Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 07-06-2014, 06:01 PM   #706
NorthVancpF
Oddometer: 141
I've only got 3k kilometers on my 14 1190 ADV ST but no problems at all. Just good riding! :)
NorthVancpF is offline   Reply With Quote
Old 07-06-2014, 11:00 PM   #707
speed_racer
speed_racer's Avatar
Oddometer: 707
Originally Posted by umitc View Post
Mine loosened too; now I am travelling, loosened again. By the way, when I started the trip, resetted the Trip 2, last week at roughly 7500 km, suddenly Trip 2 resetted itself.
i found it takes alot out of the battery each time you start it and have had it often reset both counters..
13' KTM 1190 Adventure R
KLX650R
RIP - BMW F650 GS Twin
speed_racer is offline   Reply With Quote
Old 07-15-2014, 06:02 AM   #708
IgorBorisenko
adventurer
IgorBorisenko's Avatar
Oddometer: 71
Question
I am having some oil leaks at the rear part of the back cylinder. Seams it starts at the ventilation hose connecting to the outlet. The dealer changed to a tighter clamp that holds the hose but the isuue is still there.
And now at 14 000 kms the igntion key became very hard to turn. It is a bit easier to turn it clockwise. But in the counter direction, especially to lock the stering - its a ton of force that is needed..
Any thoughts?
IgorBorisenko is offline   Reply With Quote
Old 07-15-2014, 06:28 PM   #709
Harold Waikiki
oldfatdumbbrokeoutof
Harold Waikiki's Avatar
Oddometer: 405
2014 1190r lost power at speed today.
Going 70+mph on paved road. Gas low but still one bar left. Pulled bike to side. Bike would start. Go 10 feet and die. Did this 3 times. I was hot. Worried. Got off bike with bike not running. Fucking dropped bike on its side. Got the fucker up. Bike then ran fine 3 miles to gas station. Filled up. Rode for 2 hours more off road. All good. WTF?? Ideas please!! Thanks!! HW.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
'09 KTM 950 SE Erzberg
'15 KTM 1290 SA ordered.
Harold Waikiki is offline   Reply With Quote
Old 07-15-2014, 06:41 PM   #710
scudrunner82
combustion addict
scudrunner82's Avatar
Oddometer: 2,653
Have you had the gas tank off recently? Perhaps you forgot to open the crossover valves on the bottom of the tank? That may cause your problem....
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is offline   Reply With Quote
Old 07-15-2014, 07:12 PM   #711
kag
Wander Lust
kag's Avatar
Oddometer: 1,744
Or pinched the vent hose just by riding and bouncing around, then when you dropped it, it vented and equalized the pressure letting fuel flow. Low fuel, hot motor, created increase vapor and pressure combined with a slight pinch in the line.....it's my guess
I just ordered the Rott Stage 3......getting rid of bunch of that mess under the tank and reducing the hoses.
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 07-15-2014, 07:45 PM   #712
scudrunner82
combustion addict
Oddometer: 2,653
Did they just release them? How much $$$ ??
My unifilter has been performing perfectly but I would consider trying the proven Rottweiler solution.
Old 07-15-2014, 08:17 PM   #713
kag
Wander Lust
kag's Avatar
Oddometer: 1,744
$90
This is not the filter, its the SAS stage 3.....I should been more clear....my bad
Old 07-20-2014, 01:30 AM   #714
Bluesilver
Bluesilver's Avatar
Oddometer: 359
oil pool above the intake valves?
Is is normal to see a oil pool above the intake valves, just refitted and greased my new uni filter and noticed the oil. Have done 3800km of tar riding and still found dust on the velocity stacks.
Bluesilver is offline   Reply With Quote
Old 07-20-2014, 02:09 AM   #715
wilmar13
Oddometer: 773
I am wondering something similar... not pooled oil, but carbon buildup from oil. Did it look like this?:
http://www.advrider.com/forums/showp...&postcount=767
'14 KTM 1190-R
wilmar13 is offline   Reply With Quote
Old 07-20-2014, 05:16 AM   #716
scudrunner82
combustion addict
Oddometer: 2,653
The intake valves pictured there look just fine to me. I've seen way worse than than on perfectly running engines.
Old 07-20-2014, 10:54 AM   #717
Bluesilver
Bluesilver's Avatar
Oddometer: 359
I have a pic but need to load to my notebook. My intake looks like new, oil clean but pooling at the valve seats that are closed.
Old 07-20-2014, 02:47 PM   #718
MysteryRider
Laughing at danger
MysteryRider's Avatar
Oddometer: 949
Any thoughts?
Tell them to change the o-ring.
That's what cured mine.
IBA#44072
93 Sportster Trike
06 HP2E (4-sale)
10 RoadGlide 120R
14 KTM 1190 Adv.
MysteryRider is offline   Reply With Quote
Old 07-20-2014, 09:35 PM   #719
Bluesilver
Bluesilver's Avatar
Oddometer: 359
Oil on intake Valve
As promised here is what I see.....this "acceptable"
Bluesilver screwed with this post 09-13-2014 at 02:25 AM
Old 07-26-2014, 05:20 PM   #720
rickescazu
Oddometer: 13
Had same issue for a month. Bike run fine then after a 20 min ride and a quick errand acted like it was out of gas. Run for 10-30 sec then stall like no gas.
Been in shop. Month so far they did a ECU update, checked the fuel pump and I'm told filters but they don't know why it's dong it. Sucks now have 0 confidence to ride very far.
I'm trying to get anyone at factory to help before I go by. Duc or BMW...
rickescazu screwed with this post 07-27-2014 at 07:13 PM
rickescazu is offline   Reply With Quote
Times are GMT -7.   It's 10:00 AM.
