Old 07-16-2013, 07:07 AM   #1
RedRupert OP
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 581
Piston Removal - why this advice please?
Please can someone explain to me why KTM say this in their Repair Manual:
! CAUTION !
– DO NOT PULL THE PISTON OUT OF THE CYLINDER UP TO THE OIL SCRAPER RING
SINCE THE PISTON RING WILL BE DAMAGED BY THE LOWER EDGE OF THE CYLINDER.
I have never come across this with other motorcycles.
I can't see any way that the ring(s) can be damaged if the piston is removed from the bottom of the cylinder. There is a sharp taper at the very bottom of the cylinder, but that can only help, not hinder.
I can't see any damage to the rings after removing the piston downwards.
Thanks.
Rupert
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 07-16-2013, 09:03 AM   #2
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,126
I follow the manual on this but also have no clue. Mounting with the piston already in the bore makes it real easy though!
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 07-16-2013, 11:54 AM   #3
RedRupert OP
RedRupert's Avatar
Oddometer: 581
It's true, but I needed to replace a valve-stem oil seal. The cylinders were off, so I'd rather remove the piston than disturb the expensive head gasket.
Yamaha WR 450 F
Old 07-16-2013, 03:42 PM   #4
CRW
I dont want a pickle
CRW's Avatar
Oddometer: 754
it can be done just be careful, there is a chance of damaging a ring. I have done it but installed new rings prior to assembly.
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
CRW is online now   Reply With Quote
Old 07-17-2013, 02:18 AM   #5
RedRupert OP
RedRupert's Avatar
Oddometer: 581
What should one be careful of exactly - I mean compared with any other engine?
Yamaha WR 450 F
Old 07-17-2013, 04:59 AM   #6
charlie264
charlie264's Avatar
Oddometer: 8,258
Just leave the pistons in the bores if you can get to the gudgeon pin ....pop um out from top.
Old 07-17-2013, 05:19 AM   #7
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,126
I understand you want to leave the head gasket alone. My valvespringcompressortool won't reach with the cyllinder attached though, I think its gonna be much easyer to just spend the dough..
Old 07-17-2013, 07:44 AM   #8
RedRupert OP
RedRupert's Avatar
Oddometer: 581
I have already done the work - I used a large plug in the cylinder to hold the valves shut while I used a standard valve-spring compressor (against the plug and the valve springs). It was easy and well worth doing in order to save having to spend 80 on head gaskets.
My question was: why should the piston not be removed from the bottom of the cylinder. I can't understand how the rings can be damaged by doing so.
Sometimes the English version of the Repair Manual is poor. Do you speak/read German - if so, does it read the same in German?
Thanks, Rupert
Yamaha WR 450 F
Old 07-17-2013, 11:27 AM   #9
CRW
CRW's Avatar
Oddometer: 754
I think there is a possibility of snagging a ring upon removal. With two sets of hands assembly is easy. If you are carful should be fine. I did this when I swamped cases due to cracked cases. Then blew a head gasket 4000 miles later. Might be worth cracking the heads just for peace of mind.....
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
Old 07-17-2013, 02:56 PM   #10
mbrick
Oddometer: 126
Funny you brought this up. I was also puzzled by the 690 manual talking about only sliding it down enough to remove the wrist pin, then taking it out the top of the bore.
Is it possible the ring can be damaged because it doesn't jump out of the cylinder on the entire circumference all at once? (There are the 2 areas that extend further down into the lower case on the front and back). Really reaching here though.
mbrick is offline   Reply With Quote
Old 07-17-2013, 11:20 PM   #11
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,982
You might scratch the face of the rings on the bottom of the cylinder. KTM removes and installs the piston from the top.
Much easier to keep it in the cylinder and pull the piston pin.
Good luck on putting the pin keeper back in, they are really stiff. There is a special tool that makes this a breeze. Without it I've had the best luck using a small screw driver to pry it back in.
"Son, you can't do both"
Old 07-18-2013, 12:20 AM   #12
mbrick
Oddometer: 126
Mocking it up I actually noticed how stiff it was and how tough it will be.
Do you happen to have a photo of the tool? I can't quite see the end of it in the photo in the service manual to see how it works.
Thought about making a bore and inserting it inside the bore, then "knocking" it through into the opening on the side of the piston.
Old 07-18-2013, 05:55 AM   #13
RedRupert OP
RedRupert's Avatar
Oddometer: 581
How to install the piston circlips
You say 'back in' do you re-use them?
I've installed LC8 piston circlips (pin keepers) several times. There is no need for a special tool, as it's a breeze when you know how. This is how it's done:
1) Locate the tail of the clip into the notch in the piston: 'A' below.
2) Support the clip with your left thumb - applying a little pressure towards the centre and towards the piston pin - at point 'B'.
3) Use a stick or rod to gently push the circlip towards the piston pin, starting just to the right of point '1' and working CCW, do the same at points '2' and '3'. Take it easy - it's similar to fitting a tyre - the last bit just slips in and snaps into place.
I use a hardwood dowel, about 8mm in diameter and 100mm in length - there is no danger of fragments splintering off and getting into the engine. Perhaps better would be a soft aluminium, bronze, brass or copper rod - whatever you use, it needs a square-cut end i.e. not rounded so that it slips. A screwdriver is too aggressive, and may damage the clip seat or leave marks on the piston if it slips.
I recommend you practice using an old/used circlip - then install a new clip when you've sussed it.
Yamaha WR 450 F
RedRupert screwed with this post 07-18-2013 at 06:11 AM
Old 07-18-2013, 01:54 PM   #14
dmn0507
dmn0507's Avatar
Oddometer: 352
If You are going to follow the manual (install from top) you need a ring compressor, otherwise a piece of plastic is enopugh to work your way in little by little.
dmn0507 is offline   Reply With Quote
Old 07-19-2013, 06:28 AM   #15
RedRupert OP
RedRupert's Avatar
Oddometer: 581
Thanks, but a ring compressor is not needed whether inserting the piston in from the top or bottom - it's quite easy and safe to insert a single piston into a single cylinder, specially when on the bench. I know KTM recommend it, but it's not imperative.
It's one of the reasons I asked the question in post #1 of this thread - why can't one remove the piston from the bottom of the cylinder - is it imperative or just good practise or recommended.
Yamaha WR 450 F
Times are GMT -7.   It's 05:02 PM.
