Old 07-22-2013, 04:53 PM   #1
gunnirider OP
Oddometer: 37
'01 1150 GS Rubber grommet stud broken
went to change the oil a couple of days ago. removed the nuts and female (sex bolts) that hold the skid plate. one of the rubber grommet studs fell off the bike. is there a trick to replacing this stud? i have the part # on the broken stud, but want to make sure i perform this repair correctly. yes, i have crash bars on the bike and a secondary Touratech skid plate that all attach to the studs. should i change all of them or just the broken one?
gunnirider is offline   Reply With Quote
Old 07-22-2013, 05:05 PM   #2
tjt94
Oddometer: 603
No trick to it at all. It is a cheap part you get from BMW (less than $3 each). They are there to fail instead of a crash breaking the engine.
tjt94 is offline   Reply With Quote
Old 07-22-2013, 05:09 PM   #3
mudmullet
mudmullet's Avatar
Oddometer: 196
order 3 or 4 of them (to save on shipping) and replace them as needed.
mudmullet is offline   Reply With Quote
Old 07-22-2013, 05:53 PM   #4
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,944
Just grab it close to the block and you will find a steel hex encapsulated in the rubber. That will give enough bite to remove it. I like to put some anti sieze on them so they come out easy if they break.
bemiiten is offline   Reply With Quote
Old 07-23-2013, 06:51 AM   #5
gunnirider OP
Oddometer: 37
replace broken stud
thanks guys! i'll order the part today....and a few spares.
Old 07-23-2013, 06:58 AM   #6
cidi
cidi
Oddometer: 33
So I have been through several sets of these. It seems that everytime I make contact with the skid plate and rock or dirt these keep breaking . Seems that I carry my skid plate more on the back of my bike than under it . Anyone found a better solution than the stock set-up?
Life has many risks.
The most dangerous risk of all - The risk of spending your life not doing what you want on the bet you can buy yourself the freedom to do it later.
cidi is offline   Reply With Quote
Old 07-23-2013, 10:19 AM   #7
Welshman
B.U.F.F.
Welshman's Avatar
Oddometer: 1,205
Get better springs/shocks only real answer
Welshman is offline   Reply With Quote
Old 07-23-2013, 04:09 PM   #8
cidi
cidi
Oddometer: 33
Thanks Welshman! Not what I wanted to hear but the truth sometimes hurts...
Old 07-23-2013, 08:51 PM   #9
Welshman
B.U.F.F.
Welshman's Avatar
Oddometer: 1,205
I have a large jar of those broken mounts, as I used to rip my bash plate of regularly.
Replaced shocks with a rebuilt GSA set and hyperpro springs has cured the problem
"Just south of Denver" I spent a week in Colorado Springs a couple of years ago, rather nice..
Old 07-24-2013, 08:34 AM   #10
gunnirider OP
Oddometer: 37
shocks/springs
have 63k on the bike with plenty of off-roading miles...guess i got lucky that i've only have one broken stud, but i guess the next project will be new suspension. good excuse to upgrade
Old 07-24-2013, 10:50 AM   #11
Welshman
B.U.F.F.
Welshman's Avatar
Oddometer: 1,205
I am a B.U.F.F. and tend to chase "friends" on gravel roads with the ocasional washout, so its a case of the wrong tool for the job, but I am attached to the old girl
UMMM
Welshman screwed with this post 07-24-2013 at 10:57 AM
Times are GMT -7.   It's 04:09 AM.
