Old 07-29-2013, 11:01 AM   #1
onewoodsrider OP
Oddometer: 187
Speedometer reading seems off
Just picked up a new to me 05 ktm 950s. On the way home it seemed that my speedometer was reading faster than I was actually going. Is the speedometer adjustable for wheel diameter? It shows 21 when it first turns on.
Thanks all
Todd
onewoodsrider is offline   Reply With Quote
Old 07-29-2013, 11:49 AM   #2
Qwik
Adrenaline Addict
Oddometer: 6,890
Yes it is adjustable. I have mine set for a 19 and it shows a pretty accurate actual speed.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 07-29-2013, 12:14 PM   #3
onewoodsrider OP
Oddometer: 187
Thanks for the heads up. I will try setting it at 19 and get the gun out. Down side to this is that I am not as fast as I though I was lol.
Old 07-29-2013, 12:26 PM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,059
When you set wheel dia at 19, your milliage is also affected.
It will read lower than real, so keep that in mind when counting distances.
Cheers.
Old 07-30-2013, 09:03 PM   #5
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,137
In stock form with the stock front tire, your bike will read 60 at 55mph, it will read 10.4 mi at 10.0 miles.
"Son, you can't do both"
Old 07-31-2013, 08:32 AM   #6
onewoodsrider OP
Oddometer: 187
Is there any way to fix this problem without tricking the computer?
Todd
Old 07-31-2013, 08:37 AM   #7
Somewhere Far Beyond
The Narrator
Somewhere Far Beyond's Avatar
Oddometer: 200
I personally keep the wheel size at 21 since I'm used to the speed reading high and I understand that changing the wheel size will make the speed correct but throws the odometer reading off.
I would rather my odometer is spot on rather than my speed. That's what GPS is for.
I've had two 640s and one 950S, all of which had the same speedo/tach setup, all of which behave the same way concerning speed/odo readings.
Just use a GPS to figure out actual speed.
2003 KTM 640 Adventure
Somewhere Far Beyond is offline   Reply With Quote
Old 07-31-2013, 01:18 PM   #8
Sumi
Sumi's Avatar
Oddometer: 1,812
Todd
Actually it's not a problem.. It's ment to be this way (EU laws..)
Times are GMT -7.   It's 07:56 AM.
