Old 07-31-2013, 07:03 PM   #1
rubRsidedown OP
rubRsidedown's Avatar
Oddometer: 2,726
Question 950 stalls once in a while
My 950 just started stalling when hot while sitting at a red light.
Tweaked idle up a smidge still doing it from time to time.
Happened three times this evening.
My Son took it last week and said it did it to him at a red light on two separate occasions
Thoughts?
Jeff B In Maine
05.5 KTM 950 Adventure Black, Mine
06 BMW F650GS Electric Orange, Hers
"We don't quit playing because we grow old, we grow old because we quit playing."
rubRsidedown is offline   Reply With Quote
Old 07-31-2013, 07:23 PM   #2
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,823
Valves! I'll bet the exhausts are tight. I had exactly the same symptoms and a shim did the trick.
Of course while your in there do the carbs/clean the throttle bodies and renew the air filter. Quick oil change and your good for a lotta Km's.
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 07-31-2013, 07:38 PM   #3
Racer111v
Racer111v's Avatar
Oddometer: 851
Mine was doing it from time to time. I did a few things at once, so here it goes. I sync'd the carbs. They were a full inch+ apart. I raised the idle about 200 rpm. I also changed the h2o seal , and fuel pump (new oem). That was done as maintenance, not looking to solve a problem.
I haven't had it happen once since.
2004 KTM 950 ADV ...............................1979 Suzuki RM400 VMX Race bike
2006 DR-Z400E plated........................... 2001 Ducati ST2 944
2001 YZ250N 2T plated.......................... 1986 Yamaha FJ1200
Racer111v is offline   Reply With Quote
Old 08-01-2013, 01:45 AM   #4
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 954
Check the choke cable. Sometimes might get dirty and wont retract fully, so you'll have a choked engine at idle and that can cause it to stall
690R
Gustavo.Ramos is online now   Reply With Quote
Old 08-01-2013, 06:21 AM   #5
rubRsidedown OP
Oddometer: 2,726
Thanks guys, I'll check the easiest things first and go from there.
Thanks again.
Sent via my New England Telephone™ rotary dial device
Jeff B In Maine
Old 08-01-2013, 08:44 AM   #6
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
Put some carb cleaner in your tank and clean your oil jet. done
DeepInIt is offline   Reply With Quote
Old 08-01-2013, 10:42 AM   #7
DrKayak
Retro Rider
Oddometer: 795
Originally Posted by DeepInIt View Post
Put some carb cleaner in your tank ..
and take it out and run it hard.
Mine was doing it, I don't ride it enough. Ran it hard a couple of rides and it has not done it since. .. and I got religious about add fuel stabalizer to every tank... becuase I don't ride it often and the crap ethanol in the gas.
DrKayak is offline   Reply With Quote
Old 08-01-2013, 12:46 PM   #8
rubRsidedown OP
Oddometer: 2,726
You know what,
I think we have a winner here.
I too don't/haven't been riding it as much as I should/used to. (been boating a lot on weekends and vacations so the bikes on the back burner so to speak) I bet fuel is the cause.
I religiously add fuel stabilizer to my snowmobiles in the winter each and every fill up but for some strange reason I don't even think twice about the bike.
Thanks again for all the tips especially bringing this to my attention.
I can't believe I didn't even give that a second thought.
Jeff B In Maine
Old 08-01-2013, 02:27 PM   #9
Katoom72
Katoom72's Avatar
Oddometer: 910
Sync the carbs, mine is doing the same at the moment and they need syncing.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 08-01-2013, 02:46 PM   #10
rubRsidedown OP
Oddometer: 2,726
They have been synched within a few thousands miles, can't imagine they are out but you never know.
Jeff B In Maine
Old 08-01-2013, 02:49 PM   #11
Katoom72
Katoom72's Avatar
Oddometer: 910
By yourself?
Sorry, i just don't thrust dealerships.
Now:
Before:
Old 08-01-2013, 05:44 PM   #12
rubRsidedown OP
Oddometer: 2,726
Originally Posted by Katoom72 View Post
By yourself?
No,
a MORE qualified person than myself.
Unfortunatly he passed away since.
Jeff B In Maine
Old 08-02-2013, 07:42 AM   #13
Katoom72
Katoom72's Avatar
Oddometer: 910
No,
My condolences for your loss.
Now:
Before:
Old 08-02-2013, 08:57 AM   #14
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 2,018
You know what,
Side holes in the idle jet may be partially plugged:
Vee2 "The Train", Wee2 "Muliti-Tool"
NC7X "Commuter Xtraordinaire"
mcmann is offline   Reply With Quote
Old 08-02-2013, 09:50 AM   #15
Tangai
Oddometer: 589
Everything advised so far is good and might solve your problem.
However, my 950 did the same although everything was perfectly tuned. Finally, I synchronized the carbs with the front cylinder a little ahead of the rear. On the liquid tube gages, the front cylinder is about a 1/4 inch higher than the rear. With that, my bike will idle at 1,100 RPM all day and never dies—cold or hot.
Tangai is offline   Reply With Quote
Times are GMT -7.   It's 03:27 AM.
