Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 01-21-2014, 12:34 AM   #196
mcguyver
mcguyver's Avatar
Oddometer: 1,269
Originally Posted by PPiA View Post
Does your dog piss on them or something?
10000km now. Original spring.
Ha havnt got a dog and don't think it's operator error. Stand goes down stand goes up. Spring stretches and either false off when I put the stand down or in the last case one of the springs actually broke.
Am I doing it wrong?
mcguyver is offline   Reply With Quote
Old 01-21-2014, 12:35 AM   #197
PPiA
Pete
PPiA's Avatar
Oddometer: 1,182
Must be...
PPiA is offline   Reply With Quote
Old 01-21-2014, 01:09 AM   #198
OrangeV
OrangeV's Avatar
Oddometer: 617
so your'e at a point where you cant.... stand it...
75 V perky peak power from around 5000rpm and loves to be worked through the gears.
When you hit that sweet spot, it is simply electrifying. Stoner
A smile is a curve that sets allot of things straight..
OrangeV is offline   Reply With Quote
Old 01-21-2014, 01:48 AM   #199
PPiA
Pete
PPiA's Avatar
Oddometer: 1,182
Maybe he just needs to spring for a new one.
Old 01-21-2014, 02:36 AM   #200
Schussboelie
Schussboelie's Avatar
Oddometer: 543
Horn failed...
Schussboelie is offline   Reply With Quote
Old 01-21-2014, 03:52 AM   #201
Scutty
Oddometer: 180
You can get tablets for that................
My bike anthology: Another KTM 690 Enduro R, BMW G450X, BMW R1200GSA LC, KTM 690 Enduro R, Yamaha WR250R, Yamaha XT600E, KTM 990 SM-T, Ducati Diavel, Kawasaki Z1000, Suzuki SV1000, Kawasaki Zx7-R, Honda VFR800, Honda CBR600F, Yamaha RD350, Yamaha DT175, Honda CM125, Kawasaki AR125, Kawasaki AE50 - wow I have owned a lot of bikes
Scutty is offline   Reply With Quote
Old 01-21-2014, 04:05 AM   #202
Schussboelie
Oddometer: 543
That. Is. Too. Funny!!!!
You had me laughing out loud in front of my computer screen, thank you for that!!
Old 01-21-2014, 05:07 AM   #203
wildhog911
Oddometer: 11
Question KTM 1190 Adventure Skid Plate Problem
I recently purchased an 1190 Adventure R and opted for the accessory package marketed thru the dealer. I have found two problems with the items. First, the right rear hanger bolt would not work as provided because the bike came from the factory without a bolt mounting the engine to the frame in this area. I purchased a 10mm tap and created the appropriate threaded hole for mounting. Anyone with a new 1190 should inspect this frame -engine mount point.
Secondly, I have installed the factory fog lights and made all the appropriate connections only to find the Accessory 2 plug to not be hot with the ignition on and engine running. I was wondering where the 1 amp fuse might be for checking purposes.
wildhog911 is offline   Reply With Quote
Old 01-21-2014, 06:38 AM   #204
RoteEddie
Oddometer: 528
Originally Posted by kag View Post
Well....brand new battery fully charged. I had to plow the driveway and our long drive to the house today because it snowed yesterday. I pulled the bikes out of the garage to sweep the garage out. The bikes (listed below) sat out for 3 hours in 15F with a chill of Freezing ass cold. So before I put them up after plowing and sweeping I thought I would let each of them run for 15 minutes or so.
The KTM would not fire as the engine would not spin fast enough. Smelled of gas too. I on off'd it couple of times and no change. I put in the garage with a heat blower on the crank case for 15 minutes and it started. The KTM does not like cold temps like this or maybe the oil in it from the factory is thicker. After break in i do plan on going pure syn. The starter just drags when cold but I thought it spun it enough to kick off but it didn't until I put some heat to it.
My Buell Uly would not even turn over......too cold. The Yamaha TW200's cranked slow but no fire.
The wife's Triumph Tiger 800 spun right up and fired easily. It seems her starter on her bike is much lower geared and spins the motor without any issue and kicked right off........of now she is talking trash.....painful
Mine has failed to start on 2 occasions. Both times temps below 5 degrees C. Battery was simply not strong enough. First time I needed help as I was stranded on my weekend home in the mountains Second time was in my garage yesterday. Put the battery on a charge for 20 minutes and it started.
This could prove very problematic touring the Alps or similar even in summertime. I have not asked KTM for a solution yet.
14' KTM 500EXC
13' KTM 1190 Adventure
12' Aprilia Tuono V4R APRC
12' KTM 690 Enduro R Evo2
RoteEddie is offline   Reply With Quote
Old 01-21-2014, 06:50 AM   #205
Schussboelie
Oddometer: 543
It really is an issue.
Mine only just started yesterday at 6C.
I almost got stranded at work, again.
Both Alp and Arctic circle touring, even in the summertime might become problematic.
In my case commuting to work and clients will prove difficult.
Luckily we've been having a very warm winter so far...
Old 01-21-2014, 07:45 AM   #206
RoteEddie
Oddometer: 528
I am tempted to simply buy an Anti Gravity Micro Start XP-3. Small enough to carry even on my 500.
Sent from my LG-V500 using Tapatalk
14' KTM 500EXC
Old 01-21-2014, 07:50 AM   #207
Schussboelie
Oddometer: 543
Looks like a nice piece of kit...
Old 01-21-2014, 10:41 AM   #208
Tjeu
Oddometer: 143
Does the non-starting-low batterie issue only occures on the bikes fitted with the alarm? Are is it a problem on all bikes?
Tjeu is offline   Reply With Quote
Old 01-21-2014, 10:49 AM   #209
Black Hills
Oddometer: 1,183
will they push start?
Black Hills is offline   Reply With Quote
Old 01-21-2014, 10:51 AM   #210
Tjeu
Oddometer: 143
Doubt it.... Think the assisted anti-hop clutch will make it hard... I know Schussboelie tried it, but it didn't work...
Times are GMT -7.   It's 02:00 AM.
