Old 09-24-2013, 06:51 PM   #121
DaddyGreenGenes
Delicious
Oddometer: 33
Try using two rim locks on opposite sides of the rear rim. I did that and only had to add about 35 grams of weight to balance out...
The 1 Man Riot
'12 Kawi Concours
'13 Suzuki DRZ400SM
'12 Suzuki DRZ 400SSM
'12 Christini 300 AWD
DaddyGreenGenes is offline   Reply With Quote
Old 09-26-2013, 11:14 AM   #122
WR_guy
Location: 96' Dr650 - 200 wr400f street legal -- Hot xr50
Oddometer: 883
Run a Tubliss in the rear and run 8-10# and you will be golden.
HD tube in the front.
More than 15# in the front tire and it starts to pound you to death on rocks.
WR_guy is offline   Reply With Quote
Old 09-26-2013, 03:04 PM   #123
DyrWolf
DyrWolf's Avatar
Oddometer: 108
!0 day weather forecast. Temps look great low 70s upper 40s. No rain so it will be dusty.
DyrWolf is offline   Reply With Quote
Old 09-26-2013, 07:20 PM   #124
kicktenmin
Oddometer: 158
Any one know what time the ride starts have to work fri night
kicktenmin is offline   Reply With Quote
Old 09-26-2013, 07:24 PM   #125
Scotty P
Funny Like a Clown
Scotty P's Avatar
Oddometer: 13,683
It doesn't matter.............it's not a race!!
xxxx- hrs about
edit:I was wrong
06 KLR 650 "FBG" 99 Triumph 885i Tiger "Girlie"
Smokehole after midnignt..."I'm hungry", "me too" How about some Bitches n Gravy?
I'm a thread bully with no Ragrets.
Scotty P screwed with this post 09-27-2013 at 09:35 AM
Scotty P is offline   Reply With Quote
Old 09-27-2013, 03:49 AM   #126
tjzondrz
I'm older now.
tjzondrz's Avatar
Oddometer: 1,622
8:00 AM Sat. & Sun.
Breakfast is from 6:00-8:00 Sat & Sun. at the camp.
" I'm your Huckleberry"
2012 DRZ400s
1980 IT175G
tjzondrz is offline   Reply With Quote
Old 09-27-2013, 04:37 AM   #127
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,462
Posted timetable: http://watr.us/docs/2013_S500_Info.pdf
Registration Sign-In and Tech Inspection:
Friday from 5:00 PM to 8:00 PM
Saturday & Sunday from 6:30 AM to 8:00 AM
Riders’ Meeting: Saturday & Sunday at 8:00 AM
The ride begins immediately following the riders' meeting both days - be prepared to start your ride. Sweep riders leave the campground at 9:00 AM
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 09-27-2013, 04:56 AM   #128
kicktenmin
Oddometer: 158
thanks need to read all that i got riding up from n.c sat am
Old 09-27-2013, 07:39 AM   #129
TRIPPEEE
ugh!
TRIPPEEE's Avatar
Oddometer: 30
Jousting
Are there restrictions to the length or type material of the lances one uses on the joust track at Natural Chimneys?
TRIPPEEE is offline   Reply With Quote
Old 09-27-2013, 07:52 AM   #130
TRIPPEEE
ugh!
TRIPPEEE's Avatar
Oddometer: 30
But seriously....
Alcohol
A) No person shall consume or possess an
open or previously opened container
containing any alcoholic beverage, or be
under the influence of an alcoholic beverage
while at any public parks and
recreation facility.
B) No person shall consume, possess or be
under the influence of any controlled
substance, as defined by the Code of
Virginia, while in public parks and recreation
facility.
Are these rules enforced?!? If so, I may have a camp spot available for sub-lease.
Old 09-27-2013, 09:26 AM   #131
tjzondrz
I'm older now.
tjzondrz's Avatar
Oddometer: 1,622
Originally Posted by TRIPPEEE View Post
Alcohol
under the influence.
Gee,
I HOPE NOT.
2012 DRZ400s
1980 IT175G
Old 09-27-2013, 09:54 AM   #132
screamin injin
FUBAR
screamin injin's Avatar
Oddometer: 2,519
Alcohol
facility.
Only if you draw attention to yourself.
screamin injin is offline   Reply With Quote
Old 09-29-2013, 11:16 PM   #133
Whitfield
Whitfield's Avatar
Oddometer: 196
So glad I made a practice run and installed a new front tire before the S-500. My Husky front axle nut was seized and required special attention to remove. No way I could have ever removed it trail side. Husky front axles are a hollow tube with a stop on one side and a countersunk plug threaded into the other.
Twisted my OEM tool kit 12mm hex key
I had to break out the big guns.
Whitfield screwed with this post 09-29-2013 at 11:56 PM
Whitfield is offline   Reply With Quote
Old 09-30-2013, 03:18 AM   #134
JustRon
ex-broadwayron
JustRon's Avatar
Oddometer: 1,287
You know about this, right?
Motosportz sells them. (I used to own a TE610.)
2010 Beta 520RR
Baja crash Report
JustRon is offline   Reply With Quote
Old 09-30-2013, 03:26 AM   #135
Whitfield
Whitfield's Avatar
Oddometer: 196
Thanks JustRon, I found these cool front axle nuts exist once I began searching for answers as to why mine was stuck. I need to order one up this AM.
Times are GMT -7.   It's 07:54 PM.
