Old 07-24-2013, 06:19 AM   #1
Jeremiah Johnson OP
Oddometer: 11
Question 990 adventure fuel issue
Wondering if anyone with the 2012 adventure might have had this problem:
Riding down highway, engine dies. There is fuel coming out of the fuel overflow tube at the bottom of the bike. Turn on the key, can hear fuel pump running, but fuel pours out of overflow constantly and bike wont start.... Nearest ktm dealer to me is 8 hours away...
Jeremiah Johnson is offline   Reply With Quote
Old 07-24-2013, 07:25 AM   #2
alongat
alongat's Avatar
Oddometer: 1,220
Did this just start suddenly or was the bike displaying other odd behaviours prior to stalling / spitting fuel, etc? Did you ride off road prior to this? There are a number of posts relating to preventative measures designed to avoid situations that sound similar to what you are describing; those related to the evap / canister system and those related to the fuel cap "flap" - I don't know if these would help but have a read through these links to see if any of this jives...
Decanisterectomy for 950/990:
http://advrider.com/forums/showthread.php?t=905992
Flapendectomy for 950 / 990:
http://www.ktm950.info/how/Orange%20...endectomy.html
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is online now   Reply With Quote
Old 07-24-2013, 07:27 AM   #3
alongat
alongat's Avatar
Oddometer: 1,220
By the way, are you sure fuel is coming out of the overflow tube rather than the fuel line (or lines) coming out of the fuel tank petcocks? In addition to the links I provided, I know that there is a crossover vent tube that runs between the tanks along the top so if you have had the front side pieces or dash/headlight areas of the bike apart for any reason, you could have disconnected or pinched that crossover tube.
Toronto, Canada
Old 07-24-2013, 08:50 AM   #4
Jeremiah Johnson OP
Oddometer: 11
It did start suddenly, no other issues before that.
Upon further investigation, the fuel is coming from the air box drain line.. air filter is soaked with gas... will continue searching for source...Any ideas or known issues??
And thank you very much for your help!
Old 07-24-2013, 10:24 AM   #5
alongat
alongat's Avatar
Oddometer: 1,220
Sorry, I'm stumped on this one - hopefully somebody else has an idea...
Toronto, Canada
Old 07-24-2013, 10:31 AM   #6
Hootowl
Oddometer: 1,262
Check the fuel line coming from the left tank where it enters the airbox and connects to the TB's
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 07-24-2013, 10:42 AM   #7
Jeremiah Johnson OP
Oddometer: 11
yep that's it, pin hole in fuel line just below where it attaches to tb's. Going to remove and just splice a new piece of fuel line until the new one arrives. Thanks
Old 07-24-2013, 11:08 AM   #8
Hootowl
Oddometer: 1,262
Good that you found the problem. Make sure to use FI rated line
'07 990A
'12 Super Tenere
Times are GMT -7.   It's 02:21 AM.
