View Results: How do you clean your chain?
Leave it on the bike 76 87.36%
Remove it from the bike 2 2.30%
I ride an expensive import and let the mechanic clean it while I ask for Grey Poupon 9 10.34%
Voters: 87. You may not vote on this poll
Old 07-12-2013, 10:54 AM   #16
Navy Chief
Navy Chief's Avatar
Oddometer: 1,544
We are supposed to clean these things??
Navy Chief is offline   Reply With Quote
Old 07-12-2013, 11:02 AM   #17
RideDualSport.com
TPB all the way
RideDualSport.com's Avatar
Oddometer: 1,596
Spray a rag with some WD40, lift the rear wheel and spin the chain through the rag. I don't spray WD 40 directly on the chain.
For a really dirty chain covered in lots of road grime and old chain lube I may go a step further and use some simple green and a brush then hose the chain off.
My bike equipped with a Scott Oiler, almost never needs the chain cleaned.
"... I lock my rear up at least once every time I throw a leg over a bike."
The RideDualSport Forum
Mountain State Super Tenere Adventure
Alaska Deep Adventure
RideDualSport.com is offline   Reply With Quote
Old 07-12-2013, 01:48 PM   #18
Jan from Finland
Registered
Oddometer: 567
1. Leave it on the bike.
2. Remove it from the bike.
3. Never. I let the mechanic do it.
I would like to see one more option. Mechanics do it occasionally with the pressure washer. Which I don't approve.
4. Never, but the mechanics do it without consent. So does a rain and river crossings.
No, we are not. I only lube the chain when it's new or after a rain. Just to prevent rust. No need to clean it.
Originally Posted by hippiebrian View Post
Nowadays, I spray it with lube when I fill the tank (center stands rock) and ride the thing. Chains always still last longer than advertised.
I would like to hear how long your well oiled chains last? I typically change the chain after 2-3 rear sprockets. Usually at the same time with the front sprocket.
If you are ever attacked by lion, your best defense is to shove your arm down
their throat, grabbing the back of their tongue and hope help arrives quickly.
- Pro Travel Tip by Overland Journal
Jan from Finland is offline   Reply With Quote
Old 07-12-2013, 04:34 PM   #19
DAKEZ
DAKEZ's Avatar
Oddometer: 19,740
I run O-ring or X-ring chains and they don't need to be cleaned.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 07-12-2013, 06:18 PM   #20
Warin
Retired
Oddometer: 2,213
Cleaning
Tools: stick + Rag and/or brush
Material: Kero or diesel (if kero not available, e.g. on a trip)
Use stick to remove gunk from sprockets + chain .. the big bits.
Use rag/brush + kero to wash dirt off chain/sprockets.
The next question is lube?
For wet weather (raining/mud): oil - chain lube or gear box oil if not available
For sand/dust ... a wax type lube .. or nothing .. grit + oil = grinding paste.
For road riding - either of the above.
Warin is offline   Reply With Quote
Old 07-12-2013, 09:16 PM   #21
Krono
Speed Junkie
Oddometer: 193
Not really, but it is like yourself ... one can probably still be ok with only one bath a year
Call it waste of time or wathever .. but I like my bike clean such as my body, my firearms, my car, my house, my dog and so on
L
SM510R
Krono is offline   Reply With Quote
Old 07-12-2013, 09:24 PM   #22
DAKEZ
DAKEZ's Avatar
Oddometer: 19,740
Really? Even if you use that super sticky synthetic stuff? I have been using the synthetic lube and it seams to be collecting a lot of sand and grit. Will the my Wee o-ring chain still be ok?
I don't lube them either. The lube is on the inside. I do spray Teflon Chain lube on about every 300-500 miles for the chain to sprocket contact... Other than that leave them alone and they last longer and are WAY less messy.
Bib
Old 07-13-2013, 02:01 AM   #23
davidji
bike curious
Oddometer: 1,045
Not many choices in the poll. How about for example I don't (with no additional garbage about having someone else do it). Or maybe I don't, I let my chain oiler deal with it.
davidji is offline   Reply With Quote
Old 07-13-2013, 02:02 AM   #24
davidji
bike curious
Oddometer: 1,045
Whether I need it or not?
Old 07-13-2013, 05:36 AM   #25
gmk999
____ as a Rotax
gmk999's Avatar
Oddometer: 1,015
centrifugal force
I normally lube with Wax or silicone. but to clean I use spin off lube (the type for dirt bikes) and run a few hot miles on the highway. When i get back the thin shines like a diamond in a goats ass. A quick wipe down with a rag and back to the wax.
I do tho use the carwash pressure washer to get the spun-off lube from my shock, fender and roller plate.
BTW.. I have wasted a chain with a Pressure washer.. but i was being overly stupid with it on a cheap o ring chain.. It put a "bind"-section in the chain that was so bad the tire almost locked up when it got to the front sprocket.. I thought it was a wheel bearing .
I sprayed so close that it split a section of 4-5 o-rings and then let it sit wet for a week before i lubed /rode again.
I still have the piece of chain on my wall as a reminder.
Peace
gmk999 is offline   Reply With Quote
Old 07-13-2013, 06:28 AM   #26
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,333
On a warm chain rght after riding:
Spray on Maxima chain wax on the section of exposed chain, then scrub/wipe off excess with a rag. Rotate rear wheel to move chain to new section, then rinse and repeat. I never really "clean" the chain; the wipe down with the rag pulls off most of the worse mess. Then I won't ride the bike until the wax has had several hours to set up.
I got 22K out of my last chain with this method, and the chain could have gone longer. I only replaced it because it was getting noisy and starting to vibrate more -- it wasn't stretched to the limit and it had no stiff links.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 07-13-2013, 06:29 AM   #27
bradluke0
Oddometer: 220
Hi all ! We never clean our chains because they never get dirty . We are in the dry lube camp . Those sticky commercial chain lubes just collect dirt and make a nice grinding paste for your chain . We put brand new chains and sprockets on both our 450's about a year ago . We have adjusted the chains only once and that was only 2 points ( a third of one turn) .
bradluke0 is offline   Reply With Quote
Old 07-17-2013, 03:38 AM   #28
henshao
Bained
henshao's Avatar
Oddometer: 607
Wink
I never clean my chain. It's on the inside.
henshao is offline   Reply With Quote
Old 07-17-2013, 03:50 AM   #29
PeterW
Oddometer: 2,696
Wipe the dirt off now and then with a paper towel.
Chain oiler, any dirt isn't hanging on that hard so a wipe does it.
Pete
PeterW is online now   Reply With Quote
Old 07-17-2013, 05:50 AM   #30
Twinz
Twinz's Avatar
Oddometer: 542
Clean occasionally with kerosene on a rag. Mostly lube with my last can of DuPont teflon dry lube using a Grease Ninja to ensure the lube goes where I want it to go:
Twinz, Montpelier, VT
04 aprilia Futura, Ash Black - love it!
Gone but not forgotten:
'94 R1100RS, '84 R100CS, '76 R75/6 (S fairing)
'80 Guzzi V50 II, '73 Guzzi V7 Sport
Twinz is online now   Reply With Quote
Times are GMT -7.   It's 06:30 PM.
