Old 07-18-2013, 10:08 PM   #1
brucifer OP
brucifer's Avatar
Oddometer: 2,429
What's a Better Sand Bike--CR500 or KX500
Hey guys, I've been toying with the idea of picking up one of these bikes to ride at our local off-road park that is situated on the shore of the Pacific Ocean.
I used to ride out there quite often back in the '80s when you could ride for miles legally but unfortunately the area has been reduced to acreage.
Anyhow I want something fairly light with lots of power to ride with my buddy and his 700 Raptor. Must be cheap and cheap to maintain and I think that pretty much describes both of these 500s.
Probably be looking for a mid '90s up model.
Thanks for any input.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 07-19-2013, 05:32 AM   #2
anotherguy
anotherguy's Avatar
Oddometer: 6,208
Both are beasts with much power. In my experience I've seen more than a few KX500 with 3rd gear issues. Not so many issues on CR500.
you don't see luggage racks on a hearse..........act accordingly
Old 07-19-2013, 11:36 AM   #3
Twin-shocker
Oddometer: 1,673
I would have thought that a bike which is easy to start, might be worth looking at, before opting for a hard to start difficult to ride 500?
Old 07-19-2013, 12:39 PM   #4
PistonPants
Crankcase Scavenger
PistonPants's Avatar
Oddometer: 438
Don't bite at the bait.
PistonPants is offline   Reply With Quote
Old 07-19-2013, 12:57 PM   #5
Twin-shocker
Oddometer: 1,673
You got an easy method to start a 500cc MX bike? None of those I had started that well, and simply cant see the point of having one for playbike use.
Old 07-19-2013, 01:23 PM   #6
brucifer OP
brucifer's Avatar
Oddometer: 2,429
I don't have a problem starting them. Difficult to ride? Fun, I say!
Maybe not so much fun in tight, technical single track but wide open beach and sand dunes? Kick arse!
Now....which is better suited for the sand--the CR or KX??
Old 07-19-2013, 01:25 PM   #7
PistonPants
Crankcase Scavenger
Oddometer: 438
However lots of people do. Like brucifer. His question was pretty specific. Your response had nothing to do with his query. Besides nothing else hits like a 500 2T motocrosser.
Piston
Old 07-19-2013, 01:53 PM   #8
brucifer OP
brucifer's Avatar
Oddometer: 2,429
Piston
And that's what I love about them. They're just such overkill!
Old 07-19-2013, 07:40 PM   #9
bigzack
6'6" of awesome
bigzack's Avatar
Oddometer: 61
I hear they start and run better with Taiwanese Epay carbs, Chinese CDIs and thinned down Autolube oil.
Z
bigzack is offline   Reply With Quote
Old 07-19-2013, 09:07 PM   #10
PistonPants
Crankcase Scavenger
Oddometer: 438
According to your 'internet sources'?
Old 07-19-2013, 09:29 PM   #11
81cr450
Oddometer: 96
I really cant fuckin believe how hard it is for an answer on here, half the replys should just be in the basement
C5 bullet proof & has massive snap, power right now. I LOVE 86's have had 89 90 98 2000 & 2 86's
K5 most power over a broader rpm hands down. My personal only 1 bike pick. A little hinky in some areas like the frame is kinda light duty & they shoulda bolted on gears & sprockets instead of snap rings . But a cylinder replate with a big bore & you'll smoke most anything & has a higher top speed with the powervalve offering a wider spread of power. Get a clean one, low hour , even if it costs a bit more. When the motors done , there done, no quick piston & re-bore like the cr but well worth it. Either bike & you wont be sorry but if you want the fastest go K5. You could also get a ktm500 or 550 2 smoke the mid 90's 550 is sposed to be sweet but never had one yet.
ps you can trail ride a 500 & its easier to ride than a 250 cause they lug, but if you've never tried & are just a doucher on the net...
81cr450 is offline   Reply With Quote
Old 07-20-2013, 06:12 AM   #12
brucifer OP
brucifer's Avatar
Oddometer: 2,429
Good info here. What is it about the '86 CR500 you love?
I'm selling my '84 mainly because this particular bike should have a full restoration but also the appalling design of the kick starter--it's high, short and slams the top of your foot into the foot peg.
Old 07-20-2013, 06:35 AM   #13
Rokoneer
Oddometer: 540
Why screw around with a 500? Bigger is better, and it even has a compression release for 'easy' starting....
Rokoneer is offline   Reply With Quote
Old 07-20-2013, 06:44 AM   #14
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,360
Really can't help you but visions of Danny Hamel kickng ass for team green make me lean toward the KX ... Plus in my neck of the woods the KX seem to be found in better condition for cheaper thn then CR.
JeffS77 is offline   Reply With Quote
Old 07-20-2013, 06:44 AM   #15
brucifer OP
brucifer's Avatar
Oddometer: 2,429
RE: ATK
If I could find one cheap enough! Those things come in 500, 600 and 700cc as I recall.
I remember reading a test on them and the author preferred the 600. Said the 700 was kinda like a diesel and didn't change RPM much.
Times are GMT -7.   It's 05:12 PM.
