Old 07-22-2013, 02:30 AM   #1
JohnG. OP
JohnG.'s Avatar
Oddometer: 2,008
SCA fuses
SCA fuses,their quality varies...
JohnG.
JohnG. is offline   Reply With Quote
Old 07-22-2013, 03:58 AM   #2
gavo
Slacker
gavo's Avatar
Oddometer: 1,817
Had this problem also.Melted the fuse holder as well.
gavo is offline   Reply With Quote
Old 07-22-2013, 04:53 AM   #3
PBee
______________
PBee's Avatar
Oddometer: 8,888
Everything I see in that photo is wrong, did the fuse do all of that?
QUORN SCHNITZEL CLUB Est 2011.
When in the FLINDERS RANGES SA stay at the
ANGORICHINA VILLAGE
PBee is offline   Reply With Quote
Old 07-22-2013, 04:37 PM   #4
crash n bern
crash n bern's Avatar
Oddometer: 1,295
Well put.
*Crash testing motorcycles since 1972.
crash n bern is offline   Reply With Quote
Old 07-22-2013, 05:47 PM   #5
dnrobertson
Big Bike, Slow Rider
Oddometer: 808
For the purpose of education, could you detail what is wrong in the photo?
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 07-22-2013, 06:25 PM   #6
Andy_P
Oddometer: 449
I would say that its not a fuse issue, but rather a design issue. The fuse is designed to blow when it gets over a certain current. If it sits just under that, it gets hot, but not quite hot enough to melt the fuse material.
You will also see the same issue when the contacts in the fuse holder are dirty/corroded or the contacts are underrated. Possibly a combination of the 2.
“The purpose of education is not to validate ignorance but to overcome it”
― Lawrence M. Krauss
Andy_P is offline   Reply With Quote
Old 07-22-2013, 06:28 PM   #7
Warin
Retired
Oddometer: 2,122
Electrical tape
Possibly wire colour
Solder joint without strain relief
The problem for that fuse holder is poor contact, that combined with current produces heat that has melted the thing.
If you want to avoid this - check the contact pressure - is it hard or easy to insert the fuse? Does it get warm/hot - feel by hand with what ever it powers 'on'.
Warin is offline   Reply With Quote
Old 07-22-2013, 06:38 PM   #8
slowbike smallpenis
Tester of Tooheys Old
slowbike smallpenis's Avatar
Oddometer: 19,631
Any rating noted on the fuse base and carrier?
Illusion is the first of all pleasures
slowbike smallpenis is offline   Reply With Quote
Old 07-23-2013, 02:04 AM   #9
wisejangrae
Oddometer: 163
Originally Posted by andy_p View Post
i would say that its not a fuse issue, but rather a design issue. The fuse is designed to blow when it gets over a certain current. If it sits just under that, it gets hot, but not quite hot enough to melt the fuse material.
+ 1
wisejangrae is offline   Reply With Quote
Old 07-23-2013, 02:21 AM   #10
PBee
______________
PBee's Avatar
Oddometer: 8,888
Originally Posted by Warin View Post
Electrical tape
+ 1 wire looks like it melted the insulation & is insulated with black tape.
I'd rip it all apart & start again. Top of the list after that would be to measure the current draw.
ANGORICHINA VILLAGE
Old 07-23-2013, 02:28 AM   #11
klx_dude
klx_dude's Avatar
Oddometer: 102
Use heat shrink instead of insulation tape. Alot neater and easier to get a nice clean look that will last longer
Sent from my GT-I9300T using Tapatalk 2
klx_dude is offline   Reply With Quote
Old 07-23-2013, 03:03 AM   #12
muncher850
Oddometer: 14
same problem
had the same problem , burnt out fuse block , cheap chinese fuses not blowing at the rated specifcations , checked the packet of fuses all blade fuses seem to have the same size wire (guage ) for different amperage , threw them out and bought Brand name , no problems since
muncher850 is offline   Reply With Quote
Old 07-23-2013, 04:17 AM   #13
Andy_P
Oddometer: 449
scientific observation?
Not saying they are all good, but often the differences are subtle.
I have seen the damage in the photo many times, with high quality fuses. I just wonder what that fuse is for, because 9 times out of 10 you see that in headlight wiring.
Old 07-23-2013, 07:28 PM   #14
sidecarcrazy
grandad in gladstone
sidecarcrazy's Avatar
Oddometer: 178
Grey tape
Is that grey tape "metallised duct tape" ?
Seen plenty of builders use it on building sites and the tape can become 'LIVE'
You should use 'insulation tape'
my 2 cents worth
sidecarcrazy is offline   Reply With Quote
Old 07-24-2013, 04:24 AM   #15
itsgunnahurt
Gravity Enhanced!
itsgunnahurt's Avatar
Oddometer: 1,948
Did you follow the correct application chart?
I hate it when the voices in my head go silent...
˙˙˙buıuuɐןd ǝɹɐ sɹǝʞɔnɟ ǝsoɥʇ ʇɐɥʍ ʍouʞ ɹǝʌǝu ı
itsgunnahurt is online now   Reply With Quote
Times are GMT -7.   It's 02:03 AM.
