Old 07-12-2013, 07:34 AM   #1
True North OP
True North's Avatar
Oddometer: 20
Thumbs down broken 276
Can a 276 with a broken screen be repaired? Garmin no longer does it.
True North is offline   Reply With Quote
Old 07-12-2013, 10:51 AM   #2
sintax
Oddometer: 495
I've not been inside of one of those units, but i'm guessing its just a ribbon cable to a mainboard. Maybe if you find a replacement screen, or buy a junked unit with a good screen you could swap em?
I dont think it could get anymore broken? Give it a shot.
Worse comes to worse, pre-order a Garmin Monterra
sintax is offline   Reply With Quote
Old 07-13-2013, 03:23 AM   #3
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,329
If you can find the parts, you could repair it.
Look at the thread on how to replace the internal battery for instructions on how to disassemble the unit.
Don't quite know what you mean by broken screen. If you are talking broken glass, that might be easier to source than the LCD. I'm trying to remember if someone at some point found a source for the glass and the display, but I couldn't find the reference.
dunno.....
Old 07-15-2013, 01:10 PM   #4
True North OP
True North's Avatar
Oddometer: 20
Both the LCD and glass are broken. I replaced it with a Montana but hate to see a 276 die.
Old 08-04-2013, 10:08 AM   #5
mexipike
Oddometer: 420
screen swap
I had a BmW nav I or II i don't recall. I think it was the garmin streetpilot 2610 or something. I bought one off ebay for like 20 bucks and swapped the screen. I posted a thread here but no one had any tips so I just did it. Took me about a half hour and everything was straight forward. I am not an "electronics guy" or anything like that and I found it easy. Just do it.
mexipike is offline   Reply With Quote
Old 08-04-2013, 11:41 PM   #6
Bengt Phorks
Oddometer: 255
Here is a place that will fix it: http://satnavrepairservice.com/repai...pair/1523.html.
Ebay has parts for it too.
http://www.ebay.com/itm/GLASS-Garmin...-/261111713212
http://www.ebay.com/sch/garmin_parts...rksid=p2047675
Keep it if you can, it is a good GPS.
Bengt Phorks is offline   Reply With Quote
Old 08-08-2013, 07:01 PM   #7
Ride4Coffee
Ride4Coffee's Avatar
Oddometer: 211
Try portatronics
I just sent my broken 376c to portatronics in NY.
They may be able to fix it. However, YMMV.
In my case, they said that, since everything else was working fine, it must be the motherboard, which they can replace for $640. I respectfully declined and asked for it to be sent back.
And a-shopping I go....
IBA# 57940
Need the 90mm bolt for your Kaoko?
Ride4Coffee is offline   Reply With Quote
HTML code is Off
Times are GMT -7.   It's 05:06 AM.
