Old 07-15-2013, 05:41 PM   #1
Philthy! OP
Gravity Tester
Philthy!'s Avatar
Oddometer: 5
Superlite rear sprocket
Installed a new chain and sprocket kit on the 800. Used DID chain and Superlite sprockets front and rear. The front is a beautiful piece and fit perfectly. The rear is nice too. I weighed it and it's 1.3 lb vs. the stock 1.1 lb. So much for Superlite. It is black though .
Compared to most bikes, the GS has a fairly large diameter bolt spread, so weight savings aren't going to be too big for any sprocket.
Thought I would post this in case anyone was curious about the Superlites.
Philthy! is offline   Reply With Quote
Old 07-17-2013, 11:43 AM   #2
Calgary06
Calgary06's Avatar
Oddometer: 161
Did you go with the stock number of teeth?
I am about to bite the bullet and order me a set as well but was thinking 45/16 ratio.
(pic?)
EEUC
Calgary06 is offline   Reply With Quote
Times are GMT -7.   It's 01:39 AM.
