Old 07-27-2013, 06:48 AM   #1
trabbart OP
hellrider
Oddometer: 46
Pissed damn,,,rpm gauge does not work after short under tank
well my tank came loose when riding,it moved backwards and dropped ,,, it must have made contact somewhere, bike started to backfire and a red light came on, i secured the tank, but that short dammaged something ,,,my rpm gauge does not work anymore, the light on the gauge works, but the needle does not move , , , , first it still moved , but not accurate,,,but now its dead,,,,,, any thoughts / tips ?
trabbart is offline   Reply With Quote
Old 07-27-2013, 06:57 AM   #2
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,989
It must the the tachometer cable being shorted against a muffler bearing. Do te turn signal work? If so, you might have also had a blinker fluid leak...
'73 R60/5 Toaster
Old 07-27-2013, 07:03 AM   #3
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
You don't say what bike.
On a bike with the 2 6V coils under the tank (5/6/7 up to '84) there might be one of the coil terminals (the one that is connected to the rpm gauge) shortened constantly to the tank. That would explain your rpm gauge not working. I am not sure whether the bike would run in case of a short.
You'll see arcing marks on the underside of the tank.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 07-27-2013, 07:31 AM   #4
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,747
I'm going to have to agree with this. Or, the tank's inner fuel inertia relay was triggered into a false reading, so now your tachometer is receiving too much voltage.
Have you opened the tank yet to check this? There are seams underneath....
(please go to a mechanic, do not listen to me........)
Black Shadow of Vincent, falls on a Triumph line
I've got my motorcycle jacket but I'm walking all the time...
Zodiac is offline   Reply With Quote
Old 07-27-2013, 07:34 AM   #5
trabbart OP
hellrider
Oddometer: 46
an 81 r100rs, i dont have blinkers anymore, its a cafe racer,
i checked again , there was a short indeed, one coilwire touched the tank, gauge works again,,,,,glad it does, i bought that instrumentpanel only a few months ago ,,,
thank you guys,,,i was thinking it was inside the gauge burned up or something,,,, glad it works again
trabbart screwed with this post 07-27-2013 at 07:41 AM
Times are GMT -7.   It's 12:54 AM.
