Old 08-02-2013, 06:16 AM   #16
anotherguy
anotherguy's Avatar
Oddometer: 6,207
Originally Posted by *Gmoney* View Post
This post may of helped me
I am having a flat spot on acceleration that I have not worked out.
Bought a CT2 with blown crank seals replaced them and have not work out this flat spot.
Its the one thing I have not checked.
I may get back to you if you do not mind.
Plug looks rich
leaner jet no change, worse
needle on middle grove.
Up or down on needle no better
Typical weak ignition. Cylinder pressure spikes as the engine hit the powerband and the spark has a rough time coping.
Old 08-02-2013, 02:16 PM   #17
Twin-shocker
Oddometer: 1,673
Plug looks rich
If your bike has points, then it might be a good idea to change them and at the same time fit a new condenser. If bike has been standing for a long while, you may have a porous float, which will tend to mean fuel level is too high. Easy enough to check, as you simply need to switch off fuel, and see if bike runs normally momentarily before it cuts due to lack of fuel.
Old 08-04-2013, 09:56 PM   #18
Enduronut357 OP
Oddometer: 36
it does not use any oil out of the transmission or crank case i have rode it for awhile and checked and none is missing
Enduronut357 is offline   Reply With Quote
Times are GMT -7.   It's 11:32 PM.
