Old 08-02-2013, 01:26 PM   #1
BOHUNTR OP
Character and Honor Count
BOHUNTR's Avatar
Oddometer: 446
2007 KTM 990 Adv information
I have seen a local KTM with 12K on the odometer that looks pretty good. When I try to google this, it always comes up as a 950/990 until 2009, when it's called a 2009 model-present.
So.... Is this really a 950 with a slightly bigger motor? What is the reliability of this year? I know the 05.5 models are better than the prior years. Is this considered the first of the 990's and a model prone to bugs?
Any information on this would be helpful. The 07-08 models seem to be hard to specifically identify issues for.
John
BOHUNTR is offline   Reply With Quote
Old 08-02-2013, 03:34 PM   #2
wpbarlow
Oddometer: 11,287
Google better-- like 2007 KTM 990
http://www.ridermagazine.com/road-te...road-test.htm/
I think low speed throttle operation was the biggest issue. Folks will probably pipe in with information.
wpbarlow is offline   Reply With Quote
Old 08-02-2013, 03:50 PM   #3
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,311
First year for 990 is 2006, last year for 950 was 2005
Generally speaking, 2006-07-08 are the less desirable years for 990s because of the throttle response mentioned above, but they don't have any different issues that may have newer bikes.
06-08 have a nicer dashboard than 2010-12 though
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is online now   Reply With Quote
Old 08-02-2013, 04:02 PM   #4
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,481
From the H.O.W.
Model year differences:
KOTH: The following differences between model years are related to the actual year of manufacture of the bike, not the year on the registration. KTM's model year runs from June to May. For example, A true 2004 bike was manufactured between June 1, 2003 and May 31, 2004. A true 2005 bike between June 1, 2004 and May 31, 2005, etc, etc. There are were a few instances when bikes with even earlier build dates were shipped as later year models. Whether this was due to an effort to clean out inventory or a need to meet production demands, the latest updates should have been done before they left the Factory. Still, it behooves the owner of such a bike to carefully go over it to make sure all pertinent Tech Bulletins have been taken care of.
The bikes are registered in their destination countries as the year they are delivered to the dealer. I don't know how other countries do it, but KTMNA has been known to keep bikes in their warehouse for six months and release them to the dealers after the start of the New Year. So just cuz your bike's registration says you have an '04, '05, '06, '07, etc. Doesn't necessarily mean you do. Many of the differences listed below are visible upon close examination of your bike. That and the build date from the KTM Dealer-Net are the surest way to tell the actual year of your Katoom. The designation XXXX.5 is not used in KTM's documentation to denote actual year of build, so look for yourself, if you really want to know (important for certain maintenance and tech Bulletins).
Differences between 2003 and 2004 Adventures (USA) (6/03-5/04):
Added black bikes and blue bikes to the line up (1/04-5/04)
Black wheels (1/04-5/04)
Color matched front fender (1/04-5/04)
Different fork legs
Different rear shock
Added carb vents to the canister system
New oil tank
New fuel pump
New crankshaft and rods
New cylinders
New oil pressure switch
New pulse generator
New ignition rotor
New clutch pushrod (600.32.054.100)
New outer clutch hub
Differences between 2004 and 2005 Adventures (USA) (6/04-5/05):
New chain slider on frame
Lower center stand and shorter sidestand (1/05-5/05)
Shorter front brake hose (1/05-5/05)
New swingarm pivot bolt
New front exhaust header (1/05-5/05)
New heat shield for front exhaust (1/05-5/05)
New fuel tank fill flanges
Carb de-icers
Lower suspension front and rear (different forks and rear shock) (1/05-5/05)
New seat (1/05-5/05)
New speedometer (1/05-5/05)
Wider rear wheel: 4.25" wide (Up from 4") (1/05-5/05)
New rear brake caliper pistons
Splash guard under triple clamp area of frame
Splash guards on sides of triple clamp area of frame
New fan shroud (directs air away from rider)
Added a Torque limiter to the starting system (1/05-5/05)
Redesigned engine case with added cylinder oil injectors(2) (1/05-5/05)
New front sprocket chain protector
Added a main bearing retainer plate (1/05-5/05)
Added a 2nd vacuum valve to the canister system
New balancer shaft with 2 piece timing gear (1/05-5/05)
New cylinders (1/05-5/05)
New exhaust valves (1/05-5/05)
New valve buckets (intake and exhaust) (1/05-5/05)
New head nuts and added washers
New oil dipstick (10mm longer) (1/05-5/05)
New oil tank ball valve
New ECU
Added a rollover sensor
Added crankcase vent back pressure valve (1/05-5/05)
New clutch pushrod (600.32.054.300) (1/05-5/05)
Differences between 2005 and 2006 Adventures (USA) (6/05-5/06):
New steering head bearings
New frame
New swingarm
New "H" pipe clamps
New glovebox interior
New rear hub
New speedo sensor and cable
New clutch cover
New crankshaft and connecting rods
New shift drum
New clutch pushrod (600.32.054.400)
Differences between 2006 and 2007 Adventures (USA) (6/06-5/07):
Added a Dakar paint scheme to the blue "S" model
998 cc engine (2007 Super Duke Engine)
Fuel injection
New wiring harness
ABS brakes (non "S" models)
*New waterpump seal (PTFE)
*New waterpump shaft (nitride coated)
*New re-designed torque limiter, idler gear and ignition cover
*New forks
*New triple clamps
*New frame
*Silver subframe
*New plastic engine protectors
*New lower tank mount
*Silver passenger footrest brackets
*New rear shock
*New silencer with 3-way CAT
New fuel tanks with internal HP pump
*Added thermal foil protection on plastic parts
*New front and rear rims
New floating brake rotors front and rear
*New rear brake cylinder
*Added an electric solenoid to the evaporative canister system
*New clutch slave cylinder
*Silver foot brake and shift levers
Added LC4 foot brake lever stop
New horn
*New front fender (more clearance from tire)
New battery charging terminals (accessible from right side)
Torx head fittings replace many small hex head screws
*= New for 2007 (non-asterisk is 2006 EURO/UK/AUS 990)
Differences between 2007 and 2008 Adventures (USA) (6/07-5/08):
New forks
New rear shock
New ECU (Timing Charger EFI)
New ABS module and brake hoses
New water pump rotor (thicker)
New water pump shaft (longer)
New handlebar
New inner clutch cover
New oil tank
New fuel hose
Differences between 2008 and 2009 Adventures (USA) (6/08-5/09):
First year for the white (ABS)
First year for the "R" Black and white with orange frame (non-ABS long & travel suspension)
New pistons (2008 Super Duke pistons)
New camshafts (2007 Super Duke cams)
Increased horsepower ratings (106hp for ABS and 115hp for "R")
New wiring harness
New ignition lock with immobilizer
New water pump cover
New instrument panel
Black forks
New Black swingarm
Emergency flashers
New design tanktop storage box
Differences between 2009 and 2010 Adventures (USA) (6/09-5/10):
New oil pump pressure regulator
New skid plate and skid plate/fuel tank mount
New silencers
New forks
New rear shock absorber (mono shock)
New MFSD (speedometer)
Differences between 2010 and 2011 Adventures (USA) (6/10-5/11):
Added "Dakar" model (blue, ABS, 210mm suspension, 115hp engine)
Reduced suspension travel on the "R" model by 17mm
Adventure Suspension Travel:
2003-04: 9.0" (230mm) - "S" 10.4" (265mm)
2005-06: 8.3" (210mm) - "S" 9.65" (245mm)
2007-08: 8.3" (210mm) - "S" 10.4" (265mm)
2009-10: 8.3" (210mm) - "R" 10.4" (265mm)
2011-11: 8.3" (210mm) - "R" 9.76" (248mm)
Adventure Seat Height:
2003-04: 34.6" (880mm) - "S" 36.0" (915mm)
2005-06: 33.8" (860mm) - "S" 35.2" (895mm)
2007-08: 33.8" (860mm) - "S" 36.0" (915mm)
2009-11: 33.8" (860mm) - "R" 36.0" (915mm)
2011-11: 33.8" (860mm) - "R" 35.2" (895mm)
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 08-02-2013, 04:27 PM   #5
BOHUNTR OP
BOHUNTR's Avatar
Oddometer: 446
Thanks for the information. I hit the OC Hall of Wisdom as well.
Has there been a definitive answer for the quirky throttle between 3-4.5K rpms? Haven't seen anything except for changing the fuel injection tuning with tune ECU.
Thinking of picking it up this weekend, it's a clean bike, the price is decent and at 12K miles it's not been around too much.
Old 08-05-2013, 06:20 AM   #6
ronsolo
Hooplehead
ronsolo's Avatar
Oddometer: 826
Curious what the market is for this bike. I have a pristine 2007 with 9K on it that I am thinking of selling because I don't have time to ride it. Gobi bags and FMF exhaust. Poor thing sits in the garage.
2012 C14
ronsolo is offline   Reply With Quote
Times are GMT -7.   It's 04:11 AM.
