Old 08-22-2013, 07:33 AM   #1
drj434343 OP
Oddometer: 76
Any LED headlight options available?
I've been looking into a headlight upgrade for my R100RS. It currently has the stock 8" enclosure with a PIAA 55/60 W bulb installed by the PO. The projected light is pretty bad, especially compared to the Truck-lite 7" LED headlight I installed on my Honda CB.
That said, the issue I see is the size difference. I can't find anyone who manufactures a 8" LED replacement. There are H4 LED bulbs that can be swapped into the original housing, but they do not put out nearly enough light to be replacements; most are advertised as daytime running lights only.
I've read about HID options on this board and others. It seems like a possibility, but I don't like the complication of an additional box, and issues with the dark spot due to the cap in the housing.
Has anyone found either a suitable LED option, or possibly a 8" to 7" housing conversion so as to use existing 7" fixtures?
drj434343 is offline   Reply With Quote
Old 08-22-2013, 07:42 AM   #2
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Not sure if it will help but why dont you get in touch with boatman. He worked out 2 8" to 7" conversion for both baja and trailtech 8" race lights maybe he can help you out
http://www.advrider.com/forums/showthread.php?t=532075
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 08-22-2013, 05:37 PM   #3
Kai Ju
Kai Ju's Avatar
Oddometer: 1,817
Truck Lite
http://tinyurl.com/m4l6pag
Not cheap but that's the one I want.
Kai Ju is offline   Reply With Quote
Old 08-23-2013, 08:44 AM   #4
drj434343 OP
Oddometer: 76
That's the exact one I'm referring to. Unfortunately it will not fit without some kind of conversion ring, as it's only 7".
Old 08-23-2013, 09:12 AM   #5
darklight79
scaffold builder
Oddometer: 418
Led and hid headlights arent exactly legal and some denalis much more effective
darklight79 is offline   Reply With Quote
Old 08-23-2013, 09:48 AM   #6
KhaoSanMan
Airhead
KhaoSanMan's Avatar
Oddometer: 584
There is one of these 7" lights at BoxerMetal and I have been eyeing it for my project. Not only do you have to create a new ring to make it fit the bucket, but you have to think about heat transfer and venting. Since the LED is a sealed unit you *should* be able to just pop some holes in the bucket as long as you aren't doing long distances in the pouring rain.
KhaoSanMan is offline   Reply With Quote
Old 08-23-2013, 10:19 AM   #7
drj434343 OP
Oddometer: 76
Actually, those Truck-lite 27270 LED headlights are fully DOT legal.
As for heat dissipation, they're designed to fit into enclosed headlight buckets without modification. They have about 3 pounds of aluminum on the back to help with heat, but in my experience they don't get nearly as hot as a filament bulb sitting in the same bucket. I've been running one already on a Honda CB500 for a year.
Old 08-23-2013, 12:23 PM   #8
drj434343 OP
Oddometer: 76
Boatman was kind enough to respond to my inquery, however, his conversion ring has a 8.5" OD, which is way to large for my attachment ring and bucket. My measurements indicate I need about 7 3/4" OD to fit in the R100RS. This is the strangest sized light I've ever seen, I can't find any Google references to whatever standard it may have adhered to...
Old 08-23-2013, 01:42 PM   #9
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Figured it was worth a shot. Good luck
Old 08-23-2013, 02:56 PM   #10
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,774
The Slash Fives, and the R65/R45 and R80ST G/S all had the smaller reflector... maybe try a bucket from one of those?
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 08-24-2013, 12:49 PM   #11
noman
Oddometer: 844
lighting
have you considered a 100w halogen? been running one in my r75 since 1982 or thereabouts, after a truck turned left in front of me. hasn't happened since, 'cause i'm being seen now.
they're for off-road use only, but have never been stopped.
1976 r75/6 -- thx lloyd!
1985 vf500f -- v4, 6 spd, 16v, triple discs, water cooled
1997 900ss -- full sp spec
noman is offline   Reply With Quote
Times are GMT -7.   It's 03:52 AM.
