Old 07-29-2013, 11:21 PM   #31
D K
Oddometer: 482
Clips.
And I make sure they are installed the correct way, or they will come loose.
Never once had a problem and makes swapping gearing easier if chain needs to be shortened or lengthened.
'13 EC300 Racing
07 950SE - sold
08 950SE - sold
09 FE570 - sold
D K is offline   Reply With Quote
Old 07-30-2013, 05:17 AM   #32
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,865
How does that work? Do you run two clip links?
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 07-30-2013, 06:14 AM   #33
Reinhold
No, not Messner
Oddometer: 195
For you riveting guys.......what chain tool do you use and do you carry it with you when you ride on trips? If you use solid rivets I think the tool would be pretty heavy......
Reinhold is offline   Reply With Quote
Old 07-30-2013, 07:22 AM   #34
ABuck99 OP
0.0
ABuck99's Avatar
Oddometer: 651
Originally Posted by D K View Post
Clips.
Exactly- Its the main reason I stared the thread: Ive got two sets of wheels, with different gearing, and wanted to keep dedicated chain that's matched for that gearing, and most importantly making it easier to swap from one to the other.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 07-30-2013, 07:47 AM   #35
Quij95
Quij95's Avatar
Oddometer: 61
I have used all methods described above and lost clips with and without silicone. Never lost safety wire described in a previous post. Make sure you do it exactly like the picture, tail at trailing end, do not curl.
Quij95 is offline   Reply With Quote
Old 07-31-2013, 06:30 AM   #36
xTomKx
xTomKx's Avatar
Oddometer: 196
What thickness safety wire?
2012 KTM 990A, 2006 KTM 250 2s, and many other toys
xTomKx is offline   Reply With Quote
Old 07-31-2013, 09:35 AM   #37
Quij95
Quij95's Avatar
Oddometer: 61
0.032" stainless aircraft grade works best.
Old 07-31-2013, 09:41 AM   #38
WallyWhirled
WallyWhirled's Avatar
Oddometer: 854
It is my understanding that lots of shops are no longer selling big bike chains with clips. Choice may have already been made for you.
KTM 950 Super Enduro, KTM 950 Adventure,
Beta 520 RS, Rickman Cafe Racer
WallyWhirled is offline   Reply With Quote
Old 07-31-2013, 11:45 AM   #39
triplenickel
triplenickel's Avatar
Oddometer: 2,430
I rivet when I'm at home but pack some extra clip type links for the trail. I use a Motion Pro Jumbo at home which could probably be carried without noticing the weight if you're loaded to travel on one of these pigs.
07 SE
PG007
Old 07-31-2013, 08:36 PM   #40
highsider
Oddometer: 28
Clips are fine for standard chains, but if you have an o-ring chain, riveted masters are better. Its the constant outward pressure of the o-rings that do not allow a master link clip any way to recover from being whacked out of its slot, and wear the clip and slot. This is why race bikes can get away with the clips- no o-ring chains.
highsider is offline   Reply With Quote
Old 08-01-2013, 01:35 AM   #41
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 584
Originally Posted by Frog uk View Post
Why bother grinding the pin heads off and using a tool to push the pin out? I used to do it like this until one day the light went on above my head, and used the grinder to just cut straight through the chain, takes no time at all and saves pissing around pushing pins out.
I assume you're putting a new chain on.
Agreed.
If you grind or file the pins, why bother with a special tool? Just use a screwdriver between the links and twist - it's quick and easy.
If you don't need to swap your chain for different gearing, why not use the rivet link that you get free with the (DID) chain?
Also, it's pretty quick and easy to remove the swinging arm to swap out the chain without splitting if you're removing the wheel anyway.
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 08-01-2013, 11:05 AM   #42
D K
Oddometer: 482
The only downside with a clip is that if you install the clip backwards and the chain comes in contact with anything, it can push the clip loose.
It's not an issue is the clip is installed the correct direction.
I have, on 2 occasions, swapped a clip around on a bike I have purchased 2nd hand
YMMV
'13 EC300 Racing
07 950SE - sold
08 950SE - sold
09 FE570 - sold
Old 08-02-2013, 05:12 AM   #43
halfcab
Oddometer: 683
I have been a clip user since 1974 and will continue to do so. Why, because I remove the chain for inspection and cleaning quite often plus I replace the counter shaft sprocket when needed.
halfcab is online now   Reply With Quote
Old 08-30-2013, 05:30 AM   #44
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,097
Bought a DID 525 vx chain and fitted it up yesterday. Was suprised to see it did not come with a rivet link, only a clip link.
Went back to 3 diffrent shops to find a rivet link and none had one to fit. Was recomended to just run the clip.
Call me old fashion. I want a rivet. Even had a mechanic tell me all bike (Ducati) come with clips now.
Hmmm, Im suspicious about that.
990 Adv 06, Aprilia Tuono 03 Racing gen 1
rossguzzi is offline   Reply With Quote
Old 08-30-2013, 06:51 AM   #45
Rodknee
sensitive? who, me?
Rodknee's Avatar
Oddometer: 3,009
on pure dirtbikes, i will run a clip. on anything i ride on the street, rivet 100% all the time.
on last weeks ride a guy clip took off on him, and luckily nothing happened short of some minor case scraping. could have been a disaster if the wheel locked up on him.
there are enough hazards out there on the street at speed, i don't need to add another.
I choose to live, not just exist...
2015 Rides: Katie M Big girl, Berg Hoon'icycle, Katoom 3hunny (pic)
Rodknee is offline   Reply With Quote
Times are GMT -7.   It's 10:13 AM.
