Old 07-22-2013, 07:01 PM   #16
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,207
Originally Posted by AntonLargiader View Post
From the ad:
I have to admit I didn't read all the way to the bottom of the ad. It does say not compatible with fuel and oil but earlier it says suitable for intake components. I'm at a loss to explain what they mean.
---Albert Einstein
Old 07-22-2013, 08:49 PM   #17
supershaft
because I can
Oddometer: 9,116
Most of the time it seems like everyone jumps on someone for not mentioning what model when it doesn't matter and then no asks the question when it does. Small port heads have carb spigots for both 32 and 40mm carbs. Last time I checked they were cheap. Big port heads don't have spigots for 32mm carbs. What heads does the OP have?
Old 07-22-2013, 09:04 PM   #18
robtg
Oddometer: 709
I think he is trying to put 32mm carbs on big port heads for whatever reason.
robtg is online now   Reply With Quote
Old 07-22-2013, 09:14 PM   #19
supershaft
because I can
Oddometer: 9,116
For wrongever reason? I have no advise for that.
Old 07-22-2013, 09:21 PM   #20
Plaka
Brevis illi vita est
Oddometer: 4,614
All intake components upstream of the carb don't take fuel. Most don't take oil either although on the airhead the crank windage is just upstream of the carb.
Old 07-22-2013, 10:16 PM   #21
mykill
odd
mykill's Avatar
Oddometer: 1,168
Sounds like budgetary reasons. Sounds like a good 38mm Mikuni or Dellorto application to me.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 07-22-2013, 10:25 PM   #22
Warin
Retired
Oddometer: 2,329
Ummm.. I've had the carbs flood .. and the bmw components took the excess fuel without dissolving. They also take oil - engine blow by. I'd need any components in that area to take both fuel and oil. I can fix beside the road the fuel over flow, tolerate the oil but some component dissolving?
Warin is offline   Reply With Quote
Old 07-23-2013, 04:44 AM   #23
centdukesfan OP
Oddometer: 62
i dont think these things would dissolve with fuel - just not made to put liquid fuel through every day
I could get new carbs - but why? R100s used to run the 32mm bings, and ive had success running the bike very smoothly with a less than ideal jerry rigged setup. I want something more permanent and that doesnt have vacuum leaks
centdukesfan is offline   Reply With Quote
Old 07-23-2013, 05:53 AM   #24
Plaka
Oddometer: 4,614
Not so much dissolve as swell and get soft and gummy. You are putting liquid fuel through them ever day. If the mfg. says don't then don't. You don't know more about them than they do. These things are for turbo to intercooler transitions and the like. No gas, but very hot.
See if 32mm spigots will screw into your heads.
Check out Sudco for proper rubber adapters.
Consult the folks at Rocky Point Cycle about proper rubber adapters.
Old 07-23-2013, 08:58 AM   #25
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,207
That's just it. As mentioned by Mr. SS you have not given the year and model of this engine yet. All we know is it is an R100 in an R80 frame. Not all R100 engines are the same. This may be one of the years that has different sized metal spigots that screw into the head. If so it would work much better than rubber adapters.
---Albert Einstein
Old 07-23-2013, 09:10 AM   #26
supershaft
because I can
Oddometer: 9,116
/7's that came with 32mm carbs have different heads. Small port heads. Different carb spigots, port sizes, and valve sizes. I don't think anyone has made a spigot to put a 32mm carb on a big port head.
Everything up stream doesn't take fuel? That's not even close to right. Reversion. Idle your airhead without the snorkels on. You can see it with your own eyes. It happens.
Know better than the manufacturer? That's sometimes easy to do.
supershaft screwed with this post 07-23-2013 at 09:34 AM
Old 07-23-2013, 09:14 AM   #27
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,606
Not the exact application you have, but should work the same. I used the stock bmw rubbers to fit mikuni VM34s on big port heads. Get one of the larger rubbers for 40mm carbs, and sleeve one of the smaller rubbers for 32mm carbs (trimmed to half its length) inside of it where it clamps to the carb. The portion that clamps to the spigot will still be the larger ID. Use the stock BMW clamps on the outside and the whole mess will look like this (but with a bing):
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler is online now   Reply With Quote
Old 07-23-2013, 12:34 PM   #28
centdukesfan OP
Oddometer: 62
i did that, but the back pressure blew it out a few times, i could never really get a good fit. Youve never had that problem?
Old 07-23-2013, 12:41 PM   #29
Airhead Wrangler
Adios Mexico
Oddometer: 6,606
I haven't put many miles on it yet. What "back pressure" are you talking about? Sounds more like a backfire. There shouldn't be any pressure in your intake tract that would blow your carb off the head. You might have a leaky intake valve or your ignition or your cam is timed wrong.
Old 07-23-2013, 01:27 PM   #30
centdukesfan OP
Oddometer: 62
When the engine stops, i believe there is air blowback which puts pressure on that connection.
Times are GMT -7.   It's 03:13 PM.
