Old 07-23-2013, 07:56 AM   #1
John Smallberries OP
John Smallberries's Avatar
Oddometer: 1,310
Airbrake on '05 GS: beware...
While not a new issue, I thought I'd share my experience to help anyone else with a potentially dangerous GS problem. The side panels on the 1200GS sold before the '07 model year had a crappy plastic/rubber twist-lock to hold the front edge onto the frame. If it pops loose while riding - you get this:
The airbrake failure wrecks the $400 black side cover and puts a nasty crease in the $300 silver cover. Luckily, I found an inmate with a used set (on the way).
For '07MY, they replaced the rubber plug with a proper threaded fastener.
I had this happen to me a few years ago and THOUGHT I fixed the issue by replacing the plug with a zip tie. I replaced the zip tie every time I had the cover off. I was not aware that I could scurry down to my dealership and buy the upgraded fastener. Well - one of my zip ties failed and I got the right-hand airbrake again while riding this weekend. Lesson learned.
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 '07 KTM 400 XCW/EXC '15 Jialing 150 GY2
John Smallberries is offline   Reply With Quote
Old 07-23-2013, 08:10 AM   #2
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,750
When the forward lower inside fastener is affixed correctly, this does not happen. I advise anyone who is unsure to use cable ties or nuts & bolts. The 2005 side panels do not tolerate improper installation.
Old 07-23-2013, 08:13 AM   #3
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,043
If you do it right it will not come open. If you do not get the lower front fastner "snapped" in place, then this will happen.
There is a simple way to do it. Hold the fastner parallel with the ground between your index and middle finger, then squeeze the fastner with your palm until you hear it snap into place. If you try to do it by turning the fastner you are risking not getting it properly seated.
Jim
Old 07-23-2013, 08:28 AM   #4
GB
Mod Squad
GB's Avatar
Oddometer: 56,998
It's a quarter turn fastener. Tug on the lower front end after attaching it and if it's fastened correctly it will not come loose. Operator error and poor design, hence the change in 2007.
Old 07-23-2013, 09:42 AM   #5
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,037
What, no hue and cry for a recall and free parts from BMW?
OBVIOUSLY a safety issue.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 07-23-2013, 10:59 AM   #6
JimVonBaden
"Cool" Aid!
Oddometer: 54,043
So is not strapping on your helmet correctly!
Jim
Old 07-23-2013, 11:35 AM   #7
Farkleberry
Farkleberry's Avatar
Oddometer: 186
My 07 ones are none to awesome, either.
Farkleberry is offline   Reply With Quote
Old 07-23-2013, 12:50 PM   #8
jolly green giant
biggles
jolly green giant's Avatar
Oddometer: 139
This will not happen if a. you fasten correctly, b. you have upper engine guards
jolly green giant is offline   Reply With Quote
Old 07-23-2013, 01:22 PM   #9
Desert Skies
One brick shy...
Desert Skies's Avatar
Oddometer: 2,411
I remember seeing this shortly after getting my 05. From then on, I make sure the fastener is installed correctly. Then I double check it...
“Sorry I'm late, feck'n off takes a lot of time.”
" The 'Wing is my wife's bike - I'm just the feck'n driver." - USMCG_Spyder
" This post is full of VonBadenisms." - Gordy
Tripn' with Tom Some pictures ZZ Rider - Tom Lowry Texas Blue - Tom Lowry
Desert Skies is offline   Reply With Quote
Old 07-23-2013, 02:14 PM   #10
Desert Skies
One brick shy...
Oddometer: 2,411
BTW, those are not 'Airbrakes'. They are cornering enhancement spoilers... Same principle as these...
You are only supposed to deploy them when in curves... I know it's written in the manual somewhere.
Old 07-23-2013, 02:22 PM   #11
Oddometer: 1,310
The fix
Shoulda done this 3 years ago:
Old 07-23-2013, 02:33 PM   #12
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,750
Do those fit your panels ok? I was going to make the upgrade but the parts guru at a well-known shop told me they changed so much about the panels with the re-design that you couldn't just do that. He was able to source me new original quick release fastener parts, which I put in place and are working fine.
Old 07-23-2013, 02:36 PM   #13
Oddometer: 1,310
Setting!
You are right - I had them set on "Biannual/Random" mode.
Old 07-23-2013, 02:47 PM   #14
Oddometer: 1,310
Fit fine
Popped out the old one - popped in the new one. Hole lines up OK. Looks good.
Old 07-23-2013, 02:52 PM   #15
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,750
Thanks! Good to know.
Times are GMT -7.   It's 10:51 PM.
