Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-27-2014, 01:48 PM   #676
Black Hills
Oddometer: 1,235
Originally Posted by Mugatu View Post
Install a tutoro oiler / scottoiler, see, one problem gone
good idea...why didn't I think of that??
Black Hills is offline   Reply With Quote
Old 06-27-2014, 06:12 PM   #677
PS-RagE
PS-RagE's Avatar
Oddometer: 642
Originally Posted by CHRIS_D View Post
I heard the fix is to keep the traction control on.....
Originally Posted by Black Hills View Post
in my financial analysis the amount of money spent on extra tires is well worth the extra smiles no TC generates
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
2014 KTM 1190 Adventure R
PS-RagE is offline   Reply With Quote
Old 06-28-2014, 04:53 PM   #678
Harpinc
Oddometer: 15
I don't know how to copy a prior post yet but in regards to the comment that floating brake rotors on these bikes don't move. FLOATING ROTORS always move hence the name floating.
Harpinc is offline   Reply With Quote
Old 06-29-2014, 12:25 PM   #679
RobZorba
RobZorba
RobZorba's Avatar
Oddometer: 432
Yes, they are designed to move sideways at right angles to the rotation of the wheel. The problem reported and photographed by an inmate is that on his 'bike the U-shaped slots had worn in the direction of rotation, allowing the "floating rotor" to move forwards and backwards as well as sideways. This then produced vibration/ chatter especially when the ABS was modulating the brakes.
KTM 1290 SA, KTM 1190R, Suzuki VStrom 650 ABS, Honda ST1300, Suzuki SV650, Yamaha RD250
RobZorba is offline   Reply With Quote
Old 06-29-2014, 04:09 PM   #680
JETJOCK125
Oddometer: 8
Rear brake rotor is hot after riding. Front is just warm. I am making sure I'm not resting my foot on the pedal. reservoir is below max and free play is 6 MM. On the center stand, it is not dragging.
Any ideas?
________________________
2014 1190R, 2013 300 XC-W
JETJOCK125 is offline   Reply With Quote
Old 06-30-2014, 04:33 AM   #681
RobZorba
RobZorba
RobZorba's Avatar
Oddometer: 432
Any ideas?
Is the rear rotor scratched at all? If so there could be a small stone embedded in the rear pads. If that is OK, then water or air contamination in the rear brake fluid circuit could cause the symptoms you describe. Get the dealer to drain, replace and bleed the rear brake fluid following the procedure in the service manual.
Old 06-30-2014, 07:44 AM   #682
PS-RagE
PS-RagE's Avatar
Oddometer: 642
Check that the pedal return spring is not broken
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
Old 07-01-2014, 09:48 AM   #683
tagentry
Northwest Silverback
tagentry's Avatar
Oddometer: 34
Steering Head Bearings aka headset
My headset has loosened after only 1500 miles. I understand it's a common issue, but I'm wondering if I will have to check it every 1K miles or was it just too loose from the factory and an annual/semi-annual inspection will do?
tagentry is offline   Reply With Quote
Old 07-01-2014, 11:20 AM   #684
umitc
umitc's Avatar
Oddometer: 353
Mine loosened too; now I am travelling, loosened again. By the way, when I started the trip, resetted the Trip 2, last week at roughly 7500 km, suddenly Trip 2 resetted itself.
umitc is offline   Reply With Quote
Old 07-03-2014, 05:02 AM   #685
Bluesilver
Bluesilver's Avatar
Oddometer: 343
http://www.youtube.com/watch?v=__YGDMDZXoo
What GREAT advertising for KTM and their fully tested Adventure....having to be pulled started your entire trip cause your new bike is foobar from, dust....that guy must be riding a new GSA by now.....I know my attorney is.
Bluesilver is offline   Reply With Quote
Old 07-03-2014, 06:27 AM   #686
scudrunner82
combustion addict
scudrunner82's Avatar
Oddometer: 2,474
Pretty common thing to happen on new motorcycles. My 1190 did it, as well as a Super Tenere I used to have. Just remove the nut and dab a little loc-tite and torque to spec. It should stay tight from there out.
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is online now   Reply With Quote
Old 07-03-2014, 07:18 AM   #687
PS-RagE
PS-RagE's Avatar
Oddometer: 642
It must suck to hate your bike so much? Does it make you angry every time you look at it in your garage?
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
Old 07-03-2014, 07:43 AM   #688
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,110
How many pages ago was that video posted ?? old news Y a w n
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is online now   Reply With Quote
Old 07-03-2014, 07:47 AM   #689
scudrunner82
combustion addict
Oddometer: 2,474
People, please stop feeding the troll.
Old 07-03-2014, 07:01 PM   #690
motomuppet
Oddometer: 468
My headset has come loose for the fifth time now. First three times I took it too the dealer, as I figured they should be aware of it, and they should figure it out eventually. I was wrong. Forth time it came loose I did it myself...loosened the top fork bolts and the top triple clamp nut then tried to figure out how to tighten the wierd headset nut....and I snapped the wee tool I found in the standard tool kit that sort of fit! How are you guys torquing this thing down...what tool are you using? Anyone have a picture of the tool?
motomuppet is offline   Reply With Quote
Times are GMT -7.   It's 07:46 AM.
