Old 07-28-2013, 04:36 PM   #1
flux_capacitor OP
I know a shortcut!
flux_capacitor's Avatar
Oddometer: 9,619
Doing the points on your OEM fuel pump? Have some free advice.
Here's the biggest lesson I learned while repairing my poorly running 950's stock fuel pump.
Make sure the little tab attached to a spring fits into the groove on the shaft of the fuel pump before you button everything back up. Its an easy detail to miss, and not one I knew about til my friend Jeff mentioned it to me. I had replaced the points and my bike still would not start and I was having big issues chasing the problem. Once I took the pump back apart, and saw that tab wasn't in the groove, and fixed it, the bike fired right up.
Also, you should be able to just plug the fuel pump back into the wiring harness (without even hooking it up to the fuel lines), turn your key on, and the pump will (should) make the familiar clicking noise we all love.
Cheers.
flux_capacitor is offline   Reply With Quote
Old 07-28-2013, 05:03 PM   #2
mjlang
Man Caves Rule!
mjlang's Avatar
Oddometer: 169
If you do a search, there is a guy from Holland selling a solid state electronic update to the pump. It makes that pump bullet proof for 50 euro. Forget the points.
If it flys, f*cks, or floats... RENT IT!
'06 KTM 950 Adventure S
'07 KTM 450 EXC
mjlang is offline   Reply With Quote
Old 07-29-2013, 07:46 AM   #3
SpeedyR
SE in the SE
Oddometer: 854
main advantage for most is that (at least for me) the local shop has the points in stock and they are $28. It's the same points kit that goes into a lot of the modern bikes fuel pumps.
I'll eventually switch over to an alternative fuel delivery system (more than likely the Mikuni vacuum pump as it's one of the only ones I've read about very few failures), and at that time my stock pump will become my backup.
here was a good writeup I found on the points replacement from the CBR forum:
http://cbrforum.com/forum/stickies-9...l-pump-102151/
in this writeup, he mentions the points fitting in the groove on the shaft which I didn't find on many other threads on ADV, so when mine wasn't working, I went back and found the CBR writeup and read thru it, looked online for other photos showing the exact placement of the points in the groove and mine fired right up. when mark described about the same sound (just one "pump" but not the usual "studder" when you flip the switch) I suggested he check that slot. bingo!
so if you want to replace your points with new points, this is the tip to make sure it works correctly.
if you want to replace it with a solid state system, the Dr. Beans kit is the way to go but at least for us US folks, my guess is it's at least a few days away or more (and a bit more money but not much).
good riding with you this weekend flux!
SpeedyR is offline   Reply With Quote
Old 07-29-2013, 09:45 AM   #4
EZ300
EZ300's Avatar
Oddometer: 1,009
Link?
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 07-29-2013, 10:32 AM   #5
twwhitey
twwhitey's Avatar
Oddometer: 91
Originally Posted by EZ300 View Post
Link?
You can contact him (Dr. Bean) here on Advrider
http://www.advrider.com/forums/showthread.php?t=823347
'07 KTM 950 Super Enduro R
twwhitey is offline   Reply With Quote
Old 07-29-2013, 07:17 PM   #6
flux_capacitor OP
I know a shortcut!
Oddometer: 9,619
Dr Beans was out on holiday or something til end of August so that wasn't happening for me.
I've got an entire Facet pump assembly sitting on a shelf for when this one goes out again.
Old 07-30-2013, 07:05 AM   #7
ABuck99
0.0
ABuck99's Avatar
Oddometer: 582
Flux: Excellent update to the FP points replacement process.
The only reason I see to install the Dr bean kit is to eliminate the issue of the points contacts from wearing out. The Bean kit doesnt change anything else with the pump delivery, and there are other durability concerns that come to mind with a circuit board, that at times will be under water, exposed to prolonged heat and vibration. So while the Dr Bean Kit is a nice solution, its not always available, and its pricey for us on this side of the pond. Personally, 20,000 miles out of my first set of points was an acceptable result. And for under $30 you can re-new the points with a fresh kit. But for a just a dollar or two more its possible to make your own solid state pump mod by adding a simple radio shack diode which would in theory extend the life of the points. ( in simple terms by cleaning up the current).
I read about a mod to effectively create a solid state circuit by simply adding a diode to the FP points. I found this "how to" on a Honda Deauville forum, that explains in detail how to add the diode to the Mitsubishi FP points to extend their life span. This mod in theory would match the result that the Dr Bean kit delivers, longer FP life. **I have not personally done this mod.
http://hankeln.net/freizeit/nt650v5/...-diode_en.html
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 07-30-2013, 04:37 PM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,884
Installing a diode on the Mitsubishi fp
[QUOTE=ABuck99;21986042 But for a just a dollar or two more its possible to make your own solid state pump mod by adding a simple radio shack diode which would in theory extend the life of the points. ( in simple terms by cleaning up the current).[/QUOTE]
There is already a diode on the OEM fp.
Dr Bean's solution is far superior to all other solutions. It elliminates the points, but keeps the basic characteristics of the OEM operation. Infrared sensor sees if the core shaft has moved too low and then powers up the coil and runs again.
Cheers.
gefr is online now   Reply With Quote
Old 07-31-2013, 11:03 PM   #9
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,782
Cheers.
Its good idea to take a digital picture before and after for items like this and carb vents lines & hoses etc to refer to for comparison.
Motorcycles . . . my Happy medicine.
“One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure.” – Steve McQueen
2014 Wee2,Vee2, NC7X: http://s836.photobucket.com/user/Twm...21297.jpg.html
mcmann is offline   Reply With Quote
Old 08-01-2013, 01:54 AM   #10
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 581
The OE Mitsubishi pump is know to be very reliable, except for the points.
If you add a diode, and run the pump before replacing its cap, you'll still see arcing at the points. Less arcing, but still arcing. You can expect longer service life, but it will not be fit and forget. In my view, Dr Bean's solution is the way to go. It's well made.
I replaced my Facet with a Dr Bean-ised OE pump, as the external wiring on the Facet is of poor quality and not suitable for the semi-exposed and hot area in which it is installed.
The fact that vacuum pumps need battery sapping engine cranking in order to prime puts me off, as the OE battery is already on the small side.
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 08-10-2013, 05:21 AM   #11
flux_capacitor OP
I know a shortcut!
Oddometer: 9,619
Yup you are right, that IS a good idea. Not sure I would have noticed this little groove though. And I never saw it mentioned in any of the HUNDREDS of posts about fuel pumps going bad that I read through. Kinda makes me wonder how many GOOD fuel pumps there have been that were deemed garbage because this detail was missed.
Old 08-10-2013, 06:48 AM   #12
Skinner
Mr.KTM
Skinner's Avatar
Oddometer: 5,709
Have there been any improvements to the fuelpump, do i need to be concerned about my 2013 990?
You might be an ADVRider if:
You recognize your friends by the sound of their mufflers.
http://www.meetup.com/Chicagoland-Du...torcycle-Club/
www.jimstarwaltteam.com
Skinner is offline   Reply With Quote
Old 08-10-2013, 07:52 AM   #13
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,237
This thread pertains to the fuel pump on the early carbureted models. Pump on the injected bikes is a different animal.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 11-22-2013, 07:39 PM   #14
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,704
Thought I'd add a quick update to this thread. My 950 SE fuel pump died last night (first fuel pump failure in 4 different LC8's and 60,000 miles). I needed to get it fixed fast (today) so I can make a track day tomorrow so I went searching for points. Turns out the same pump is use on Kawi ZX-6, ZX-7 an ZX-9 models, Kawi Vulcans and Honda CBR 600 F3's all from about the 2002 era. Also, K&L supply makes a replacement part for the points. It is part number 18-4615 an I picked up a set from Parts Unlimited today for $23. Not too bad and I got the bike going for my track day!
07 Yamaha R6
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 11-22-2013, 08:17 PM   #15
GrenDesb
Oddometer: 322
Dr. Bean kit, all the way.
Arrived to Canada in 5 days from Holland.
Great instruction sheet, easy enough to install and works perfect for as long as you'll own the bike.
GrenDesb is offline   Reply With Quote
Times are GMT -7.   It's 11:37 PM.
