Old 07-25-2013, 10:13 PM   #16
tommcbride OP
tommcbride's Avatar
Oddometer: 1,084
Originally Posted by Spark Plug View Post
I looked for one when mine died on my 85 G/S.
Ended up going this route and couldn't be happier. http://www.motoelekt.com/ignition.htm
HI Spark Plug,
Haven't ruled this out.....I'm just stuborn & looking for a stock replacement.
If this Hall Effect Sensor remains illusive,...I'll consider..thanks :-)
Tom McBride
tommcbride is offline   Reply With Quote
Old 07-25-2013, 11:34 PM   #17
Plaka
Brevis illi vita est
Oddometer: 4,608
hmmmm....
http://www.google.com/url?sa=t&rct=j...,d.aWc&cad=rja
Old 07-26-2013, 12:58 AM   #18
digger440
digger440's Avatar
Oddometer: 74
From Snowbum's page at
http://bmwmotorcycletech.info/Ignition.htm
"UNconfirmed information is that the Hall units may be found in 1979-85 VW; 1978-1983 Audi; 1979-1982 Porsche; and that Bosch 1237011052 may be the number."
Just food for thought
R100 cafefighter build in progress
http://www.customfighters.com/forums...ad.php?t=85610
digger440 is offline   Reply With Quote
Old 07-26-2013, 05:55 AM   #19
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,462
It would be useful if someone who has (or thinks they have) an automobile model and year with a suitable Hall effect sensor to post that information. For example, a 1968 BMW 2002 voltage regulator will work in a BMW airhead charging system. However, even if the automobile Hall effect sensor is correct type it still may not be suitable for installation in an airhead - or only offered as part of a replacement distributor.
Stan_R80/7 screwed with this post 07-26-2013 at 06:02 AM
Stan_R80/7 is offline   Reply With Quote
Old 07-26-2013, 07:34 AM   #20
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 835
http://advrider.com/forums/showthread.php?t=823543
My can has two.
Bulldust is offline   Reply With Quote
Old 07-26-2013, 04:20 PM   #21
tommcbride OP
tommcbride's Avatar
Oddometer: 1,084
An update for those interested
An update from Onlinecomponents:
Sir
This was discontinued by Honeywell when the division to which it belonged was sold to Sensata Technologies a few years ago.
They do not offer a comparable product and I am not immediately aware of a similar product being offered by our other vendors.
I placed an inquiry with Sensata to find out for you if they still support this and if so, through whom you would be able to purchase it.
Will advise.
Thank you for your inquiry.
Regards,
Product Technical Support
Onlinecomponents.com
www.onlinecomponents.com
__________________________________________________ _______________
Richard Yu, Jul 26 06:33 am (PDT):
Hello Tom,
Honeywell p/n: 2AV54 has been discontinued with no current replacements available.
If you're looking for an alternative part you can email contact our technical support department at techsupport@onlinecomponents.com
Regards,
Richard Yu
P: 702-462-7300
E: richard@onlinecomponents.com
Sent: Friday, July 26, 2013 9:48 AM
To: techsupportolc
Subject: Honeywell p/n 2AV54
Hello,
I am in search of this Honeywell p/n: 2AV54 (or comparable replacement)
are you able to advise on this?
Any assistance is appreciated.
Tom McBride
Tom McBride
Tom McBride
Old 07-26-2013, 06:37 PM   #22
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,192
Might be time to check into alternative technologies. I wonder about using an LED with a sensor behind the notch.
Wirespokes is online now   Reply With Quote
Old 07-26-2013, 09:04 PM   #23
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,560
$40 posted to NA. I can source the HME301 HES from a local electronics shop. It works fine. If I bought them in bulk they'd be cheaper, but on demand is a better option. As many in a box less than 500gms...the postage is unchanged.
boxerboy81 screwed with this post 08-03-2014 at 09:05 PM
boxerboy81 is offline   Reply With Quote
Old 07-26-2013, 09:06 PM   #24
Warin
Retired
Oddometer: 2,208
No. Consider what happens to the light when it is dirty, or water flooded.
The 'other technology' used is a reluctance coil, or a pick up coil. But light sensing was given up a long time ago.
Warin is online now   Reply With Quote
Old 07-26-2013, 09:27 PM   #25
Plaka
Oddometer: 4,608
The Lumenition Optronic system has no troubles. I had one in my Rover and that engine got pretty flooded every so often. It's UV light, not visible.
The inside of your beancan stays pretty clean and dry anyway. if it didn't all the points-in-can bikes would have died long ago.
Old 07-27-2013, 12:39 AM   #26
Warin
Retired
Oddometer: 2,208
UV ... or the other side - InfraRed?
Either way light gets blocked by dirt, bent by water.
How many manufactures use a light based system in a production vehicle? The vast majority use a reluctance sensor or a hall effect.
Old 07-27-2013, 03:08 AM   #27
_cy_
Oddometer: 6,321
here's how Lumenition optical ignition system is laid out. note optical disc that sits below ignition rotor has lobes that match number of cylinders. a four cylinder disc could be easily modded to two lobes. years back sold 200+ Lumenition systems for British sports cars. very reliable, very few come backs.
much easier to find a beancan with points
_cy_ screwed with this post 07-27-2013 at 03:14 AM
Old 07-27-2013, 04:49 AM   #28
Plaka
Oddometer: 4,608
google it.
I made two points. The first concerning the realities of a londstanding successful manufactured product, seems to conflict with your armchair theorizing.
The second, concerning the cleanliness of the conditions that the sensor operates under, you conveniently ignore.
You do not know what's under the hood of everything out there. You have never designed and built equipment using optical sensors (I have, FWIW). Neither of us knows why capacitive sensors are used in some vehicles and opticals in others.
Old 07-27-2013, 04:49 AM   #29
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,462
And here it is: Ta-da
Originally Posted by boxerboy81 View Post
$20.
boxerboy81 did not state: Ta-da! Behold, the Siemens HKZ101S replacement Hall effect vane sensor for the (obsolete) Honeywell 2AV54.
Edit: I try not to brag about my Google-fu, but sometimes it just comes out: http://robfrankham.co.uk/bike/replac...ect_sensor.htm
Stan_R80/7 screwed with this post 07-27-2013 at 05:16 AM
Old 07-27-2013, 05:04 AM   #30
Plaka
Oddometer: 4,608
http://www.bbautomacao.com/products.asp?cat=14
Times are GMT -7.   It's 06:54 PM.
