Old 07-31-2013, 01:41 PM   #1
Ads OP
Oddometer: 10
Vibranators/Bar weights
Hi to all from sunny Cornwall UK, has some one got a set I can buy for my 2012 ADV 990, or may be swap for a rally raid screen in white and black, please HELP!!!! fed up with dead fingers. Cheers Adam.
Ads is offline   Reply With Quote
Old 07-31-2013, 01:53 PM   #2
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 2,095
Try bar end weights, foam grips, or foam grip covers (over rally grips).
Sample:
http://motorcycle.motorcycle-superst...cle/Bar%20Ends
http://www.ascycles.com/detail.aspx?ID=76265
"In the end, it's not going to matter how many breaths you took, but how many moments took your breath away"
mcmann is offline   Reply With Quote
Old 07-31-2013, 04:15 PM   #3
zgfiredude
Oddometer: 876
Or Tennis Racquet grip wrap.....
DRZ440E, KLX440R, DRZ250, KTM 950S Adv, F650GS, & F650GS Dakar
zgfiredude is online now   Reply With Quote
Old 07-31-2013, 07:26 PM   #4
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,893
Cant say there are that many vibes in a LC8 - but if you think you need them get foam grips or maybe investigate the bar bend itself. Changing to a MX or SX bar will make a world of difference!!!
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 07-31-2013, 07:33 PM   #5
Motomedic
Motomedic's Avatar
Oddometer: 2,509
FWIW, I thought the Vibranators made a large reduction in the felt vibrations.
Why not just order a set from them?
http://www.vibranator.com/
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is offline   Reply With Quote
Old 08-01-2013, 12:58 AM   #6
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,481
I've wondered about filling the bars with lead shot, or something similar. Probably with a bit of silicone to hold it on. Never got round to trying it though :(
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 08-01-2013, 01:28 AM   #7
Peanuts
Peanuts's Avatar
Location: Beautiful but often rainy North Yorkshire, UK
Oddometer: 1,731
They are heavy enough to pick up as it is!!!
I know what you mean about vibrations, feel the bar clamp at speed and it has some big vibes on it. Thats with balanced 17/19" wheels too.
I am going to try filling the bars with silicon.
Peanuts is offline   Reply With Quote
Old 08-01-2013, 05:19 AM   #8
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 584
Don't bother adding these, despite being quite heavy (about 180g), they make no difference at all!
BMWs always have them, but why?
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 08-01-2013, 05:21 AM   #9
RedRupert
RedRupert's Avatar
Oddometer: 584
Cyril's bike used bar-end weights and the KTM isolated handle-bar mounts.
Yamaha WR 450 F
Old 08-01-2013, 09:58 AM   #10
skydivegazoo
Oddometer: 33
Short answer: They look interesting. Try them out and report back to us.
Long answer:
The thing to remember about your vibration issues is that they are YOUR vibration issues. Unless there is something mechanically wrong with your bike, you can't really make them go away. You can only change how they affect you.
Think of your bike, bars and YOU as a system. Vibrations start in the engine and wheels, transmit through the frame, triple clamps, bar mounts, bars, grips, into your palms, through your wrist and up your arm. Change any one part of that system and you change the whole. The change may be major or may be so minor that you can't detect it. You could even make it worse. The only way for you to know what works for you is to try it. I suggest you try the free stuff first.
1) Is the bike mechanically sound? Sorry, had to be asked.
2) Riding position. Are you putting too much weight on the bars or gripping too tightly? What angle are your wrists? Does changing riding position alleviate vibration problems? If so, try to figure out why.
3) Ride in a different gear. See what changes.
4) Bar position. Rotate the bars a few degrees either way and move them forward and back if you have adjustable mounts. Pay attention to how bar position affects riding position and wrist angle. Experiment. Note that if you move the mounts one way and then rotate the bars the other way, you can have the grips in the same position, but they will be at a slightly different angle (This is what worked for me in the end - it vibrates as much as ever, it just doesn't bother me any more. And it was free.). Try short risers. Better or worse?
5) Bar weights. Mostly they just change the resonant frequency of the bar system. It may be enough to help. Take the ones you have off. How's that? For the most part, even fancy bar weights are still just bar weights, the important thing is mass and distance from centre. The vibranator seems different, though. It looks like it would respond in a unique way. I'm intrigued.
6) Change the bars. Even an identical bend from a different manufacturer will transmit vibrations differently. The result would be similar to adding or removing bar weights. More better would be to change the bend. NOW we're talking. Liked the risers? Get a taller bend and throw them away. Found a bar position that you liked but it was weird for your wrists? Pick a bend to fix that. Sit on the bike and hold your hands out where you feel that bars should be. Look at all the angles.
Sorry for being long winded, but that should give you some ideas before you spend a lot of money on stuff that ends up not working.
Good luck!
skydivegazoo is offline   Reply With Quote
Old 08-01-2013, 12:08 PM   #11
Peanuts
Peanuts's Avatar
Oddometer: 1,731
Interseting that he has his light switch set up to operate dip/main with his thumb. I prefer to rotate the top part of the switch 180 degrees and operate the kill and horn with my thumb....
Old 08-02-2013, 06:05 AM   #12
Peanuts
Peanuts's Avatar
Oddometer: 1,731
So I filled my bars with silicon bathroom sealer last night. Took a fair bit of force to push the stuff from one side all the way through till it came out the other side.
Then I dug out enough length for the handguard inserts.
This morning I realised the bars have locating holes drilled in them for the switchgear!!!!!!!!
Fortunately the silicon had not fully cured so I was able to peel/dig it out the switches!
Will ride the bike at the weekend to see if the vibes are reduced......
Old 08-02-2013, 06:59 AM   #13
Zander
Zander's Avatar
Oddometer: 194
He also seems to be using foam grips.
Beginner's mind !
KTM 950
Zander is offline   Reply With Quote
Old 08-02-2013, 10:01 AM   #14
RedRupert
RedRupert's Avatar
Oddometer: 584
Well spotted!
Yamaha WR 450 F
Old 08-02-2013, 01:47 PM   #15
Ads OP
Oddometer: 10
Wow! what a response, all to much, I am going to sell the damn thing!
Times are GMT -7.   It's 08:57 PM.
