Old 07-29-2013, 04:59 PM   #1
laramie LC4 OP
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,415
Bar Risers: Need pics
want to put some risers on the 990 but don't want to break the bank doing it.
anyone have pics of either of these on their bike?
Mori Designs 19mm bar risers; $20 from Munn racing
"Will fit most KTM models, bolts included are for 950/990 "Hard" annodized. This lightweight riser is designed like a brace to reduce any twisting"
or,
KTM 18mm risers (part #
58401043018), $29.00 from Munn racing
any thoughts on either, or other options i may have missed is appreciated.
thanks,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 07-29-2013, 05:12 PM   #2
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,297
I can recommend this
http://www.advrider.com/forums/showp...&postcount=170
I like the fact that it raises the bar AND moves it a bit forward so you're in a far more natural position than using KTM 18mm risers (didn't work for me)
Two versions (2.0 and 1.25 rise), can't remember the price but it was $60 or so.
It seems he doesn't connect to this forum anymore but on the last page you'll get his contact info.
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is offline   Reply With Quote
Old 07-29-2013, 07:00 PM   #3
quicksandfab
Experienced n00b
quicksandfab's Avatar
Oddometer: 22
+1 for the Rally Risers
quicksandfab is offline   Reply With Quote
Old 07-29-2013, 09:11 PM   #4
Qwik
Adrenaline Addict
Oddometer: 6,868
Buy a set of Rox Risers. One of the best investments I have made for my KTM. Adjustable, strong, and an easy install.
Topes never seem to make me go any faster.
Qwik is online now   Reply With Quote
Old 07-29-2013, 11:04 PM   #5
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,012
+2 I run the two different heights on both my 990Advs
Cheers.
Old 07-30-2013, 08:49 AM   #6
OlivierS
Oddometer: 98
I have the KTM risers, this was not nearly enough, so I put some Rox risers as well wish I would have done that months ago, it's worth the investement and you can take them to your next bike...
OlivierS is offline   Reply With Quote
Old 07-30-2013, 10:21 AM   #7
Cris
AB+
Cris's Avatar
Oddometer: 133
My sentiments exactly!
It's a five minute install and does wonders for riding position on a couple of levels.
Cris is offline   Reply With Quote
Old 07-30-2013, 10:40 AM   #8
laramie LC4 OP
crash test dummy!
Oddometer: 2,415
ya, but i would rather not spend $70 when i can do it for $20.
plus, call me vain, but i don't like the look of the Rox risers. looks like an after thought...
no one has any input on the Mori risers? for $20 i think i may just have to give them a shot. i don't need much rise, nor do i believe i need to move forward at all.
thanks,
laramie
Old 08-07-2013, 07:48 AM   #9
Bowser
Oddometer: 169
+1, I am sure that they work well, but god they are ugly as hell
Bowser is offline   Reply With Quote
Old 08-11-2013, 07:52 PM   #10
Ktrout
Oddometer: 6
You can hardly see the riser bar and they work fine. My stock cables fit well also. I am 6' with 30" inseam( long torso) and they make the bar position much more confortable. A great fix for me.
Ktrout is offline   Reply With Quote
Old 08-12-2013, 05:06 AM   #11
roookie1
Oddometer: 119
Sigutech
I have one of these the 3,2 cm version. I´m 180, and have a 32" inseam..
I like em. You can add some more height yourself by inserting spacers under the handlebar mount if needed..
Ktm 950 Adv S Go!! 2004 (Mathilda)
Ktm 530 Exc-r 2008
roookie1 is offline   Reply With Quote
Old 08-12-2013, 06:01 AM   #12
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 7,663
Anyone find a taller handlebar that mimics the stock handlebar sweep? I have bar risers, but need an 1" or so more.
Are there peg lowering kits? Not that I want to lower the pegs much since they already scrape pretty easily on pavement.
"There isn't any secret," he said. "It's all very obvious."
UngaWunga is offline   Reply With Quote
Old 08-12-2013, 12:41 PM   #13
triplenickel
triplenickel's Avatar
Oddometer: 2,428
Rox could easily be the last riser you ever buy. Function before form or.....
07 SE
PG007
Old 08-12-2013, 12:52 PM   #14
Frog uk
Oddometer: 287
I have the KTM risers and find them just right, cheap, simple, job done.
But it all depends on your size at the end of the day.
Frog uk is offline   Reply With Quote
Old 08-12-2013, 01:45 PM   #15
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,018
Same here. Note that you can run into problems with your throttle cables getting too tight with almost any riser. Some people flip over the throttle to put the cables on the bottom of the bar. There are some space problems with that. A better solution is to reroute the throttle cables to the right side of the frame head.
{KTM risers, before I moved my throttle cables to the right.}
{After throttle cables moved to the right.}
Orangecicle is offline   Reply With Quote
Times are GMT -7.   It's 09:28 PM.
