Old 07-16-2013, 11:55 AM   #31
baachor OP
Oddometer: 65
Originally Posted by sintax View Post
Just one more thing i'd like to add to this....
If the gas in the tank is older than 2 weeks, just drain it and put it into your car.
I just spent about 8 hrs troubleshooting a similar problem, bike just ran shitty. Did the same drill I sent you to do 2 times.
Ended up being 4 week old gas.... Bike would hardly run on it. Drained, put fresh fuel in and it ran great.
Life lessons folks.
That's good to know sintax,will do that as it has been in there for while. I remember advice from one guy I was test-riding his bike,he said he always drain carb with screw on the bottom.
Thanx
Originally Posted by Sean-0 View Post
adjust your float level to 18mm 16mm is not enough .......its common knowledge
Sean-0,
what's the difference? My bike is running fine now on 16mm.
baachor screwed with this post 07-16-2013 at 11:57 AM Reason: add
baachor is offline   Reply With Quote
Old 07-16-2013, 02:06 PM   #32
sintax
Oddometer: 495
I see the 18mm might allow for a little better MPG since the bowl would be a little less full and experience less spillage out of the overflow. Maybe someone will chime in that is more experienced than myself. I'd say on a 1-10 carb rating, i'd give myself a 6.
sintax is offline   Reply With Quote
Old 07-16-2013, 06:52 PM   #33
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,436
Yes better mpg less chance of overflow. There are oyher reasons im sure. All I know is the guru's say to set it at 18mm
Sent from my phone while swerving over the road in my car
Sean-0 is online now   Reply With Quote
Old 07-18-2013, 03:27 PM   #34
baachor OP
Oddometer: 65
Thanks Sean-0
Found this video on how to adjust the float as I had no clue
Old 07-18-2013, 03:31 PM   #35
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,436
Thats the 1.....the guru of the xrr
Times are GMT -7.   It's 10:09 PM.
