Old 07-15-2013, 02:55 PM   #1
Full Power OP
Oddometer: 1,481
Extra Electrons
How much EXTRA DC auxiliary power is available, on the F8 , over and above the
"Base Load" of fuel pump, ignition, and LOW beam headlamp ?
I have no hard numbers, but I can confirm that my F800 will support TWO electric vests, grip heat, and HIGH beam for 24 hours straight, no problem..
My question pertains to auxiliary lighting, an I wonder if I can run a pair of 55 watt H3 Piaa lamps, in addition to the 'normal' touring loads.
. The owners manual spec of " 400 watts " alternator output means exactly nothing, as no net machine load is specified.
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Old 07-15-2013, 05:20 PM   #2
sturgeon
sturgeon's Avatar
Oddometer: 943
JoelWisman posted the results of some testing he did. It's around here somewhere. Search around.
Dyslexics untie!
Dyslexics Untie!
sturgeon is offline   Reply With Quote
Old 07-16-2013, 05:19 AM   #3
JRWooden
Oddometer: 4,267
The link I saved to the post no longer works,
but I believe his post is in this thread...
http://www.advrider.com/forums/showthread.php?t=395505
Here's a repost: http://advrider.com/forums/showpost....1&postcount=61
The rough answer is that (screaming down the highway) you have something like 130 watts to mess with...
plus another 50 watts if you don't run your hi-beam,
plus another 45 watts if you don't run (or don't have) the heated grips.
I would strongly recommend investing in one of the voltage monitoring gadgets since it varies with engine RPM and the charging system on the older models is not so great ... etc...
JRWooden screwed with this post 07-16-2013 at 05:25 AM
Old 09-10-2013, 02:24 PM   #4
Full Power OP
Oddometer: 1,481
I can confirm that F800GS WILL run TWO electric heated vests, Highbeam , pair of AUX lights, and heated grips on HIGH setting, for 800 miles, in the rain.
Old 09-10-2013, 04:45 PM   #5
TowPro
Lets ride
Oddometer: 3,223
Originally Posted by Full Power View Post
My question pertains to auxiliary lighting, an I wonder if I can run a pair of 55 watt H3 Piaa lamps, in addition to the 'normal' touring loads..
I would look into LED over the old fashioned H3 stuff :). Plus they are smaller. You can get them in everything from Wide flood to pencil beam spots.
your looking at maybe 10W for LED instead of 110w for the pair of H3's.
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 09-14-2013, 08:23 AM   #6
Nacho911
Nacho911's Avatar
Oddometer: 463
Buy Rigid lights. Super tough, and LED. Uses very very little power
Nacho911
Nacho911 is offline   Reply With Quote
Times are GMT -7.   It's 06:07 AM.
