Old 07-29-2013, 08:16 AM   #1
uk_mouse OP
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,475
Reducing fork stiction - ideas?
I've come to the conclusion that my forks are too sticky - they don't seem to react very well to small movements. And where they settle into a neutral position can be a couple of inches different depending on whether they were going from extended or compressed.
I read about removing the third bush from the fork leg (this is a 2004 S model, so 3 bushes plus a big spacer tube), and tried this but it gave what I thought was unacceptable play in the fork sliders.
So, are there any other ways I can address the problem? Different oil? Currently using Motul 5W oil, I have read suggestions that ATF can give less stiction. I've also got fork seal savers fitted (the neoprene tube type) which probably don't help matters.
I'm planning a quick service on the forks this week (new oil, clean seals etc) so thought I'd ask this question before I start just in case there's anything relatively easy I can try out.
Cheers all :)
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 07-29-2013, 08:31 AM   #2
btao
RIP Lilolita
Oddometer: 1,015
I use Manitou Prep M. Carryover from pedal power, but you will have zero stiction after. It's actually my go to grease for just about everything. Amazing stuff. Just apply liberally, preferably under the dust covers and then just pogo pogo pogo to work it down in there onto the bushings. Or you can take the fork apart, your choice. It's usually the seals that stick though.
_________________________
Current: '13 Tiger 800 XC, '09 Subi WRX, '11 405hp Sti (wifey's) Past: '74 Honda CB 360, '81 Yamaha 650 Special II, '01 Bandit 1200S, '07 Bandit 1250S
btao is offline   Reply With Quote
Old 07-29-2013, 08:55 AM   #3
Hootowl
Oddometer: 1,259
Switching to SKF seals will help
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 07-29-2013, 09:56 AM   #4
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 860
Cheers all :)
Honestly you have a multitude of options, and yes the early models have horrible issues with stiction.
I would immediately start by removing the 3rd bushing, and replacing the seals, wipers, and upper and lower bushings (can source directly through your local KTM dealer part # R14020 fork rebuild kit, you will have a few extra items as they are for the CC forks and comes with the SKF seals and much higher quality bushings)
I would recommend going with an oil like Maxima Racing fork fluid, or something along those lines. You do not need to spend $30.00 to $45.00 a quart on super slippery, or ultra slick fork fluid.
Having a local shop, or if you are capable of polishing the fork lowers along with doing all of the above mentioned mods will almost eliminate the stiction issues.
Getting rid of the 3rd bushing and sleeve immediately will be the starting point. As well toss the seal savers unless you clean them religiously.
Alex
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 07-29-2013, 02:53 PM   #5
D K
Oddometer: 482
Make sure they are the green ones
'13 EC300 Racing
’07 950SE - sold
’08 950SE - sold
’09 FE570 - sold
D K is offline   Reply With Quote
Old 07-29-2013, 04:10 PM   #6
Hootowl
Oddometer: 1,259
What is the life expectancy of those compared to OEM or another mfg?
'07 990A
'12 Super Tenere
Old 07-29-2013, 06:40 PM   #7
KM TUNER
Oddometer: 860
Depends on where you are riding and how often you clean your bike really. I have some customers in the Southwest that have well over 100 hours of hard off road use without any issues, then again I have other customers in the PNW and Canada that have gotten around 50 hours of hard off road use, the reasoning is do you ride in extremely muddy conditions or the opposite?
The SKF seals are coming standard on most KTM models nowadays and even on the 2013 BMW F800GS as the went with the 43mm WP fork. They are the best on the market at this point and time.
I’ve tested every seal on the market, hands down these are what you should be running, period.
Old 07-29-2013, 11:38 PM   #8
uk_mouse OP
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,475
Thanks for the advice chaps.
I have recently replaced all the fork bushes, that's when I experimented with removing the 3rd bush and spacer - as I said I felt this gave unacceptable play in the fork. It did definitely reduce the stiction though!
But I'll try the other suggestions. I was in two minds about the seal savers anyway - do they keep the seals clean, or do they trap dirt and water?
Question - what would you use to polish the fork sliders? Simply metal polish, maybe followed by a coat of silicon spray?
Old 07-29-2013, 11:46 PM   #9
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,453
Alex
Wow, great and timely post. Exactly what I was noticing with my 950 S forks. I've heard many guys refreshing their front suspension... I've not noticed any changes in my rear shock. Is there any periodic service required? Or do you just ride it until you blow a seal?
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Old 07-30-2013, 07:10 AM   #10
KM TUNER
Oddometer: 860
For your peace of mind, I have removed the 3rd bushing and sleeve on well over 200 sets of forks without any issue's. This was the first thing almost every enduro/desert racer did on the smaller KTM's back in the day when the forks came out. It will not create intolerable slop, it will be in line with just about every other fork on the market.
I do not run seal savers, and we recommend against them unless you are religious about dropping them down and cleaning them otherwise mud will get packed in there and slowly destroy the seals and wipers.
To polish the lowers heres a quick video to see how we do it: http://www.youtube.com/watch?v=Zp0u4WVX_TI
Old 07-30-2013, 07:12 AM   #11
KM TUNER
Oddometer: 860
We recommend every 15,000 miles, or every other year as a service interval for front and rear.
Old 07-30-2013, 09:16 AM   #12
uk_mouse OP
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,475
Thanks for that. I've ordered some SKF seals, so when they arrive I'll strip the forks and experiment again with removing the 3rd bush.
Old 07-30-2013, 10:09 AM   #13
DesertSurfer
Tail sprayin
Oddometer: 1,453
What does a 15,000k service entail on a rear 950 Adv S shock? A drain, bushing inspection and recharge? Just asking.
Because when it comes to suspension servicing... I don't know Jack Shock!
Old 07-30-2013, 07:38 PM   #14
KM TUNER
Oddometer: 860
A shock service entails a complete tear down and inspection of all wear items (shock shaft bushing, piston bushing, oil seal, dust seal), as well as a thorough inspection of the shim stacks to see if there is any distorted shims.
Once all items have been addressed we assemble the units without oil and use a vacuum bleeding/filling system to ensure all air is out of the shock.
Old 07-30-2013, 07:50 PM   #15
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,152
Just thought that I would add, the forks will have a lot of sticktion if the front wheel is not re installed correctly in the forks.
-John
An Elefant never forgets.
www.Raceforthewounded.com
azcagiva is offline   Reply With Quote
Times are GMT -7.   It's 06:33 PM.
