Old 07-28-2013, 04:48 PM   #1
Enduronut357 OP
Oddometer: 36
how much smoke is normal on first start up?
when i first start my dt400 up in the morning it smokes enough to create a blue haze across the street lol it fires up in 2 to 3 kicks when cold and one when warm . it also fouls spark plugs every two weeks
Enduronut357 is offline   Reply With Quote
Old 07-28-2013, 04:57 PM   #2
PistonPants
Crankcase Scavenger
PistonPants's Avatar
Oddometer: 453
Does your DT still inject oil or do you premix? So when you leave home, figure out how far a float bowl of gas will take you (warm it up, shut off the gas, ride til it runs out). Then every time on the way home, remember to shut off the gas at this place and run your carb out. This is my practice for my premix bikes. Hope it helps.
Peace
Piston
PistonPants is offline   Reply With Quote
Old 07-28-2013, 05:09 PM   #3
Enduronut357 OP
Oddometer: 36
it still injects i don't premix at all
Old 07-28-2013, 05:19 PM   #4
joexr
Oddometer: 3,773
Smoke is normal , plug fouling is not. Is you airfilter clean? Check out the enrichener plungers sealing tip.
Old 07-28-2013, 07:19 PM   #5
slideways
permanent ex-pat
slideways's Avatar
Oddometer: 5,851
Also check needle valve seat and float height.
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
Upper Italian Lakes report.
http://www.advrider.com/forums/showthread.php?t=160841
South Africa, Swaziland, Botswana ride report
http://www.advrider.com/forums/showthread.php?t=454490
Great CanAm Tour
http://www.advrider.com/forums/showthread.php?t=476605
slideways is offline   Reply With Quote
Old 07-28-2013, 08:20 PM   #6
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Do a leak down test. Yamaha strokers have an issue (not a bad thing IMHO) with holding a lot of oil in the crankcase. But with a bike that old and fouling plugs the crank seals are suspect. The transmission (right) side in your case. Does it use transmission lube?
you don't see luggage racks on a hearse..........act accordingly
Old 07-28-2013, 09:14 PM   #7
Enduronut357 OP
Oddometer: 36
nah no trans lube the dealer said to use 10 w 30 yamalube in the transmission leakdown test? how do i do that
Old 07-29-2013, 05:29 AM   #8
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Well the question is does the trans oil disappear?
And as far as a leakdown-this.
Old 07-29-2013, 10:12 AM   #9
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
I would also think the crank seals are at fault. They are 40 yrs old quite likely. Probably leaking on mag side as well as transcase side. Ethanol gas is especially hard on them.
buls4evr is offline   Reply With Quote
Old 07-29-2013, 10:59 AM   #10
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,375
My advice is to put all your DT400 stuff in one thread..you have the same questions bouncing around a few diferent threads you have started asking the same questions.
JeffS77 is offline   Reply With Quote
Old 07-30-2013, 05:15 AM   #11
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
You should realize though that your 3 threads are likely related in some way. Look at all 3 and take the good advice they offer.
Old 07-31-2013, 11:24 AM   #12
Tim McKittrick
Oddometer: 1,763
At the risk of actually answering a question....
All of the autolube bikes I have owned smoke a lot on startup if they have been sitting for a period. My worst is an Aprilia RS250, a v-twin road racer with it's front cylinder inclined at a steep angle. It smokes like a tire fire the first time I start it on a race weekend. I believe that even pump fed systems drool a bit of oil when parked, and this pooled oil is responsible for the smoking when the machine is restarted after sitting. Once warmed and "Cleared out" all of my autolube machines become much less smokey.
I don't want to re-ignite the oils debate, as it has devolved into tiresome circular arguing, other than to say in my experience some of the synthetic mix oils seem to make less smoke when they burn. The start-up smoke is less due to the oil type than to excess oil collecting when the bike sits, so a change of oil is probably not going to have a large effect.
Your plug fouling is not likely related to the smoke on startup, assuming the smoke level subsides once the engine is warmed and happy. The autolube pump on your DT is adjustable, however, and it's possible it may be over oiling. The adjustment is pretty rudimentary, if I recall, so it may well be worth checking.
Sadly, I don't have a manual in front of me to quote from. Anyone else care to provide specifics?
The plug fouling is more likely due to either an incorrect plug, mixture issue, or ignition timing issue.
Tim McKittrick is offline   Reply With Quote
Old 08-01-2013, 03:21 AM   #13
Flood
F5lood.
Flood's Avatar
Oddometer: 10,161
OK ladies, out of the 31 posts in this thread, I had to move 19 down to Head Explody as they only revolved about asshattery, counter-asshattery and identification and rationalization of who's a troll and who isn't.
As someone once said "civility is enforced in the on-topic forums". If you want to bang heads, there's a perfectly fine padded cell downstairs in Jo Momma. Or just tell us about your political leanings in CS&M! People love that crap down there and the mods there have a lot more patience than I do.
Thanks for your time,
Flood
ADV mod-creature.
TEAM F5
RallyRAIDio on Twitter
RallyRAIDio on Facebook
Flood is offline   Reply With Quote
Old 08-01-2013, 06:10 AM   #14
joexr
Oddometer: 3,773
Thumb
Flood
ADV mod-creature.
THANK YOU!
Old 08-01-2013, 11:18 PM   #15
*Gmoney*
don't look here
*Gmoney*'s Avatar
Oddometer: 911
This post may of helped me
I am having a flat spot on acceleration that I have not worked out.
Bought a CT2 with blown crank seals replaced them and have not work out this flat spot.
Its the one thing I have not checked.
I may get back to you if you do not mind.
Plug looks rich
leaner jet no change, worse
needle on middle grove.
Up or down on needle no better
*Gmoney* is offline   Reply With Quote
Times are GMT -7.   It's 02:46 AM.
