Old 08-03-2013, 08:17 AM   #1
Katoom119 OP
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
Brake light out, tail light working?
Brake light has gone out on my 08 990 and here's what I know so far:
1. I have no power at the bulb socket.
2. I have no breaks in the green power and brown ground wire running back to the first 3-pin connector.
3. At aforementioned connector, I have no power in the green power and brown ground. However, I do have power in the white running and brown ground wires. The brown wires share a common ground.
Symptoms:
Brake light kaput; front brake and rear brake levers will not activate it. I still have my horn and speedo (which share the same fuse) and I have pulled the fuse under the glove box to confirm that it's hunky dory.
Any other thoughts before I start pulling tanks off? I'm thinking I've just got a break in the green power wire.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 08-03-2013, 08:29 AM   #2
sieg
sieg's Avatar
Oddometer: 2,867
Well, check continuity from first 3 pin connector to the two brake light switches. If good check switches. Also check for power to the switches.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 09-30-2013, 10:53 PM   #3
KMC1
There is no spoon.
Oddometer: 2,561
Hey, what did you end up finding with this? I just got the exact same symptoms on my 2009 990 adv tonight.....
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em
An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
KMC1 is offline   Reply With Quote
Times are GMT -7.   It's 02:28 AM.
