Old 07-26-2013, 07:12 PM   #1
picinisco OP
Scottish Transplant
picinisco's Avatar
Oddometer: 468
suzuki wheels on airhead
I am planning on installing DR650 forks on my R100/7 project. I do not yet have a wheel. Will any Suzuki wheel fit those forks and axle? RM125, RM250, etc
Cheers...John - 2004 BMW R1150GS, 1978 R100 (G/S Frankenbike)
Bikes That have Moved On:
1978 Suzuki GS550E, 1978 Kawasaki KZ1000P, 1982 Honda XL500R, 1995 BMW R1100RSL
picinisco is offline   Reply With Quote
Old 07-26-2013, 07:32 PM   #2
walkingbear
walkingbear's Avatar
Oddometer: 3,425
Doing mine on a R80/7
I have the forks and I will be using the airhead rim.
http://www.advrider.com/forums/showthread.php?t=906086
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 07-26-2013, 09:49 PM   #3
mendoje
Oddometer: 235
I'm thinking not...
Found this post on DR650 wheels...
http://drriders.com/topic6434-10.html "The DR650 front wheel is pretty much only compatible with the DR forks... the DR250 is the only other match..."
From the link above, sounds like the brake rotor is what makes it different. You might want to research a Suzuki parts fiche website to see which parts are interchangeable between RMs and DRs, to see if you can make RM wheels work. But it looks like there is a fair number of DR250 and 650 front wheels on eBay right now.
FWIW, complete RM125/250 wheel assembly (wheel/hub/bearings/rotor) are a direct bolt on to DRZ/KLX 400 forks/axle/spacers/brake caliper.
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1993 Suzuki RMX250 / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike )
mendoje is offline   Reply With Quote
Old 07-26-2013, 10:01 PM   #4
picinisco OP
Scottish Transplant
picinisco's Avatar
Oddometer: 468
Originally Posted by mendoje View Post
I'm thinking not...
Thanks for the answer and the link. Saves me some dissapointment.
Old 07-26-2013, 10:02 PM   #5
walkingbear
Oddometer: 3,425
I'm thinking not...
DR650 front forks and airhead wheel
http://www.bikeexif.com/bmw-r80-crowe-customs
Old 07-26-2013, 11:46 PM   #6
picinisco OP
Scottish Transplant
picinisco's Avatar
Oddometer: 468
The BMW wheel I've got is drum
Old 07-26-2013, 11:52 PM   #7
PeterW
Oddometer: 2,595
Gets messy, but DL 650 lower legs and wheels fit DR 650 tubes, though the tubes may need to be shortened. That gives you dual disk stoppers.
That's been done to get more front travel on DL's.
Pete
PeterW is offline   Reply With Quote
Old 07-27-2013, 07:47 PM   #8
walkingbear
Oddometer: 3,425
EZ fix find a single disc BMW front rim.
Times are GMT -7.   It's 06:21 AM.
