Old 04-09-2014, 09:40 AM   #166
KX50002
NooB, my ass
KX50002's Avatar
Oddometer: 1,826
Originally Posted by Rot Box View Post
Looks good Brucifer
Always thought the KX's with blue forks looked cool/unique..
+1 I wish mine had them, I've got old school (right side up??) forks
SOTGMOTT Some Of The Gear Most Of The Time
KX50002 is offline   Reply With Quote
Old 04-24-2014, 07:01 AM   #167
brucifer OP
brucifer's Avatar
Oddometer: 2,460
I got the big, bad KX fired--and immediately shut it down. It was rattling terribly in the top end.
I initially thought it may be a wrist pin because while kicking it over I thought I could feel play somewhere, and when it fired it sounded like it was coming from the top end.
Aahhhhh......no. Of course it's the big end of the rod.
Some piston/cylinder scoring as well.
A few pics.
At least the cylinder has already been sleeved so a minor overbore and piston will take care of that issue without having to send the cylinder out for replating.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 04-27-2014, 03:08 PM   #168
Rot Box
Oddometer: 212
Agh!... That's no good
94 ATK 605DSES - 84 Honda CR500R - 81 Honda XL500S
Rot Box is offline   Reply With Quote
Old 06-09-2014, 07:17 PM   #169
brucifer OP
brucifer's Avatar
Oddometer: 2,460
Originally Posted by zokalr13 View Post
Sooo hows the KX motor coming along?? yeah,yeah I know,side-trakked again... I thought my 91 CR500 needed a rebore- and I already have a 89.5 mm pro x piston kit- but to my dismay today I found out my cylinder is at 90.25 a [1.25 overbore] so I am selling the 89.5 piston kit and will just buy some new rings hopefully and then reuse the piston that I cleaned up [ carbon removal is when I noticed the 125 stamped on the piston] also a parts bike has sprung up locally so I will get some susp. parts and a carb hopefully.. this farkin bike will run .........
Do I detect a hint of sarcasm here?
I'm actually making some progress on the KX. I purchased everything I need for a complete crank and top end rebuild (hopefully), but I haven't split the cases yet--who knows what may be waiting inside.
I went ahead and stripped the bike completely and am going to get the frame, sub frame and foot peg bracket powder coated.
Here's what the bike looks like now.
Old 06-10-2014, 04:30 PM   #170
zokalr13
zokalr13's Avatar
Oddometer: 413
good on you then-I hope you can put it all back together without adding a few extra parts there,eh.. I just came back from the shop and they checked my cylinder and it is NFG so I have to rebore and then get a 90.50mm size piston kit ...so another delay what color are you gonna paint the frame? that green is hard to get touch up paint for...
zokalr13 is offline   Reply With Quote
Old 06-10-2014, 05:48 PM   #171
brucifer OP
brucifer's Avatar
Oddometer: 2,460
Gonna stick with the factory green--I really like that color.
Well that sucks about your cylinder. At least that's all that's wrong with it but the delays get old I know.
Old 07-16-2014, 06:06 PM   #172
zokalr13
zokalr13's Avatar
Oddometer: 413
half ways finished
my 91 CR500 is half ways finished ,new bore job, new cyl head, frame painted, swing arm polished -just needs a few finishes ,like crank seals and I need to buy a white aftermarket gas tank and rad shrouds .hows the KX coming along??
Old 07-17-2014, 07:03 PM   #173
Rd650
Rd650's Avatar
Oddometer: 238
Going to have to go with the KX500 just because I got one and am jealous of those great looking CR500's Keep those build pictures coming, of both red and green bikes.
Rd650 is offline   Reply With Quote
Old 07-17-2014, 07:21 PM   #174
brucifer OP
brucifer's Avatar
Oddometer: 2,460
Looking good, Z! Mines at a standstill. My plated XR600 I recently built quit shifting so I'm in the process of splitting the cases on it.
Rd650- I'll try to get some build pics here but so far the Z-man's smokin' me.
Old 08-03-2014, 09:21 AM   #175
brucifer OP
brucifer's Avatar
Oddometer: 2,460
Nice!
Old 08-05-2014, 07:03 PM   #176
zokalr13
zokalr13's Avatar
Oddometer: 413
@%$&!! needs more work on the ignition side of things as the spark was weak.replaced coil.now I gotta get the FWW removed and rotor taken off to replace the seal too...has low compression as well due to @%$^!! piston and ring job -Ive given up and now its for sale....
zokalr13 screwed with this post 10-10-2014 at 02:01 PM
Old 10-27-2014, 08:25 AM   #177
BikePilot
BikePilot's Avatar
Oddometer: 11,251
For sand I'd take the KX500 for the better motor. The CR500s have a bit better handling though.
FWIW The '87-88 CR500 made massive power with a really meaty, tractable mid-range, but were somewhat hard to start. My 1991 felt much ligher, quicker and higher revving, easier to start, and less midrange grunt. My dad's 1993 (and they really didn't change much from then to end of production) was somewhere in between. The 1991 also had a bit more ridged chassis than the later models. Overall the 1991 is my favorite year for the CR500. The suspension is even quite good once you work it over. All years have issues cracking pistons. A forged wiseco goes a long way and I'm told head work makes a big difference also.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 12-23-2014, 12:06 PM   #178
brucifer OP
brucifer's Avatar
Oddometer: 2,460
Dropped the frame, sub-frame and foot peg mount off at the powder coater this morning.
Finally some forward movement.
Old 01-04-2015, 05:13 PM   #179
Kevin K
Oddometer: 61
finally finished the 500!! hope it starts sunday ..still needs a few things like white tank- new seat cover- red sliders-but good 2 go..
No way, your Honda looks perfect to me. No white tank or anything needed. Maybe at most a set cover in a black gripper or something.
Kevin K is offline   Reply With Quote
Old 03-09-2015, 06:50 PM   #180
brucifer OP
brucifer's Avatar
Oddometer: 2,460
Frame parts done. Forks rebuilt.
Sorry for the fuzzy pic.
This is going to a while as I'm working on 3 bikes at the same time.
Times are GMT -7.   It's 12:01 AM.
