamp inside your house.
Oh, and it works great for taking off chain wax.
“Fools learn from experience. I prefer to learn from the experience of others.”― Otto von Bismarck
1995 Honda VF750CD
2002 Honda VFR800
PalePhase is offline   Reply With Quote
Old 07-11-2013, 11:43 PM   #10
oldxr
oldxr's Avatar
Oddometer: 1,142
I dont.I do not use commercial chain lube anymore.2 years ago I did rebuild/upgrade job on my plated xr650r.I used Ironman sprockets and a RK x-ring chain.I have been using only triflon or dupont dry film lube only.Chain is clean and all parts look good with 7k of on-off road use.The grit that the chain lube attracts is bad for the chain.If I had to clean a chain I would use wd-40 or kerosene on a rag.I started using triflon on my street bike chain and its clean now.
oldxr is offline   Reply With Quote
Old 07-12-2013, 03:58 AM   #11
Vertical C
Vertical C's Avatar
Oddometer: 2,817
Take the rear wheel off and then through a bath of kero. Its quicker in the long run.
Vertical C is online now   Reply With Quote
Old 07-12-2013, 04:03 AM   #12
hippiebrian
Oddometer: 3,737
What is this "clean your chain" you speak of?
Seriously, the last time I cleaned a chain was in the old pre o ring days. Nowadays, I spray it with lube when I fill the tank (center stands rock) and ride the thing. Chains always still last longer than advertised.
hippiebrian is offline   Reply With Quote
Old 07-12-2013, 04:04 AM   #13
Vertical C
Vertical C's Avatar
Oddometer: 2,817
I think that you are going to get different answers on this forum than you would a sportsbike forum
Old 07-12-2013, 06:26 AM   #14
Smoke Eater 3
Oddometer: 765
Kerosene and then wipe it off.
Smoke Eater 3 is offline   Reply With Quote
Old 07-12-2013, 10:14 AM   #15
GoUglyEarly
Boots Still Clean
Oddometer: 73
I recently cleaned and lubed the chain on my XR400 for the first time.
Took it out in the sandy Pine Barrens and it quickly started to ssssttttttrrrreeeetttccchhh.
Picked up new chain, sprockets and rollers yesterday.
Interested in hearing more evidence for the "no cleaning" theory.
GoUglyEarly is offline   Reply With Quote
Times are GMT -7.   It's 03:53 PM.
