Old 07-19-2013, 08:40 AM   #1
Alleycatdad OP
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Handlebars
Ok gang,
I replaced my stock bars a while ago with CR high bars and am much happier, but there's an issue. The straight (handgrip) portion of the bars is too short to accommodate the heated grips (can't cut 'em!), the switchgear, and the master cylinder clamps. Right now I've got some homemade extenders supporting my handguards, but if it hits hard there's gonna be more damage than I may be able to repair trailside.
Any suggestions for similar-bend bars with longer handgrip portions? Specific brands, bends, etc are welcome...
Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 07-19-2013, 05:37 PM   #2
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
Originally Posted by Alleycatdad View Post
Ok gang,
Steve
I have the CR high bars as well. The bend was an issue for me as well but I cut off part of the heated grips and added a short spacer in the throttle tube along with a kaoko throttle lock (for these long boring freeway rides you sometimes have to take to get to good dirt)
Other than that, I love the bars
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 07-19-2013, 06:12 PM   #3
DuctTape
Oddometer: 351
You can safely cut this much from the KTM heated grips.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 07-20-2013, 07:43 AM   #4
ABuck99
0.0
ABuck99's Avatar
Oddometer: 609
Renthal Fatbar RC High (#609)- have little a narrower clamp area, which gives more area between the bend and the end of the bars for accessories ect. compared to CR high
Ok gang,
Steve
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 07-20-2013, 09:18 AM   #5
KTMbageera
Oddometer: 89
FLEXX enduro 14 degree bars have room and save your joints. They cost more because they are more.
R tank bag
KTMbageera is offline   Reply With Quote
Old 07-20-2013, 08:20 PM   #6
DirtJack
DirtJack's Avatar
Oddometer: 1,597
Ditto, I had a similar problem in that I had HDB hand guards, Kaoko, and G2 throttle tube which limited grip length. Solution: cut end off KTM heated grips. The bar is a ProTaper Kevin Windom High bend. Didn't like the stock sweep back. This bar is higher, wider and straighter. Like it a lot.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 07-20-2013, 09:55 PM   #7
DuctTape
Oddometer: 351
R tank bag
I have the Enduro 12 on both my 990 and 690 and the difference in how you feel at the end of the ride is just amazing and worth every $$. The nice thing is the ability to actually add shims to raise the bar height.
I just love these bars!
2010 Ducati 1198S
Old 07-22-2013, 07:39 AM   #8
Alleycatdad OP
Oddometer: 1,439
This is really helpful!
SA
Old 07-22-2013, 02:37 PM   #9
Stephen
Stephen's Avatar
Oddometer: 3,194
Pro Taper KX High are higher and wider than stock, flat and straight. Plenty of room at the ends.
A little more sweep than Magura SX (which are damn near straight tubes), but a lot less than stock or CR.
Pretty sure they're taller than the Kevin Windham.
Can't take pics just now, but will later if you like.
Stephen is online now   Reply With Quote
Old 07-23-2013, 08:01 AM   #10
DirtJack
DirtJack's Avatar
Oddometer: 1,597
Cycle Gear didn't have that one in stock when I went by. The limiting thing in my setup was the G2 throttle tube not being long enough. Usually you use a spacer on that end, but because I run the Kaoko that wasn't possible. I use the Kaoko primarily to put slight tension on the throttle to remove jerky movement at low speed on dirt. It's great to have when slabbing it also.
2008 KTM 690 Enduro
Old 07-23-2013, 10:12 AM   #11
charlie264
charlie264's Avatar
Oddometer: 8,318
How does that work with HDB guards?
Old 07-25-2013, 01:51 AM   #12
Bowser
Oddometer: 168
got to ask, what make of tank bag is that? sorry to hijack the thread
Bowser is offline   Reply With Quote
Old 07-25-2013, 07:03 AM   #13
DirtJack
DirtJack's Avatar
Oddometer: 1,597
I'm having trouble visualizing how the pivot action of the bar ends affects the rather rigid HDB guards too.
2008 KTM 690 Enduro
Old 08-02-2013, 11:52 AM   #14
charlie264
charlie264's Avatar
Oddometer: 8,318
Ally does flex.....but kinda defeats the purpose of the bars...
Old 09-10-2013, 04:40 PM   #15
Zander
Zander's Avatar
Oddometer: 194
I currently have a Rally Connex riser installed and I am looking for a handlebar same height or close to stock but with a lot less sweep back than stock. Any advise ?
Beginner's mind !
KTM 950
Zander is offline   Reply With Quote
Times are GMT -7.   It's 02:42 PM.
