Old 07-20-2013, 05:21 PM   #1
Dagwood_55 OP
Dagwood_55's Avatar
Oddometer: 1,347
Need Ideas for Wiring HDB Switches...
I've had the HDB handguards with the mirrors and the top clamp with 4 switches and LED lights on the bottom and 2 on top for a year or so. HDB hadguards are the best IMO.
So, on top is a plug for my heated gear and a light switch for my BD lights, all plug n play and looks good.
And on the bottom are the HDB switches and LED lights for my GPS and my HT radio.
All works well, but the problem is: The wiring to the bottom switches/LED is a rats nest. I started in today trying to clean it up, using nylon wire sheathing (think Chinese handcuffs) and heat shrink tubing. Finally got it all back together and it looks much better. Then when buttoning it back up, I pull out one of the little LED wires. So, since I was using heat shrink, its a major undertaking to replace just one part. Arrrrggggg!!!
So, before I redo it, I'm rethinking in master plan. Thinking about some kind of plug to run the little wires to. A plug you could just snap the little wires into, or possibly soilder them into.
But I don't have a clue whats out there to use or get. Any of you techy types got any ideas or a different idea on how to easily clean this mess up??? And make it easier to repair or replace a part/switch/LED??
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is online now   Reply With Quote
Old 07-21-2013, 04:23 PM   #2
DirtJack
DirtJack's Avatar
Oddometer: 1,600
I agree that wiring is a problem for the HDB which puts switches on the handlebar top clamp. Convenient, yes; a pain the ass to wire. Here is my setup on a KTM 990 Adventure.
Left to right the 4 switches are Rigid LED lights, Switched GPS circuit, Multicolor LED Voltmeter, and ABS Default (on or off).
Each of these switch/LED pairs has plug connections to Y's which are plugged into either the KTM ACC1 or ACC2 connections on the wiring harness. My first attempt at wiring this is shown below.
The switch wires and LED wires are individually shrink wrapped for a few inches and then each pair is enclosed in a larger shrink wrap which was heated only at the start leaving an unshrunk tube to run to the plug location behind the dash. Semi messy, but not too bad.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 07-22-2013, 11:43 AM   #3
theantipaul
Reforming Neandertal
theantipaul's Avatar
Oddometer: 1,191
Hi All, been meaning to do a little writeup just for guys to see how we do it here and this ends up being perfect timing as the kid wanted to run some BD LEDs, that meant a complete rewire of his WR400.
After hearing of this thread, this morning I came in and started, this is by no means the only way, but after trying to fit it as many components as possible into as small as possible an area I had to be pretty clean with the install to make it all work.
I start with super gluing the LEDs in place,
Then bunching up all the LED ground wires, here's a tip that I do all throughout wiring pretty much everything, I use the heat gun to soften all the wires/shrink tubing so that I can make it take a set when it cools, strip them all and solder to a ground bus.
Then do the same with one side of each switch, this will be our 12v bus, to keep everything neat and in place I use a twist tie, it's also important to disturb the LEDs as little as possible throughout the project.
Next is to cut and strip the accessory side of each switch and indicator LED, I cut/strip the the LED side longer for my fat fingers to grab hold of and twist around the switch side.
Then solder in the 4 12v out wires,
This is where I usually test to see where I'm at and if any of the LEDs have failed or pulled out,
With all good I shrink tube up those ends,
start bundling for bringing the wires out together and shrink tube them together, note the set after warming up,
Prep the mesh by melting the cut ends together, something I do here is try to melt a lip so that after the shrink tube melts over it it'll make it harder to pull out,
Then use glue shrink tube for this part so the mesh stays put, also note the set in the shrink tube,
Last thing I do is pump silicone in down around as much of the wiring and LEDs as I can, this is the one place I cheat and pry the wires a little to get good penetration.
All that's left is the connector, also when everything is in place I heat up any wires/shrink tube that is in an awkward place and move it while it's warm to take a set for where it eventually will live.
Let me know if you have any questions, please keep in mind, this is just the way we've taken to doing it here.
Thanks,
Paul from HDB
degarate@highwaydirtbikes.com
Man lived, Man suffered, Man died
theantipaul is offline   Reply With Quote
Old 07-22-2013, 02:41 PM   #4
Dagwood_55 OP
Dagwood_55's Avatar
Oddometer: 1,347
Thanks Paul, now that was what I'm looking for!! In fact I had thought of calling you, but did'nt.
And you sure are right, don't take much to upset the little LED's. I've got mine all apart now and I'm doing it the same way as you show here. And I'm sure I'll have a question or two.
Old 07-22-2013, 02:48 PM   #5
theantipaul
Oddometer: 1,191
We're doing shipping right now, if you need more prewired LEDs or anything else PM me,
Paul
Old 07-22-2013, 02:55 PM   #6
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,509
Personally, I find those LEDs way too bright for night time. I ganged together all of the LED grounds and run them thru a switched connection to a 22k resistor. I use the switch to dim all of the LEDs at the same time. Even with daytime lighting mode, I still add an additional 1k Ohm to the ground circuit.
I wired my switches & LEDs into the 990 dash to avoid having to mess with them when I pull the bars or triple clamps apart. It also makes them more visible when riding.
Upper right switch is headlight. Just below that is the LED light switch. At the lower right is the dimmer switch.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle screwed with this post 07-22-2013 at 03:44 PM
HellSickle is offline   Reply With Quote
Old 07-22-2013, 03:19 PM   #7
Dagwood_55 OP
Dagwood_55's Avatar
Oddometer: 1,347
You're right about them being bright at nite. I rarely ride at nite, too many deer around here, but if I do, I put a piece of tape over them. The risistor idea sounds good though. You just wire the risistor in line??
Old 07-22-2013, 03:42 PM   #8
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,509
You can zoom in on the diagram in the photo. See the switch that toggles the ground line. When the switch is open, all the ground current has to flow thru a 22k resistor. When the switch is closed, the current goes thru a 22k/1k parallel combination (~950 Ohm equivalent).
LEDs are essentially a current device. Brightness is controlled by limiting the current. By regulating resistance on the ground side, I am able to dim multiple LEDs with just one switch/resistor setup.
Old 07-22-2013, 05:14 PM   #9
Bowser
Oddometer: 169
Or if you like me, a dab of semi transparent nail varnish, works a treat ;-)
Bowser is offline   Reply With Quote
Old 07-22-2013, 08:54 PM   #10
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,681
Reinforce all LED's with hot glue that tapers down the wire. That will keep them from failing/breaking.
I did that on my KLX450R & HDB clamp LEDs-
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 07-22-2013, 08:55 PM   #11
Hondo
Hondo's Avatar
Oddometer: 9,681
And after scuffing up the LEDs with some sandpaper, I dipped them in a bit a satin black paint to tone them down some-
Old 07-22-2013, 09:36 PM   #12
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
A couple layers of a black marker works too.
+1 on the hot glue. I did the same. Pretty secure now.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 07-23-2013, 09:04 PM   #13
DirtJack
DirtJack's Avatar
Oddometer: 1,600
I just press the LEDs in the holes. No problem with them falling out. Ganging the LED circuit doesn't work in my application (well I could do that for the two on the left -- good idea HellSickle). Voltmeter has its own LED and auto dimming. The ABS circuit can't reliably tolerate dimming resistance. I need a DPST switch in the same size. Paul, do know if they are available?
2008 KTM 690 Enduro
DirtJack screwed with this post 07-24-2013 at 08:11 AM
Old 07-24-2013, 10:39 AM   #14
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,509
You want an ABS indicator light? I just used one of Paul's switches to interrupt the rear ABS line. In my dash picture above, the ABS switch is installed next to the flasher switch & power outlet. When open, the factory dash light indicates the ABS has faulted. Granted, a toggle would give a visual indication when the bike is off or before you start. If I start going and find it's disabled, I just hit the switch and key cycle the engine without stopping.
Old 07-24-2013, 05:19 PM   #15
DirtJack
DirtJack's Avatar
Oddometer: 1,600
I tried the LED in series but ABS would not reliably engage when on. The older dash has an ABS indicator, but it is not that useful since it always starts out indicating an ABS fault. I have mine wired the way you suggest (note no LED above the right most switch). A DPST switch would allow wiring an indicator LED to show whether the switch is on or off (ABS default on or off). The way it is now (to use KTM's indicator) you have to put the bike in motion to know which way the switch is set. (re-reading before reply, we're saying the same thing ) I hadn't tried cycling the switch without stopping. Good to know that works.
2008 KTM 690 Enduro
Times are GMT -7.   It's 02:25 PM.
