Old 07-27-2013, 12:15 AM   #31
RGregor
Oddometer: 485
Originally Posted by supershaft View Post
The only TM40? There's the TM40 smooth bore, TM Pro Series which come in 39 and 41mms, TM40-6's, and more.
Hello!
Oh man, I came up with a carb type that fits very nicely to our beemers.
And as a reaction we discuss about your self invented categorization "regular" and finally, if TM39s or TM41s of the Pro Series are also TM40s?
Something like "They fit, cool" would have been sufficient.
My very best regards
RG
RGregor is offline   Reply With Quote
Old 07-27-2013, 12:18 AM   #32
RGregor
Oddometer: 485
Explanation? Better mixture.
Hello again!
Just to be sure I got it right.
1. The improvement concerns WOT high rpm?
2. You did not remove the pump jet? Just set the adjuster screw for zero delivery?
Best regards
RG
Old 07-27-2013, 01:22 AM   #33
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,253
RG, thank you for your contributions (here and elsewhere) and bless you for your patience. It is always good to see your posts.
--Bill
'73 R60/5 Toaster
Old 07-27-2013, 04:40 AM   #34
beemerphile OP
beemerphile's Avatar
Oddometer: 1,949
--Bill
^^^ What Bill said ^^^
ΜOΛΩΝ ΛΑΒΕ - Lee
Unreconstructed Southerner living in Occupied Georgia
beemerphile is offline   Reply With Quote
Old 07-27-2013, 11:49 AM   #35
chasbmw
Oddometer: 2,349
Originally Posted by beemerphile View Post
^^^ what bill said ^^^
+1
Charles
1971 Commando Fastback
Old 07-27-2013, 11:53 AM   #36
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 552
Hear, hear!
Cheers, Jon-Lars Sorenson
Beverly, WA
http://www.facebook.com/BMWR90S
Jon-Lars is offline   Reply With Quote
Old 07-28-2013, 02:10 PM   #37
supershaft
because I can
Oddometer: 9,116
Originally Posted by RGregor View Post
Hello!
RG
You didn't just come up with a carb. You said that my advise about TM carbs was wrong and it wasn't. You can't use a late model snorkel on TM carb like in the photo you posted. You can a TM smooth bore but I was talking about 'regular' TM's. I suspect you might make better sense sticking with forums in German? Self invented? I didn't invent TM's, Mikuni did. They also invented TM-6's and TM Pro series and TMX's and TM smooth bores and so on. How do you miss an entire point over and over? TM Pro Seires are NOT TM's. They are TM Pro Series just like TM smooth bores are not TM's. They are TM smooth bores. BIG DIFF between TM smooth bores and TM's! Clarify.
Old 07-28-2013, 02:16 PM   #38
supershaft
because I can
Oddometer: 9,116
Hello again!
Best regards
RG
You almost never get the meaning of what I write correctly so what's the use? Remember when I mentioned picking up revs and accelerating? What has that got to do with WOT high rpm? Nothing is the correct answer. The improvement concerns accelerating from low and mid rpms.
I removed the pump arms so the pumps do not function just like a lot of tuners do.
Old 07-28-2013, 02:19 PM   #39
Carl
Carl's Avatar
Oddometer: 770
I suspect you might make better sense sticking with forums in German?.
Hey!
http://www.flyingtpot.com/
Carl is offline   Reply With Quote
Old 07-28-2013, 04:19 PM   #40
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 552
What Carl said.
Times two.
If there ever was a reason to ban Supershaft, this is it.
Beverly, WA
Old 07-28-2013, 04:44 PM   #41
Carl
Carl's Avatar
Oddometer: 770
I suspect you might make better sense sticking with forums in German? .
Hey kbasa,
You banned me for posting wittle willie's name. You let Greg slide when falsely posting and trying to connect my name to a lawsuit all the while knowing I wasn't involved.
Now step up to the plate get this racist krap out of here.
And by the way, have a nice day.
Carl
Carl screwed with this post 07-28-2013 at 07:14 PM
Old 07-28-2013, 07:20 PM   #42
robtg
Oddometer: 697
Not taking sides here,but you're all acting like a bunch of fucking idiots.
robtg is offline   Reply With Quote
Old 07-28-2013, 07:23 PM   #43
beemerphile OP
Oddometer: 1,949
Why does every simple question on the interwebs turn into a pissing contest?
I appreciate the learnings but the virtual descent into hell is unfortunate.
ΜOΛΩΝ ΛΑΒΕ - Lee
Old 07-28-2013, 07:47 PM   #44
Carl
Carl's Avatar
Oddometer: 770
Get real!
Several posters become 'all'!
You step in w/ the name calling!
Your a friend of his and often chime in taking his side.
Face it, he messed with Rudi! That is a mistake!
Carl
Old 07-28-2013, 07:51 PM   #45
Carl
Carl's Avatar
Oddometer: 770
Rudi is one kool kat. He never grooves in pissing contests. When he is told 'I suspect you might make better sense sticking with forums in German? Then I'm taking it to some virtual form of ascent/descent hell!
Carl
Times are GMT -7.   It's 04:48 PM.
