Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-02-2014, 11:38 PM   #646
Xphile1999
Oddometer: 10
Originally Posted by USPSATrevor View Post
Thanks! I was having the same sound. This helps. : )
I had the same problem with clicking after 1200 miles. When I grabbed the front brake with enough pressure it would have a decent click. Took it to he dealer after finding the rotor had a lot of play. They had said they were floating rotors, but I doubt floating rotors have this much movement. I may be wrong and welcome any input.
The dealer worked the steering head bearing and it seems better. I'm concerned that it may return.
Xphile1999 is offline   Reply With Quote
Old 06-03-2014, 04:09 AM   #647
Bundu
Bundu's Avatar
Oddometer: 675
Originally Posted by Doug Matson View Post
Thought my steering head bearing were loose as the bike was making a clicking noise when coming to a stop so I checked. What i found was the buttons that hold the floating disk on (front) were loose and rocking back and forth, bearings were fine.
https://www.youtube.com/watch?v=7I4P...ature=youtu.be
Bundu is offline   Reply With Quote
Old 06-03-2014, 04:33 AM   #648
MarchHare
Oddometer: 105
Aren't they supposed to be loose, It's what allows the disc to float.....?
MarchHare is online now   Reply With Quote
Old 06-03-2014, 05:31 AM   #649
irongrady
irongrady's Avatar
Oddometer: 241
KTM 1190 problems?
Mine have a tiny bit of play but nowhere near that and no noise . Something is wrong there for sure
irongrady is offline   Reply With Quote
Old 06-03-2014, 05:50 AM   #650
rok1679
rok1679's Avatar
Oddometer: 16
Fuck this. I will rather buy 20 year old Honda and enjoy lousy but working suspension and engine.
Shame, it could be realy good bike for me (R version, second hand of course, because price of the new one is ridiculus).
rok1679 is offline   Reply With Quote
Old 06-03-2014, 06:41 AM   #651
Black Hills
Oddometer: 1,207
my 990 was the same, enough play to make a noticeable click. I think it is normal.
Black Hills is offline   Reply With Quote
Old 06-03-2014, 07:11 AM   #652
Bluesilver
Bluesilver's Avatar
Oddometer: 340
This is why they called "floating" disks, there is VERY small amount of movement but normally on a new bike, no clicking. My RXV450 used to slap quiet nicely but all my Superbikes which the 1190 is comparative to in braking, should be quiet.
Bluesilver is offline   Reply With Quote
Old 06-03-2014, 07:13 AM   #653
Bluesilver
Bluesilver's Avatar
Oddometer: 340
I've been to two dealers 900km apart, both could not "feel" the movement but when you brake a solid "clunk" through the bars can be felt, inspection should the bearing were no longer in spec, both tightend up and after that no more clunking under braking. Last job was to locktite the header...problem solved so far.
Old 06-03-2014, 07:28 AM   #654
DirtJack
DirtJack's Avatar
Oddometer: 1,576
The float is supposed to be lateral, not in the direction of travel. I've never seen floating disks with that much play.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 06-03-2014, 01:41 PM   #655
RobZorba
RobZorba
RobZorba's Avatar
Oddometer: 405
Originally Posted by Bundu View Post
Hi Bundu,
Thanks for posting the YouTube clip. That amount of fore / aft play is certainly not supposed to happen. Have your 'bike front disks always been like that, or have the disks or mounting rings worn like that over time? It's something I'll add to the checklist on my R, so thanks for the alert.
Suzuki VStrom 650 ABS, Honda ST1300, Suzuki SV650, Yamaha RD250
RobZorba is offline   Reply With Quote
Old 06-03-2014, 07:21 PM   #656
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,735
I thought some of the 990 LC8s had this problem... I'll see if I can find it.
Edit: Here are a few
http://www.advrider.com/forums/showthread.php?t=917813
v8toilet screwed with this post 06-03-2014 at 07:29 PM
v8toilet is offline   Reply With Quote
Old 06-03-2014, 08:58 PM   #657
Bluesilver
Bluesilver's Avatar
Oddometer: 340
Originally Posted by RobZorba View Post
Hi Bundu,
HELL...did you see scour marks on that bikes disk......
Old 06-04-2014, 03:00 AM   #658
Bundu
Bundu's Avatar
Oddometer: 675
Hi Bundu,
luckily not my bike saw the video on a German forum
Old 06-04-2014, 05:47 AM   #659
Black Hills
Oddometer: 1,207
MIne is exactly like the video as was my '11 990R
Old 06-05-2014, 09:02 PM   #660
Doug Matson
Doug Matson's Avatar
Oddometer: 1,937
I rode with two other 1190's yesterday and asked them about the disk noise and told them what i had discovered was the cause for mine. They both had the same noise, my 950 had floating disks and they never moved for and aft enough to make this clicking noise plus it has taken 1000 mile for this to appear but as long as it doesn't get any worse I won't worry about it.
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
67' Triumph Bonneville
70' CB 350
65' CB 160
Doug Matson is offline   Reply With Quote
Times are GMT -7.   It's 08:45 AM.
