Old 07-28-2013, 05:20 PM   #1
PistonPants OP
Crankcase Scavenger
PistonPants's Avatar
Oddometer: 459
Frankenstein KTM
I just inherited a wrench project. Such miserable shape I almost said no to a free bike. It is a KTM 250 SX (I think) of unknown vintage. Perhaps someone here could help me identify it. But it has leaky pogo stick forks, busted rear sprocket held on by only two remaining loose bolts, kickstarter held on with (not kidding) silicone. This one won't give it up easy. But at its heart lies bitchin strong 250 mx mill that should satisfy my intended use of winter ice rider/summer guest machine/backup extra wheels.
Just to get it rolling it needs chain and sprox. This is my first KTM, and it reminds me of the Husky's of my youth (plug eater). Do these bikes really require spendy plugs or do regular old B8ES ngk or the resistor variety suffice? Is the restoration of upside down WP forks best left to a shop? Is it far more involved than The conventional legs on my KDX?
So here's some pics of the mongrel:
Thanks for taking a look. Any advice or expertise on this mo-sheen woud be appreciated.
Peace
Piston
PistonPants is offline   Reply With Quote
Old 07-28-2013, 06:40 PM   #2
PistonPants OP
Crankcase Scavenger
Oddometer: 459
According to the VIN identification chart, it's a 2001 250 sx.
Old 07-29-2013, 09:27 AM   #3
dpforth
no inline fours
dpforth's Avatar
Oddometer: 337
BR*ES plugs will work fine. If it's oil fouling them you might want to look at the right side crank seal. My 360EXC will run for years on the same plug. Plastic is the same for all 2t bikes from 98 to 02 (maybe 03?). Lots of helpful KTM experts at KTMTalk.com. USD forks are different but not really scary. There should be lots of videos on Youtube that show breaking one down. WPs should be similar to the more common Showas and KYBs.
Nice score!
This species has amused itself to death
dpforth is offline   Reply With Quote
Old 07-30-2013, 12:37 PM   #4
PistonPants OP
Crankcase Scavenger
Oddometer: 459
Thanks for the input. New chain and sprockets are on the way. after a good cleanup and getting it rolling we'll see what else it needs to make it a fun and reliable backcountry bike.
Piston
Old 07-31-2013, 07:12 AM   #5
Spikester300
Roll Tide!
Spikester300's Avatar
Oddometer: 127
Tanks are on ebay frequently and most times at a good price. The forks are not hard to replace seals on.
2007 Suzuki DL650 V-Strom
1976 Suzuki GT750 Waterbuffalo
Spikester300 is offline   Reply With Quote
Old 08-01-2013, 05:53 AM   #6
davesupreme
grand poobah
Oddometer: 1,743
nah... that's a total POS.... you'll never make it happen... i'll take it off your hands just to save you the aggravation........ .....hehehehe....
davesupreme is online now   Reply With Quote
Old 08-02-2013, 07:34 PM   #7
Sp4rks
Oddometer: 247
Looks almost like my 02 125sx when I first got it(kinda worse, but I payed 1600$ for mine, I didn't know much about bikes at the time), it was owned down near the beach(read: salt water damage), has some "restored plastics(read: spray painted, wasn't even the correct shade of orange), slightly used air-filter(read: rotted out, falling into airbox), broken in tires(read: dry rotted, knobs about to break off), perfectly tuned suspension(read: fork seals blown), a strong engine(really strong, haven't done top end yet) and an alright chain(actually, not that bad, only replaced it recently). But hey, after some TLC(and a kickass KTM dealer, and kickass parents who supported the endeavor), it's "Ready to Race" bike now. Go for it, your results might be better than mine:
http://i1209.photobucket.com/albums/...g?t=1375494659
2002 KTM 125sx:
Acerbis Uniko handguards, KTM Powerparts skidplate, FMF Shorty Exhuast, FMF Fatty Expansion Chamber, Renthal Sprockets, Renthal Chain, Pirelli Hard Terrain tires, SDG Seat, Acerbis and UFO plastic.
Sp4rks is offline   Reply With Quote
Old 08-03-2013, 09:52 AM   #8
PistonPants OP
Crankcase Scavenger
Oddometer: 459
This one was owned by a friend who left Alaska in a Chevy Luv pickup and didn't have room for much worldly stuff. I promised it would get a good home. What is supposed to hold the kickstarter on? A nut on the end of the starter shaft? I don't dare remove the mass of blue silicone holding it on (it miraculously works). Probably needs a shaft and nut. Waiting on parts.
Piston
Old 08-03-2013, 09:11 PM   #9
dpforth
no inline fours
dpforth's Avatar
Oddometer: 337
Shaft should be tapped for an 8x20 screw and countersunk washer
Old 05-21-2014, 09:03 PM   #10
PistonPants OP
Crankcase Scavenger
Oddometer: 459
The project moves forward!
Long after taking possession of the bike, I received the briefcase of manuals, etc. from the PO. Turns out it's an mxc 250. It's current state:
The front forks are all rebuilt as well as fresh front wheel bearings!
My first set of inverted forks. It was educational.
Much of what I learned was mess control.
Issues yet: The kickstarter bolt stripped out and missing. The bushrat strategy on that is to tap the shaft out to 10mm and use a bigger bolt. Wish me luck. The exhauust pipe doesn't seat against the cylinder real good and some springs are missing. It also left a big oil puddle from sitting tilted forward with no wheel/forks. Leaky primary gasket? Or accumulated spooge leaked from the wonky exhaust? Both? The cleanup shall reveal.
The KDX is also torn apart with new fork seals, awaiting new tires. That leaves only the Pampera to ride:
As usual, a one-kick wonder after hibernating all winter.
Peace
Piston
Old 05-25-2014, 12:24 PM   #11
davesupreme
grand poobah
Oddometer: 1,743
that screw/washer thing is wonky on KTM's.... there is a 9mm tap you can get at supply houses that would probably work... i think it's a 1.25 thread, which i think is the same as your 8mm x 1.25 you got now....
i think....
Old 05-26-2014, 05:33 PM   #12
PistonPants OP
Crankcase Scavenger
Oddometer: 459
What i got now is a stripped out kicker shaft and a lever held on with blue silicone. I got a 10mm tap and bolt to do the duty.
Piston
Old 05-27-2014, 05:18 AM   #13
davesupreme
grand poobah
Oddometer: 1,743
the point is.... you use a 9mm tap, and you probably won't have to drill the hole, probably follow the the threads you still have.... 10mm?... good luck!...
Old 05-31-2014, 11:16 AM   #14
PistonPants OP
Crankcase Scavenger
Oddometer: 459
Inside the kick shaft, it looks as if the screw broke off and someone attempted to extract it but failed. The whole mess refuses to be drilled, so probably going to stick it back on with chewing gum and wait a few paychecks to get a new shaft and screw. Exhaust pipe srings, o-rings and brake caliper parts on the way. Time to re-assemble.
Piston
Old 05-31-2014, 11:23 AM   #15
PistonPants OP
Crankcase Scavenger
Oddometer: 459
$170. The free orphan KTM ain't free no more.
Piston
Times are GMT -7.   It's 11:02 AM.
