Old 07-23-2013, 01:19 PM   #1
alongat OP
alongat's Avatar
Oddometer: 1,055
990 Canisterectomy - again???
Is this the most current and simple approach? I did a search and came up with this tutorial:
http://advrider.com/forums/showthrea...ight=cannister
If there is anything else, please advise (ah, I will also check the 950 HOW for a 990 Canisterectomy).
Thanks in advance
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 07-24-2013, 03:59 AM   #2
mbrick
Oddometer: 119
Not sure if you are referring to 990ADV or 990SD. But they are fairly similar.
That's a great guide.
A few notes:
He didn't spec the factory screw to replace the brass nipples on one side. I prefer the factory bolt/washer and not a home depot special, have always used the bolt/washer from EU cylinder head on 450/690/990's. Use locktite.
Bolt + washer, P/N's here (need 2x ea):
0015060103 HH COLLAR SCREW M 6X10 WS=8
0603061001 CU SEAL RING DIN7603-6x10x1
Or, some people use a section of hose to connect the 2 brass nipples together and that might prevent surging. I suspect the surging issues people talk about are more likely from using the hodo bolt without a washer?
1/2" vacuum cap for the airbox.
Part number for the female plug side of the SAS vacuum pump plug.
ECK-212
http://www.eagleday.com/ampconnectors.html
--> Wish there was another source
Leave the reed valve behind the SAS block off plates.
KTMTwins plates:
http://www.ktmtwins.com/ktm-lc8-emis...ock-off-plates
Appears most cut the plug off the air pump and re-use it. Would be easy to solder back in later. I am guessing it is a Sumitomo MT-090-2B, will have to look closer later.
More info here:
http://www.advrider.com/forums/showt...=237372&page=6
http://www.advrider.com/forums/showthread.php?t=493015
950 SM-R SAS removal guide here:
http://home.comcast.net/~garrysimmon...er-Removal.htm
mbrick screwed with this post 07-24-2013 at 07:32 AM
mbrick is offline   Reply With Quote
Old 07-24-2013, 07:28 AM   #3
alongat OP
alongat's Avatar
Oddometer: 1,055
Awesome, thank you. It's for a 990 Adventure R by the way...and yes, I am doing the SAS at the same time.
A few notes:
0015060103-HH COLLAR SCREW M 6X10 WS=8
0603061001-CU SEAL RING DIN7603-6x10x1
ECK-212
KTMTwins plates:
More info here:
Toronto, Canada
Times are GMT -7.   It's 07:47 PM.
