Old 07-12-2013, 08:06 PM   #1
garabato25 OP
garabato25's Avatar
Oddometer: 90
F800GS + Twalcom Racing Triple Clamp Kit = MotoPorn :)
Hey Guys and Gals,
Just got in the Twalcom Triple Clamp racing kit for my F800GS Trophy. All I have to say is that this is some serious sexy artwork...magnificent quality and the fit and finish is superb.....worth every penny...
I started the install tonite and am 90% complete. Im missing some DOT4 brake fluid and then I have to put all the plastics back on. I took advantage to convert to a high fender setup with new stainless steel brake lines and mx style fork guards. Here are a few pics for tonites install...enjoy!!! I will post more pics tomorrow :)
Cheers
Alex
Xplor the world....One ride at a time....Reflective Decals www.photobucket.com/arwdesigns_decals
2012 F800GS Trophy
2008 R1200GS Adventure - Magma Red :)...SOLD
BMWMOA # 138991
garabato25 is offline   Reply With Quote
Old 07-14-2013, 07:14 AM   #2
Grits&Gravy
Grits&Gravy's Avatar
Oddometer: 347
That triple looks nice. May I ask why you wanted to switch it out, or what the benefits of changing it are?
Can you please share more details about your brake lines such as manufacturer, part no's, lengths, and who you ordered them from? Also what fork guards you are using and what you are going to use to help guide the brake lines up the forks?
More pics and details please.
Thanks for sharing this info. It helps all of us other wannabe's
Grits&Gravy screwed with this post 07-14-2013 at 07:20 AM
Grits&Gravy is offline   Reply With Quote
Old 07-16-2013, 07:09 AM   #3
dsauer
Oddometer: 152
What grits said....
Deb
Golden, CO
dsauer is offline   Reply With Quote
Old 07-16-2013, 08:00 AM   #4
garabato25 OP
garabato25's Avatar
Oddometer: 90
Laugh
Hey buddy,
The reason I changed it out was a tree jumped out in front of me and well you can just imagine the rest...I was in the sand, very technical trail and was probably going a little too fast....
The brake lines I had made at my local shop for $102.00. I got 2 42" main lines which had a 1/4" SS tube inserted over them before the ends were put on to keep them straight along the forks which also helps them keep out of the way. On the top of the forks, I have a loop in place to make sure they stay straight. The fork guards are off a Kawi 450 dirt bike that I modified to fit the bottom mounting points...Formed them with a torch and reinserted the metal inserts to avoid crushing the plastic, they were $35.
The triple clamps all in all were about $650 so in total I only have about $800 bux in the whole project...the OEM triple clamp costs +/- $1300 so this was a no brainer.....Easy to install the Twalcom kit as it is a direct replacement plus it looks a lot better. Its also stronger and lighter!!!!
A lot of these ideas I got from GPRACER171 and you can see his thread here http://advrider.com/forums/showthread.php?t=580958.
Let me know if you guys have any more questions. I will post final pics as soon as I can....damn thing called work always gets in my way....
Cheers
Alex
2012 F800GS Trophy
BMWMOA # 138991
garabato25 screwed with this post 07-16-2013 at 08:07 AM
Old 07-24-2014, 11:58 AM   #5
mapuda
Crash Tested
mapuda's Avatar
Oddometer: 268
Alex,
I am thinking of ordering one of these trees but I have the Scott's dampener and it is a solid plate that bolts up to the stock riser holes in the top tree. Are the dimensions of the distance between the riser holes in the Kite tree the same as stock?
Thanks,
Mike
Anger makes you stupid and stupid gets you killed.
-Michonne
mapuda is offline   Reply With Quote
Old 07-27-2014, 05:53 PM   #6
Mr B
Mr B's Avatar
Oddometer: 493
How about that front fender, is that a Kawa too? And did you keep the brake line loop on the bottom, or run two lines, one on each leg,. Looks like you kept the jumper hyd line.
Looks real nice, am wanting to get my fender up out of the way but just can't seem to get permission to spend any money lately!
Interested in that triple tree too, looks stronger for sure.
"For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return."
Leonardo da Vinci[/FONT]
Mr B is offline   Reply With Quote
Times are GMT -7.   It's 09:50 AM.
