Old 07-25-2013, 03:48 PM   #1
brittrunyon OP
R 100 GS F 650 GS
brittrunyon's Avatar
Oddometer: 523
Tire Bead Leak.............
When I mounted this Heidenau K60 Scout all was prefect,
..............seated with a little extra psi
..............used conventional tire lube from Napa
..............held air weeks at a time, not needing topping off
Now, after 1,700 miles it will not hold air overnight
The only leaks I find are at the bead.
The plan is to unseat the tire, slap on some lube bwt the tire & rim & reinflate.
After all this time,
..........was there something done at installation to cause a delayed bead leak?
..........has anyone had this happen?
What gives?
1992 R 100 GS (ZED)
2007 F 650 GS
My Motorcycle Videos & More @ http://vimeo.com/user2721333
Big Bend Ride Report @ http://brittrunyon.com/
brittrunyon is offline   Reply With Quote
Old 07-25-2013, 04:21 PM   #2
tennessee thumper
now in Mt. View, AR
tennessee thumper's Avatar
Oddometer: 739
Leaky Heidi
Yes...happened to me not long after I got my first Heidi front tire. It happened in cold weather first while out in the bush in Big Bend, TX.
Was running tubeless then...happened a few times when I got back, put a tube in and no issues.
It just started happening on the Heidi rear this month. No bubbles on the rear like the front when I soap it up to check.
Front is a known issue, there is a thread here from a year or so ago about this. Apparently Heidi knows about it but has yet to change the mold to better fit the GS rims. That what I remember from the thread...to take that for what it's worth.
As to my rear tire leaking...it's odd since the temp is not getting too low.
My anecdotal evidence says it's temprature changes of 20 degrees or more that change may cause the rim/bead situation to change with temp fluctuation. Since it's happening on the rear in 90 degree weather it's not exactly temp related...it seems to be the drastic or rapid change in temps that effect the bead.
I'll add a tube to the rear and make sure my pump is working good. Kind of a bummer because I really like the tires. Good news is you could still make it home tubeless if the tube went flat...so there is that?
Good luck
tennessee thumper is offline   Reply With Quote
Old 07-25-2013, 06:16 PM   #3
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,545
Not a new problem........yikes
Old 07-25-2013, 06:48 PM   #4
brittrunyon OP
R 100 GS F 650 GS
Oddometer: 523
That explains everything!
Thanks for the link!
1992 R 100 GS (ZED)
2007 F 650 GS
Old 07-26-2013, 03:49 AM   #5
orangebear
orangebear's Avatar
Oddometer: 1,253
My front tire started to leak so i fitted a tub in my tubless as there was loads of like left in it
suzuki gsxr 600 srad sound fun bike
bmw r100gs i sold as it be came to unreliable.
road legal stomp pitbike sold
Klr 650 the worst ever made
Honda xl125rc powered by a cg125 block fun wee bike
orangebear is offline   Reply With Quote
Old 07-26-2013, 08:48 AM   #6
tennessee thumper
now in Mt. View, AR
Oddometer: 739
Good find on the link, thanks. I knew it was in here somewhere.
For what it's worth, I'll be sticking with the Heidi rear, love the wear and grip, perfect for my needs. Will run a tube an have the tubeless capability as a back up when the tube fails (and it will).
Going to go TKC on the front when the Heidi runs out. Had the TKC/Heidi combo for a short time and really liked it.
Also of note on the linked thread, clean those rims, huh? A little scotch brite to make sure everthing is smooth and clean. Duly noted.
Old 07-27-2013, 01:52 AM   #7
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,013
And use for-real tire lube, like Ru-Glyde (used dish soap for may years, but the Ru-Glyde makes a world of difference)
--Bill
'73 R60/5 Toaster
Old 07-27-2013, 02:07 AM   #8
Phreaky Phil
Oddometer: 1,870
The buildup of rubber on the rim over time will cause this. When changing tyres the rims where the bead seats needs to be cleaned and sometimes sanded to give a good seal. I need to do this again myself, my front tyre goes down daily.
Phreaky Phil is offline   Reply With Quote
Old 07-30-2013, 04:28 PM   #9
brittrunyon OP
R 100 GS F 650 GS
Oddometer: 523
Wish I had known this about the Heidenau K60 Scout before now........
.............I un-mounted the tire
.............cleaned the rim to the point of "super" clean
.............remounted the tire with NAPA tire mounting lube
Still it leaks at the bead
Yes, looks likes it's tube time.
Maybe I'll try the TKC up front next, thanks for the tip!
1992 R 100 GS (ZED)
2007 F 650 GS
Old 07-30-2013, 08:08 PM   #10
bmwrench
Oddometer: 2,198
"Tech" makes a bead sealant, but I have seen the old tar-based Permatex sealants used to stop a bead leak. I hate to use a tube if I can avoid it.
The last GS I saw with a bead leak had a badly damaged rim. Someone had hacked it with tire irons.
bmwrench is offline   Reply With Quote
Old 08-04-2013, 03:25 PM   #11
brittrunyon OP
R 100 GS F 650 GS
Oddometer: 523
Thanks bmwrench...
I too hate using a tube in a tubeless tire...........
Got myself a quart of NAPA bead sealer and applied........
Inflated the tire to 50 psi & it seated without problem.........
Pulled the valve stem core & let the tire sit for 3hrs without pressure, enough time for the bead sealer to cure (I hoped).....
Inflated & found two very small leaks at the bead..........
Maybe I can live with this............I do have a tube on hand.............
In the future I'll be looking for a different tire so as to avoid this problem..........
Thanks all for your input
1992 R 100 GS (ZED)
2007 F 650 GS
Old 08-04-2013, 06:11 PM   #12
LongWays
Skiing up a hill...
LongWays's Avatar
Location: City of Subdued Excitement.... no really it is!
Oddometer: 5,212
Originally Posted by brittrunyon View Post
T
No shit. Can't believe how much work it is taking to get these tires to work on the R100GSPD. Thought I had it covered but found one more spot where the air is leaking so the rear is coming off yet again. What a pain in the ass. Think I'll just stick with the TKC-80s from now on.
If you don't like my sig line - don't read it.
LongWays is offline   Reply With Quote
Old 08-04-2013, 07:04 PM   #13
klrzorn
klrzorn's Avatar
Oddometer: 826
I had the heidinau on the front of my 92 gs, ran it for about 2 months, and then it started leaking down. It totally deflated, and broke the bead on an exit ramp. I took it back to the dealer, and the dealer replaced it with a new front tire of my choice. I 'm running a Karoo 3 up front.
My back tire was a Heidinau also. It never leaked, and I wore it down pretty good, but it started losing chunks of rubber right at the edge where it still had pretty good tread. When I removed it, it had cracks all the way around the edges.
I won't run them anymore. I've run TKC 80s bald, and never had any issues. I just have to remove a little tread on the paralever side for clearance.
klrzorn is offline   Reply With Quote
Old 08-12-2013, 06:26 PM   #14
LongWays
Skiing up a hill...
LongWays's Avatar
Oddometer: 5,212
My bad, dynabeads got up in between the tire and wheel. Cleaned them out and the rear is holding air. Front still has a tube...
Old 08-13-2013, 03:44 AM   #15
Beemerboff
Oddometer: 2,332
My GS rims never held air no matter what tires I fitted, and I just got used to using tubes.
I can't feel any difference riding the bike, the tires if anything feel cooler, and I haven't has a flat since.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Times are GMT -7.   It's 01:51 PM.
