Old 07-25-2013, 07:08 PM   #16
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,930
Where's the icon that shows a forehead-slap saying.... duh!!
Of course, 4.5 volts will not charge a 12v... it takes a higher-than-nominal voltage to charge anything! You may be on to something!
Will look for the manyana post.....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 07-25-2013, 07:31 PM   #17
ritetwist OP
ritetwist's Avatar
Oddometer: 180
Update,the newer auto charger was set to 6 volts, gave a 12.5 volt out put reading.
Set on 12 volts, shows about 22 volts output.
The battery is already showing 13.5 vots and still charging.
Old charger is in the dumpster.
My forehead is sore.
Where are those old batteries?
I don't often throw things away.
Afraid to sleep for fear of missing something.
ritetwist is offline   Reply With Quote
Old 07-25-2013, 09:29 PM   #18
Warin
Retired
Oddometer: 2,267
Originally Posted by ritetwist View Post
1) Old charger is in the dumpster.
2) My forehead is sore.
3) Where are those old batteries?
4) I don't often throw things away.
Take old charger out of dumpster. Solves 4 and 1.
Drink beer. Solves 2.
The old charger may just have a faulty diode or two. Can you open it and look inside? If you cannot do it .. take it to your next swap meet or bmw club meeting .. give it away. This helps with 3 as you now have given penance for that.
Warin is offline   Reply With Quote
Old 07-25-2013, 11:04 PM   #19
ritetwist OP
ritetwist's Avatar
Oddometer: 180
Thanks W.
Before I threw the old charger out, I cut the AC cord off. Future use as a pig-tail for checking motors / pumps / lights,etc.I also cut the DC cord with the alligator clips on it, helps for testing DC hookups.
I found 4 batteries that I can charge and load test, there may be some salvation there.
Thanks for the help.
A lesson well learned. Painful to admit.
Old 07-26-2013, 04:28 AM   #20
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,930
All is well in the world.
Have another beer.
Loving the 80ST
Times are GMT -7.   It's 07:38 AM.
