Old 07-05-2013, 08:49 PM   #1
RallyeX OP
Oddometer: 175
Started upgrading my new 2013 Adventure
Well I started adding a few things to the bike this week. I have the Touratech front brake and clutch reservoir guards, fuel injector guards, oil cooler guard, and the Cockpit Cover 2, Cig +BMW socket. Also installed a Saddlemen Track seat with heat front and rear. Also had them leave off the d-rings and flap. Also a cheap cover to use at work! Oh and a set of Bikemaster billet mirrors.
Also installed the BMW aluminum side cases and top case. When I bought the bike there was a miss understanding about the free cases. They took care of it and got me the cases.
Next I will be ordering a Garmin 665 and mount.
RallyeX screwed with this post 07-05-2013 at 09:05 PM
RallyeX is offline   Reply With Quote
Old 07-05-2013, 09:58 PM   #2
Mangiacavallo
Oddometer: 19
nice!
how hard was it to install that cockpit cover II? i have one & am waiting to do the install. were the instructions clear enough to do it from them, or did you need to improvise anything yourself? did you pull the tank off to do it? anything i should pay special attention to?
just curious before i start in on that project.
many thanks.
Mangiacavallo is offline   Reply With Quote
Old 07-05-2013, 10:22 PM   #3
JM
JM's Avatar
Oddometer: 783
Did you get a top case in the deal free also? Did you have to pay for locks or mounts for the free cases deal?
I only got the two side cases with locks for free.
John
Postponing retirement one farkle at a time!
JM is offline   Reply With Quote
Old 07-06-2013, 04:08 PM   #4
RallyeX OP
Oddometer: 175
Originally Posted by Mangiacavallo View Post
nice!
many thanks.
I followed the instructions pretty much. I removed the hole head light to get to the screws on the side of wind screen frame that the new dash mounts to. The 3 clips on the back of the tach are kind of a pain. I have a stick magnet that is .250 dia and about 6.0 long. That made it a lot easier to push the clips back on. Also the knobs that you use to adjust the wind screen have a nut on the back side. Once you remove the nut there is a threaded guide with flats on each side. Those will fall if you are not paying attention.
It's not bad to do.
RallyeX
Old 07-06-2013, 04:10 PM   #5
RallyeX OP
Oddometer: 175
I got both side cases and the top case. I had to buy the locks and the mounting bracket for the top case. It says on the BMW web site that you get the 2 side cases and the top case.
RallyeX
Old 07-07-2013, 01:51 PM   #6
Mangiacavallo
Oddometer: 19
thanks for the tips on the install. i look forward to doing this job & will get myself a long magnet to help out!
cheers.
Old 07-14-2013, 09:16 PM   #7
RallyeX OP
Oddometer: 175
I got a Touratech Companero tang bag Saturday.
Old 07-14-2013, 11:19 PM   #8
ricohman
Marinoni man
ricohman's Avatar
Oddometer: 1,981
That suede seat is going to look great after you ride on wet gravel roads. It will never, ever come clean. And if the dirt has red in it then you will probably toss it.
ricohman is offline   Reply With Quote
Old 07-15-2013, 05:03 AM   #9
tom28734
Oddometer: 80
Obviously you are in a money-spending competition. Did you win?
The bike is no better for all that money. It does look good, and you can pose beside it for pictures!
tom28734 is offline   Reply With Quote
Old 07-15-2013, 06:16 AM   #10
JM
JM's Avatar
Oddometer: 783
The things added to this bike all have a function and serve a purpose. It's not like he's adding chrome just to improve the shiny factor.
John
Old 07-15-2013, 08:12 AM   #11
ricohman
Marinoni man
ricohman's Avatar
Oddometer: 1,981
Thats true, but those shields on the clutch and brake serve little function if you crash at speed.
Old 07-15-2013, 08:19 AM   #12
dontlr
Mysterious Chatter
dontlr's Avatar
Oddometer: 2,744
Nice Jeep, I've seen the pictures on Pirate, welcome..
Oh and sweet bike too..
dontlr is offline   Reply With Quote
Old 07-15-2013, 08:34 AM   #13
okennon
Oddometer: 67
OOOOOOhhhhh "a money spending competition" I like that. I lost.
okennon is offline   Reply With Quote
Old 07-15-2013, 08:46 AM   #14
JM
JM's Avatar
Oddometer: 783
Agreed. Not much really helps "if u crash at speed".
All of my GS crashes have happened trying to go slow. Those protection items are designed to help with the low speed get offs that tend to happen off road.
I'd rather spend $500 with Touratech than hand $500 to a tow truck driver because I ripped an item off the bike that's a trip ender.
John
Old 07-15-2013, 09:04 AM   #15
LVGS
LVGS's Avatar
Oddometer: 472
Congratulations, nice bike! Ignore comments like this, it's your money and there is nothing superfluous in what you have added.
LVGS is offline   Reply With Quote
Times are GMT -7.   It's 10:49 PM.
